Old 09-06-2011, 06:23 PM   #1
AL1983's Avatar
Questions?? Wheel well diameter!
Hi I'm a rookie at cutting RC bodies!
My question is:
What is the best diameter to cut the wheel wells with a circle cutter? (if one is thinking about entering a race event)
I Have a Protoform Dodge stratus 3.1, and I use Xceed foam tires.
Thx for helping!
Sorry for the newbie question!
AL1983 is offline   Reply With Quote
Old 09-07-2011, 02:18 AM   #2
Just use the cutout lines provided on the body, and check to see if the wheels (at maximum diameter) hit the body, or able able to catch the body at all. Then just enlarge it where it is needed.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 09-07-2011, 03:05 AM   #3
Hi i do mine to 64mm, have never had to trim them larger. hth
aaron w is offline   Reply With Quote
Old 09-07-2011, 11:40 AM   #4
Geezatec's Avatar
follow EFRA rules, you'll be ok.
Geezatec is offline   Reply With Quote
Old 09-09-2011, 12:07 AM   #5
As far as I remember, there aren't any rules stating how large the wheel wells are allowed to be - it's more or less common sense not to make them INCREDIBLY large (it would just look wierd!)
64mm should be fine, after you cut them, place the body on the car and see how it fits. With the front wheels, turn the wheels and push the body to see if there is any possibility of the body being collected by the wheels, Same goes for the back end - push the sides in and see if it gets collected by the wheel as it rotates.
Old 09-09-2011, 01:47 AM   #6
Suspended
That test should also be done with the suspension fully compressed to the ground !!!
bertrandsv87 is offline   Reply With Quote
Old 09-09-2011, 01:59 AM   #7
blis's Avatar
And with tyre diameters too.. Full are around 64, we start at 62 rear and 60 front.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-11-2011, 11:33 AM   #8
AL1983's Avatar
Thumbs up Thanxx!
Thanks for helping me out!
F1 is alive and well in So. Cal! 240Z California Racing 5880 07-06-2012 05:36 PM
Favorite 1/8 Buggy Wheel ?? Dan Reino Nitro Off-Road 18 04-05-2008 03:53 AM
What to look for in a wheel... josh69162 Electric On-Road 9 10-17-2005 07:07 AM
·New TakeOff dish wheel VS Cross spoke wheel· ZER01 Electric On-Road 29 10-04-2003 05:14 PM
Tags
cutting, diameter, wheel wells
