Old 11-10-2004, 05:00 PM   #1
macnkitty2002's Avatar
Default Front One Way Differential-Does it help?
I was going to get the FT NTC3 soon. I noticed that it comes with a front one way differential. I have heard that to racers who have not driven a car with a one way it is challenging to drive the car. They claim that a constant throttle must be applied to prevent from spinning out. Will it be hard to learn to drive with a one way, especially since this will be my first nitro onroad car?
Note-I am a very experienced driver, though I have never driven a nitro onroad vehicle.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 11-10-2004, 05:15 PM   #2
thefuzzclub's Avatar
Default Re: Front One Way Differential-Does it help?
i start to learn driving with front diff and when i shifted to one-way, oh boy!!! my lap time really improved a lot. almost everyone will say that hard breaking will be the first challenge you have to face. set-up(lessen) your breaking travel through your radio to a point that when you break, the rear end of your car will not sway to the front. there will be some sacrifice on breaking but as you go along practicing, you'll get use to it.
thefuzzclub is offline   Reply With Quote
Old 11-10-2004, 05:15 PM   #3
AMGRacer's Avatar
I am suprised that a "very experienced" driver has never tested a oneway. In any event you do not need to apply constant throttle to stop from spinning. On the right surface they are not harder to drive than a diff car. You use them on high grip surfaces where you do not need to brake hard.
AMGRacer is offline   Reply With Quote
Old 11-10-2004, 05:29 PM   #4
Dan
Dan's Avatar
Trader Rating: 48 (100%+)
Its just learning to drive differently thats all. When I ran diffs all around a few years ago, I would tap the brakes lightly before turning into the corner.
When I went with foams and front one way setup, I didn't use brakes that much. With foams, I still had the grip I needed, but with the one way setup, I had so much more steering available. It will make you a much smoother driver too since you'll focus more on the "line" and won't be hard on the brakes.
Dan is offline   Reply With Quote
Old 11-10-2004, 05:47 PM   #5
so do you think that if i start out driving with a fron one way as apposed to starting out with a regular diff, it should be easier to learn? i run on a pretty technical track, with few straights, so will the one way help?
Losi Rock Rey
Old 11-14-2004, 10:45 PM   #6
Im2lazy's Avatar
Really depends. If you run a one-way and you don't have to really worry about your car's stability when decellerating- but instead focus on getting your car to weave through the track, then a one-way works wonders. However, sometimes diffs or even a front solid axle works... but this is for tracks where stability under braking is more important than just a lot of steering.
With few strainghts, chances are, its the hot setup already.
Im2lazy is offline   Reply With Quote
Old 11-15-2004, 04:07 PM   #7
i see, thanks!
Losi Rock Rey
Old 11-17-2004, 02:24 AM   #8
AndyT 's Avatar
I`ve been racing a FT NTC3 and have found the front one-way to be very good on the local tracks here. It corners like its on rails on sweeping bends.
As for braking......well, try to do your braking as the car`s pointed straight, the front one-way will really want to make the car spin out when braking in corners.
Cheers
AndyT  is offline   Reply With Quote
Old 11-17-2004, 05:13 PM   #9
my track has only about 3 straights, though 1 twice as long as the other 2. very technical track otherwise, and the path into the corners is straight, so i think that there should be no braking problem. thanks
Losi Rock Rey
Old 11-18-2004, 02:34 AM   #10
HELLION's Avatar
Default Best way to learn a one way!
I have found the best way to teach someone to use a one way is to have them practise with out brakes! Works every time. That said I like the oneways on the bigger tracks. On short tight tracks I think your better off with out them or at least I am.
HELLION is offline   Reply With Quote
Old 11-18-2004, 06:08 PM   #11
i see.
Losi Rock Rey
Serpent 710 Front Ball Differential NIP scott74dog R/C Items: For Sale/Trade 0 07-23-2008 06:15 PM
Torsion Front Differential -New- Tres R/C Items: For Sale/Trade 3 06-05-2007 11:34 AM
mtx-4 front one way or differential BIGTACO Nitro On-Road 3 10-09-2006 08:51 PM
Mugen MTX4 Front Differential mnpinoy Nitro On-Road 9 03-08-2006 08:04 PM
Wanted: Serpent Front Differential. Kool R/C Items: Wanted to Buy 0 04-27-2002 08:06 PM
