Futaba Module
Futaba Module
Can I use Futaba 3PK Module on my Futaba 3PJS?
Any Info would be Appreciated
Thanks Rich, I'll try as soon as I get that module
Originally posted by Rich Panganiban
spyspeed, Yes the modules are interchangeable between the 3PJS and the 3PK, obviously the receivers are as well. I just switched to a 3PK after running a 3PJS for 5 years.
3PK
FUTL13** RFPK27&75 Futaba RF-PK27/75 FM Transmitter Module 3PK
3PJS
FUTL18** TJ27&75FM Futaba 27 & 75MHz FM Transmitter Module
Part numbers listed are totally different !
InitialD, both the modules and the crystals are interchangeable between the two transmitters. The only difference is the new 3PK has the capability of running PCM or HRS mode which is the fast frame rate mode using the R203H receiver and a digital servo, while the 3PJS will only operate in PCM and FM mode.
