Old 08-25-2011, 07:59 AM   #1
Default Kyosho IGT2 w/ LRP.30 spec 2
Is anyone running an IGT2 with the LRP.30 pull start motor?
I'm trying to find info on what mounts folks are using
apexslider is offline   Reply With Quote
Old 08-26-2011, 04:26 AM   #2
MikaR's Avatar
IGT2 mounts should be fine? I don't see why they wouldn't ..
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 08-26-2011, 07:57 AM   #3
pressure's Avatar
I have seen them doubled up
ITS COMPLICATED......................
pressure is offline   Reply With Quote
Old 08-26-2011, 07:24 PM   #4
Pressure - what good kid...
V-one-RR Evo,V-one-RRR (WC hopped-up),2007 Evolva,
Spada 09,MR-02,MR-03
Inferno GT2. Serpent Cobra GT
KF01 - F1, Serpent Viper 977WC, Serpent Natrix 748
1FastVW is offline   Reply With Quote
Old 08-30-2011, 06:01 PM   #5
they are with some modification to the base (chassis) mount; you have to file/grind some space for the pull start. You also have to use 3-4 1mm spacers on each side between the engine block and the center mounts.
If you don't file down the base mount the engine wants to sit to high and hit the rear drive shaft.
I was hoping to see if someone was able to use any of the other Inferno mounts, like the 777 or 7.5, or st-rr with out mods.
Once the mount spacers show up and I get everything fitted I'll post how many spacers it took
Old 08-30-2011, 08:22 PM   #6
Timmo's Avatar
Trader Rating: 15 (100%+)
Part No. KYOIF210
Timmo is offline   Reply With Quote
Old 08-30-2011, 11:38 PM   #7
*1speedy's Avatar
Timmo I think you might be confused on what he needs.
Here is how to make that engine fit.
I have helped many people put Pullstart aftermarket engines in the IGT2 and sometimes the pullstart sits to low to let the engine sit flush on the chassis.
What you need to do is add a washer or 2 evenly between the engine and the mount.
The IGT2 comes with these shims stock on the mount part # KYOIF211 but the only place I see that has them is IGT hobbies.
I just use a few washers from the hardware store but if you must have them here is a link to get them.
http://www.igthobbies.com/KYOSHO-KYO...CER_p_284.html
GL have fun
🏁🏁🏁 🏆🏆🏆🏆 2013 XRAY XB9 GT8 🏆🏆🏆🏆 🏁🏁🏁
2013 & 2014 R.O.A.R. REGION 1 & NY State GT8 CHAMPION!!
....................... 🏆 SPONSORS 🏆 .....................
ABSOLUTE HOBBYZ / Engines Modded by The Nitro Shop
*1speedy is offline   Reply With Quote
Old 08-31-2011, 09:09 AM   #8
Timmo's Avatar
Yeah,it has been awhile.You guys going to Texas for the race..
Old 08-31-2011, 02:56 PM   #9
GL have fun
Yes, the mounts Timmo posted place the engine too high and the mounts hit the drive shaft.
But I did order two sets of part # KYOIF211. Should sit it in perfectly.
Now the only problem is the manifold that came with the Ofna 086 pipe set hits the pull start, so I have to find a longer manifold (more of a wider bend). I think the Ofna In-Line manifold should work.
Old 08-31-2011, 05:28 PM   #10
*1speedy's Avatar
When Wild Bill "IGT HOBBIES" has a race we may come to Texas for a race but nobody I know here on the east coast is going either.
Old 08-31-2011, 05:59 PM   #11
Timmo's Avatar
I see..
Old 09-10-2011, 07:13 PM   #12
I've been having a problem with my nitro cars. This happens to all of them. Today I took my Inferno GT2 to Atlantic Beach, NY and the engine won't start! This happens to all of my nitro cars! Why does this happen? Can I possibly resolve this?
SUPERFORMIAN is offline   Reply With Quote
