Old 08-21-2011, 02:03 AM   #16
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Strip the car down to bare chassis, lay chassis on setup board or glass. Check the straightness of the chassis for twist and bow. The chances are if you have had a good whack that could be it. If the chassis is good, check suspension for binding. Make sure the pivot balls are free, put equal sized tires on the car (left and right equal). shock length should be even, and then put the car on the tweak board with bars disconnected. set tweak, then you can attach bars, there shouldn't be preload in the bars. Also make sure shock shafts aren't bent causing bind.
Hope this helps.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 11-23-2011, 06:02 AM   #17
Default springs
Also check the shock springs to be equal.With the shocks not mounted I have found out that although the shocks are equal length when the spring load rings are set equal one spring plays more than the other.
dsond is offline   Reply With Quote
Old 11-23-2011, 06:12 PM   #18
Originally Posted by mhavlena View Post
Guys:
My tweak station is telling me that my 1/8th on-road is tweaked. I've pre-loaded the left rear shock 2.5 mm more than the right rear shock...this seems to clear the tweak.
What could be causing the tweak...shocks are identical length, sway bars have been removed (same tweak)..
What are the usual suspects for a tweaked car.
Thanks!!
Do you race with Jason MacDonald? If so, check your chassis. If your pipe is bent, well, that would mean you were "Shinged"
I'm just sayin'....
I couldn't resist...sorry Mike and Jason.
Rich Browne is offline   Reply With Quote
Old 11-24-2011, 01:03 PM   #19
Team Kamikaze's Avatar
I'm just sayin'....
PRICELESS!
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-30-2011, 11:37 AM   #20
xtremes's Avatar
Guys:
Thanks!!
I had a similar problem once and it was the front sway bar that was causing it. One of my front sway bar blade was bent on the edge side of it, not on the flat side....
Vidal
___________________
Team Brooklyn Hobbies
xtremes is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16065 12-13-2017 07:32 PM
Tamiya TRF417 kentech Electric On-Road 6522 09-30-2017 04:06 AM
Rc10ntc3 Taz_S Nitro On-Road 9437 05-28-2017 09:13 PM
Team Corally RDX Phi syndr0me Electric On-Road 3380 03-11-2014 11:27 AM
