BRCA 2005 1/10th classes >
Old 10-31-2004, 02:32 PM
ziggy12345's Avatar
Default BRCA 2005 1/10th classes
Hi
Just got the word for 1/10th rules for UK next year.
the 235 class will remain the same
the 200mm rubber will remain the same
the foam class is now FULL efra rules so 16% fuel 3 port engines and saloon shells.
So that means no 5 ports and no Lola shells! Of the 300 drivers who competed last year only 50 turned up so it was the ones who bothered to turn up go the vote.
I wasnt one of them so I cant complain but i thought the BRCA represented ALL drivers and not the ones who turn up to meetings therfore voting in new rules that affects all drivers at meetings is undemocratic.
ALL drivers should be given the oppotunity to vote on things that affect them. There are a number of ways this could have been organised given a bit of thought. "Well you should have got off your arse and came to the meeting then!" I'm sure somebody will tell me. What about making the proposals public well before the meeting and be given a method of voting if we cant make the meeting.
Any comments?
Cheers
ziggy12345 is offline
Old 10-31-2004, 03:16 PM
Should help with the euros being held in UK in 2005.
We run EFRA rules at Irish Championship level, and i've made the A final with a 3-port at BRCA Foam Aldershot.
I know the cost of the change over with be hard to get used to but at the end of day 95% of people running at BRCA level will have a new engine for 2005 anyway.
Just my thoughts
Mark Gilliland
Xraykool is offline
Old 10-31-2004, 03:29 PM
ziggy12345's Avatar
Is there an Oulaw class in Europe or Ireland? At least give the choice to the drivers!
Cheers
Old 10-31-2004, 06:21 PM
InitialD's Avatar
Ooophs, Onkel Sow will be hopping mad ! I don't think he has any 3 port engines.
InitialD is offline
Old 10-31-2004, 11:33 PM
markp27's Avatar
You really think that old fox Sow would be out foxed? You need to check that ring of yours again, D
markp27 is offline
Old 11-01-2004, 12:10 AM
InitialD's Avatar
Oopphs, I take it back ! I should know that old fox better. My RING is on loan.
InitialD is offline
Old 11-01-2004, 02:21 AM
Sow&Steady's Avatar
Not really D. I've bought 2 new 3-port engines anyway in prep for going to a certain race across the pond. This was also done as a gamble because there is always the potential that work commitments will clash with that race. So now that the BRCA is going the EFRA way I could use the 3-port for that too.
I might be speculating but there might be other races organised around 5-ports. Seeing that this hobby has to fit around work, I'll race anything and anywhere I can.
By the way D, and others who race 5-ports, I'm sure you can now buy 5-ports cheap from UK based shops who now find that their market has been shut down overnight by this ruling.
Oh! Nearly forgot, I have a brand new 5-port Nova Max and a brand new OS 5-port too. Anyone wants to buy them?
Sow&Steady is offline
Old 11-01-2004, 02:24 AM
Sow&Steady's Avatar
Just my thoughts
Mark Gilliland
Doesn't help at all. Apparently only 25 slots are available and there's already a queue of 100!
I assume that the 25 is already filled with sponsored drivers. The rule is that you must have done 6 nationals so sponsored drivers have not only done that but they're also probably the top 25 in terms of ranking.
Old 11-01-2004, 02:25 AM
Sow&Steady's Avatar
Yeah, you tell him Mark!
Sow&Steady's Avatar
Did you loan it to Brett down over at New Zealand? He was looking for it the other day.
Old 11-01-2004, 03:34 AM
Sow&Steady,
Better get yourself an irish passport!!!
Xraykool is offline
Old 11-01-2004, 03:36 AM
Sow&Steady's Avatar
Sow&Steady,
Not a bad idea ... got any slots left? where do I apply for an Irish passport?
Old 11-01-2004, 08:37 AM
Like the Irish Football team, if uve every drank a pint of guinness your in!!
Xraykool is offline
Old 11-01-2004, 09:18 AM
Sow&Steady's Avatar
OK, I've downed a few guiness in my lifetime but I'm willing to prove it if I can join the Irish Euro team!
Old 11-01-2004, 10:25 AM
NiMo's Avatar
Default Re: BRCA 2005 1/10th classes
Originally posted by ziggy12345
Hi
Any comments?
Cheers
Just thought I'd check on this 300 figure, and this is how it breaks down:
IC Scale Rubber 200mm:
134 drivers entered of which 59 done half or more of the rounds.
IC Scale Foam 200mm:
120 drivers entered of which 57 done half or more of the rounds.
IC-10 235mm:
48 entered of which 28 done half or more of the rounds.
So in reality, 120 drivers are affected by the changes, not 300.
NiMo is offline
