Old 08-30-2005, 11:22 AM   #1441
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by rcrevolution
so im gonna call rd and order the shoes and a orange spring
Are you sure that RD doesn't have the stock side plates, ask for part #502199
They are listed here
Walter Diaz
wad is offline   Reply With Quote
Old 08-30-2005, 11:26 AM   #1442
YBSLOW's Avatar
Default Yes
That is what I would do.
I do not understand why people are having so many issues with the clutch. I personally think it is the best sedan clutch I have ever used. The red spring in my opinion is a little too soft, because when you finally tighten to the proper adjustment the spring is smashed and becomes coil bound and this is what makes it slip. The orange spring allows you to run it with the adjustment nut flush with the end of the threads and allows it to be free without coil bind. Basically if you have to tighten the spring down so far as there are 4 or 5 threads showing to get the engagement you are loking for that spring is not stiff enough and you should try the next spring stiffer until maybe 1 or 2 threads are showing.
I personally like the orange spring with the flyweights. Saying all of this I will be trying the new UFO clutch at the next few races.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-30-2005, 11:33 AM   #1443
rcrevolution's Avatar
Send a message via AIM to rcrevolution
yes they are listed but i got this from them
Hi Eric,
Part # 502254 is discontinued and has been replaced by K1439-1. The price for K1439-1 is $60. We would like to offer you a 10% discount if you are interested in purchasing one.
Sincerely,
RDLogics
502254 is the number listed in the manual.
personaly i rather have carbon looks better
rcrevolution is offline   Reply With Quote
Old 08-30-2005, 12:14 PM   #1444
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
Does anyone know why RDLogics doesn't have all of the parts for the Mongoose on the website?
Uneke is offline   Reply With Quote
Old 08-30-2005, 12:15 PM   #1445
wad
wad's Avatar
Which parts?
Walter Diaz
Old 08-30-2005, 12:20 PM   #1446
Moderator
Uneke's Avatar
Originally Posted by wad
Which parts?
Replacement parts, spur gears, clutch bells, etc..
Old 08-30-2005, 12:25 PM   #1447
wad
wad's Avatar
Check here
Walter Diaz
Old 08-30-2005, 12:38 PM   #1448
Moderator
Uneke's Avatar
Check here
Thanx, but i've been all over the site and there are a lot of little things not listed.
Old 08-30-2005, 12:39 PM   #1449
wad
wad's Avatar
You right, it wasn't like this before, I will find out.
Walter Diaz
Old 08-30-2005, 12:40 PM   #1450
thats weird
the manual says 502254 is the aluminum side plates in the build part, but in the rear it says its 502299, and so does the site, o well I rather get carbon
Old 08-30-2005, 12:40 PM   #1451
YBSLOW's Avatar
Default Parts not listed.
I do not know why they do not list every part? Mystery to me as well, I've talked to them about it, but does not seem to be a priority. All I can say is email them or call them with a part number and most likely they have it even though it may not be listed.
YBSLOW Racing
Old 08-30-2005, 12:51 PM   #1452
hmm the clutch shoes are the same, and the g4 and ntc3 use the same centax clutch
Old 08-30-2005, 05:11 PM   #1453
this is so messed up, everytime I tighten the clutch screw the centax locks up.
what am I doing wrong?!
i installed everything according to the book
Old 08-30-2005, 05:18 PM   #1454
Regional Moderator
Darkseid's Avatar
Rear sway bar...
I mentioned a while back that I was getting uneven action out of my rear sway bar, and a couple other people mentioned they had the same problem.
Well, I found out what was up while I was changing the oil in my rear shocks. As it turned out, I had a ball cup on the rear hub that was REALLY tight(didn't notice it because it was the last thing I snapped on) and was causing the suspension on that side not to move as free...thusly causing the sway bar not to raise the suspension as much on that side.
After correcting that (by chucking the ball end into a rotary tool and spinning it with grease inside the ball cup) the sway bar was able to work equally on both sides while still having the bars being turned to the same degree.
So anyone else who was having this issue, it might be a good idea to check out the freedom in the rear suspension. It may not be a sway bar issue at all.
TLR 22...Tamiya F104...
Old 08-30-2005, 06:08 PM   #1455
w
t
f
this car is messing with me
I rebuilt the clutch 6 times trying to figure out what was wrong, everytime the clutch would lock up!
then all off a sudden the clutch started no locking up, now it spins freely with like .5mm of play
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
