Old 08-28-2005, 08:51 PM   #1396
rcrevolution's Avatar
Send a message via AIM to rcrevolution
see I dont know if my track has that much traction, isnt the orange better for all around?
rcrevolution is offline   Reply With Quote
Old 08-29-2005, 03:48 AM   #1397
RayJ's Avatar
Default rcrevolution.....clutch problems
I use the orange spring and flyweights with the brass weights just about eveywhere............ with no problems.
Clutch Fundamentals:
1) Make sure your clutch shoe itself slide up and down on the flywheel pins with absolutely NO BINDING. If the clutch shoe hangs up when it is pushed out on acceleration or deceleration it will throw the flyweights or cause them to jam. Solution...... Make sure you check that the clutch shoe slides up and down on the pins freely. If you have to......ream out the clutch shoe holes LIGHTLY with a drill bit. Just so it slides freely.
2) make sure you know how to check your endplay correctly. .3mm to .6mm is the correct endplay. Not enough endplay will cause the clutch to bog and overheat when the clutch heats up during running. This will also glaze over the clutch shoe.
3) Make sure you measure the clutch spring tension correctly. Also make your adjustments in small increments(quarter turns on the clutch nut) Tuning holes in the clutch bell are great for experienced tuners, but newbies should do it manually untill they really understand clutch adjustment. I don't know how new you are to this.
4) For the Mongoose the large Pressure plate works better than the stock plate. It has a larger surface area and rigidity. The larger surface area gives more area for flyweight travel and positive return.
RayJ is offline   Reply With Quote
Old 08-29-2005, 07:42 AM   #1398
so I need to use flyweights?
I cant just run the orange spring with no flyweights
Old 08-29-2005, 10:06 AM   #1399
Regional Moderator
Darkseid's Avatar
Originally Posted by rcrevolution
darkseid, get the part number from your manual and email rd logics, they have 99.9% of the parts, they just dont list them for some weird reason.
and as for the clutchbell
\dont try drilling it its hardened coated metal, we were drilling it with a diamond bit at 12K rpms and it didnt even scratch the damn thing.
I'll try emailing RD then and hope for some good news.
Seeing that you didn't haven't any luck drilling with your equipment either makes me not feel so bad about me not being able to do it with my low grade Wal*Mart stuff.
TLR 22...Tamiya F104...
Old 08-29-2005, 10:16 AM   #1400
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Just use the red spring with/out the inserts on the flyweights.
I think that your motor is not working propertly because it is not tuned right.
Walter Diaz
wad is offline   Reply With Quote
Old 08-29-2005, 10:20 AM   #1401
wad
wad's Avatar
If you can't get it, Kyosho V1R will fit.
Walter Diaz
Old 08-29-2005, 10:22 AM   #1402
wad
wad's Avatar
I have soo many questions about this car, its so new to me.
like
1) How do I adjust the height on this car? In the front and rear? is it all in the drool and shocks?
2) Are the front shocks suposed to be stiffer then the rear?
3) should I take out the brass flyweights in the clutch and run with a orange spring and no weights?
1- with the nut on the shock, just changing the tension of the springs
2- yes
3- no inserts on flyweight with red spring.
Walter Diaz
Old 08-29-2005, 10:34 AM   #1403
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
What type of conditions do you guys use the front spool? I'm thinking of getting one, but I wanna make sure it fits with the type of tracks I run on.
Uneke is offline   Reply With Quote
Old 08-29-2005, 10:45 AM   #1404
Send a message via MSN to pedal2thametal
hi guys.
a family member has trown away my g4 manual.
can i download it somewhere? doesnt mather if its the Team magic one or the mongoose.
pedal2thametal is offline   Reply With Quote
Old 08-29-2005, 10:45 AM   #1405
YBSLOW's Avatar
Default Solid Front Axle
Somewhere you need very little steering and a ton of brake.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-29-2005, 11:13 AM   #1406
wad are u positive the V1 clutch bell fits?
do you have a link to one and its price?
Old 08-29-2005, 11:18 AM   #1407
wad
wad's Avatar
I was replying to a question on front universals, v1 clutch and Mongoose are totally different, like night & day.
Walter Diaz
Old 08-29-2005, 11:25 AM   #1408
alrighty.
so my best bet is red spring no inserts? or should I go orange spring no inserts.
and are 3 racing parts decently strong? or are they very cheap in quality? because I saw a brake post and rear belt tensioner they make for $8
Old 08-29-2005, 11:29 AM   #1409
wad
wad's Avatar
alrighty.
Red spring with no inserts on flyweights.
Don't know about 3 racing stuff, I will get K-Factory stuff
Walter Diaz
Old 08-29-2005, 11:57 AM   #1410
charlesd's Avatar
I purchased the 3 Racing upper graphite front deck and the rear shock tower with aluminum stiffener. The quality is very good and i'm pleased with my purchase.
charlesd is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
