Old 08-26-2005, 09:09 PM   #1366
Send a message via AIM to goosein LV
Default goosey
just so happy to be a gooseman whats up WAD
goosein LV is offline   Reply With Quote
Old 08-26-2005, 09:10 PM   #1367
Default GOOSE
YOU GOING RACING THIS WEEKEND
Old 08-26-2005, 10:49 PM   #1368
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
I will be at rev this sunday
How is your goose doing?
Walter Diaz
wad is offline   Reply With Quote
Old 08-27-2005, 12:03 AM   #1369
Default goose
hey WAD my goose is doing pretty good took it apart after the WCNC found & fixed a bunch of things now im going to the track saturday for practice find out what adjustments are needed for the paris race hopefully i do a lot better the car actually ran good at that race if you dont make that race i will keep you informed on how it works out mongoose fever
Old 08-27-2005, 12:11 AM   #1370
Default goose
Old 08-27-2005, 12:35 AM   #1371
wad
wad's Avatar
Mongoose fever You too funny
Walter Diaz
Old 08-27-2005, 11:00 AM   #1372
Default goose
the goose is in
Old 08-27-2005, 11:51 AM   #1373
JABRONI's Avatar
Default What The !!!
Goosein,
You gotta get off the puter and get some laps in so you can tell me some hints on whats working or not.
In fact all of us might like to know what is working for you !!!!!
By the way, lets pit together again so we have a good source of help when crunch time comes around and the lineups show that some of us are in the same heats etc.....
The more geese in the flock, the better we can help each other out !!!!!
Scott
JABRONI is offline   Reply With Quote
Old 08-27-2005, 11:59 AM   #1374
Default goose
we are going to the track at about 2:30 to get some work in dont worry im all over it
Old 08-27-2005, 06:57 PM   #1375
rcrevolution's Avatar
Send a message via AIM to rcrevolution
hey guys im a fellow goose owner too. so plz help me
I came across a new problem today
my centax clutch outter portion will not spinn freely, it moves the flywheel too.
now I have since solved this problem, I got the centax clutch spinning super freely, when I spin it it spinds for like 3 secs freely.
and it has a little play back and forth, the play is very little, I can barely stick a sheet of paper through it.
Is this setting perfect? or the is the centax spinning too much or does it have too much play?
rcrevolution is offline   Reply With Quote
Old 08-27-2005, 08:02 PM   #1376
Motorman's Avatar
its to tight still you need it to float about .5 to .6 mm take more shims off the end behind the thrust bearing. If there all out put a few of the small ones on the end to space it out fatrher. if its as tight as you say when it heats up it will expand closing the clerance and the engine will bog and over heat.
this was probably your issue in the first place. use the spring to adjust the engagement point. it should not engage until you get off idle a ways.
set the needles where walter told you to and it will be close to start.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-27-2005, 09:16 PM   #1377
it got that play
and the centax spins freely
now I have another question while on the engine is the flywheel soposed to have absolutly no movement when u spin the centax? or is it always gonna show faint signs of moving?
Old 08-27-2005, 10:01 PM   #1378
Motorman's Avatar
it will always have a small amount due to clearance in the front bearing
Old 08-27-2005, 10:11 PM   #1379
so the flywheel will always move a tiny bit?
the centax spins freely that I know, Im gonan try it tomorrow
Old 08-28-2005, 02:19 AM   #1380
Registered User
xrcbuggy's Avatar
Hi guys, I think I am ready to get this car, but I have some questions. Does the new kit comes with the new streering or should I order the new streering #1480? What color clutch spring do I get with kit? What other necessary parts do I need to make it race worthy?
Thanks in advance for your input.
xrcbuggy is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
