Old 08-25-2005, 05:01 PM   #1351
Dragon's Avatar
Send a message via ICQ to Dragon
Originally Posted by daniz24
You are from Singapore? I think Rotor hobby carries almost all parts in stock. Correct?
Rotor is not cheap... online seems generally cheaper even after freight... furthermore, they don seem interested in getting the stuff i want... i.e. the rear shock tower....
+ their stocks are all VERY old...
Dragon is offline   Reply With Quote
Old 08-25-2005, 07:46 PM   #1352
Regional Moderator
Darkseid's Avatar
Originally Posted by Motorman
clutch spring is to soft go to orange. Just do it!
I've heard people saying this several times.
First-What's so wrong with the kit clutch spring. I did notice that it was much softer than the kit spring on my R40, but it seems to work fine. I've had some problems with my engine being a little too powerful on the low end and engaging a little too hard, so I guess the softer, smoother engagement of the kit spring seems perfect to me.
Second-If the kit spring is so bad, why don't they change it?
TLR 22...Tamiya F104...
Old 08-25-2005, 08:07 PM   #1353
YBSLOW's Avatar
Default kit spring
The kit spring was desiigned to be used with rubber tires. Every clutch on the market has alternate springs for different track conditions. The orange spring is good 90 percent of the time in my opinion. If the track is very lo-bit the red spring is fine. If the track has off the hook traction the yellow spring can be used. Clutch setup is a science all to itself and really comes down to driving style and personal preference.
The clutch spring will be changed in future kits. (i would bank on that).
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-25-2005, 08:39 PM   #1354
Regional Moderator
daniz24's Avatar
yes their stocks are very old. I used to order from them for my shop, but later they never updated their stock list so I went to other dealer
daniz24 is offline   Reply With Quote
Old 08-25-2005, 08:47 PM   #1355
rcrevolution's Avatar
Send a message via AIM to rcrevolution
but is it the spring that is making my engine bogs so much? or is it a rich LSN?
rcrevolution is offline   Reply With Quote
Old 08-25-2005, 09:44 PM   #1356
Send a message via AIM to goosein LV
Default gooseman
as long as there will be future kits im happy more gooses more gooses more gooses
goosein LV is offline   Reply With Quote
Old 08-25-2005, 10:52 PM   #1357
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Just tight the spring until it doesn't engage, then loose it 1/2 turn
Walter Diaz
wad is offline   Reply With Quote
Old 08-25-2005, 11:54 PM   #1358
Dragon's Avatar
Other dealer? is there another in sg?
Old 08-26-2005, 02:02 AM   #1359
nickko's Avatar
Send a message via MSN to nickko
Rotor do order new parts from us. Please check again. Thanks.
nickko is offline   Reply With Quote
Old 08-26-2005, 03:14 AM   #1360
Dragon's Avatar
http://rctech.net/forum/showthread.p...=1#post1777773
Guys... me G4 needs help desperately... me on the verge of crying.... i am stressed senseless....
Old 08-26-2005, 02:31 PM   #1361
i fixed it
it doesnt bog I had to richen the needles a bit
Old 08-26-2005, 06:24 PM   #1362
alright i am having the same problem
I took a pic of my centax spring and idle gap to see if u guys think something is off.
should the centax be tightened more?
Old 08-26-2005, 07:00 PM   #1363
wad
wad's Avatar
Is that a NOVAROSSI carb?
Walter Diaz
Old 08-26-2005, 07:14 PM   #1364
wad
wad's Avatar
Yes, it is. I saw your previous post.
Nothing wrong with the clutch. Your top neddle is way too lean, try this.
Close the bottom neddle completely, then open it 3 1/2 turns.
Close the top neddle and then open it 6 turns. Try to start the engine and go full throutle. If the motor doesn't want to start or flame out when you try to go full throutle then start leaning it 1/4 turn at the time (top neddle only). When the engine starts and you go full throutle it will be way too rich. Start leaning it out until you heard a clear sound from the engine. You may want to lean the bottom neddle but no more than 1/2 turn. Hope this help
Walter Diaz
Old 08-26-2005, 08:19 PM   #1365
yeah its a novarossi carb cause its a novarossi engine
it hauls ass when its not acting up, I need to get it tuned tough
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
