Old 08-22-2005, 06:15 PM   #1306
Regional Moderator
daniz24's Avatar
Originally Posted by JABRONI
(Dogbone to a shorter one (52-53mm)
Daniz,
I'm curious as to which type or style of rear dogbone you are utilizing
Brand ? Part #
I personally just buffed off the end of round surface and It worked just fine, however, I am soon needing a replacement set and would rather get something that fits straight out of the box.
It may have been posted somwhere else, but I do not see it as of now.
Scott
I'm using Kyosho #VZ014 52mm dogbone (1 pair)
daniz24 is offline   Reply With Quote
Old 08-22-2005, 06:21 PM   #1307
Regional Moderator
daniz24's Avatar
Originally Posted by rodneybarrett
A couple of questions:
- One of my main issues with the car before was the clutch system. Just couldn't seem to get it right. and yes, I did have the updated pieces. Does the new Version 2 (UFO clutch) correct this? I sure hope so. If so, I will order it right away.
- Any more news on the new steering system?
- Are the new low friction belts more durable than the gold ones?
thanks.
What clutch issue. Yes, you can try the new UFO clutch with yellow clutch spring for harder acceleration. Yes, the new belts are very good
Old 08-22-2005, 07:46 PM   #1308
Send a message via AIM to goosein LV
Default gooserecker
the mongoose is a beast to be reconed with i also stayed at holliday inn express last night did i metion geico
goosein LV is offline   Reply With Quote
Old 08-22-2005, 07:51 PM   #1309
Default gooseville
did i mention HR PUFF N STUFF IS HAVING A GET TOGETHER dont be late
or witchie pooh will have a fit goose is ooohweeee so happy party all the time party all the time my mongoose & i ARE GOING to the movies to see goosein lv cya later
Old 08-22-2005, 08:01 PM   #1310
reactor's Avatar
Originally Posted by daniz24
The front ride height is 5.5mm and rear is 6.5mm for the 45 minutes final. And no, that is not the TM orange spring. I'm using Yokomo SS complete shock set with Rayspeed Red Spring. I think it's around between TM Purple or TM light green spring.
took off the orange springs and put back the stock silver one which is 1.6, adjusted the droop at 4mm rear and 2 on the front, i ended up 6 on front and 6.5 at rear height that is well suited in our tracks the car performs well and i have more adjustment with the spring, my settings have preload on it and still have the option to lower the ride to 4-3 mm.Thanks Dhani!
Motorman- the upstop is non functional i did took it off.
reactor is offline   Reply With Quote
Old 08-22-2005, 09:04 PM   #1311
Regional Moderator
daniz24's Avatar
The stock silver spring is good, but the purple is better. Do you already try how's the minimum ride height with the purple spring?
Old 08-22-2005, 09:31 PM   #1312
Trader Rating: 44 (100%+)
what are the part numbers for:
1. yellow clutch spring
2. orange clutch spring
3. new black belts
the UFO pics i've seen all seems to have red springs?
wyl03 is offline   Reply With Quote
Old 08-23-2005, 04:19 AM   #1313
reactor's Avatar
I have no idea with the purple spring, havent tried it yet, if its ok with you can you pm me the settings you commonly use? we have a medium traction circuit here and mostly where i practice, i dont compete i just earn good practice times and experience with right settings, i just run my car and improve driving skills for past time but looking forward to compete one day.
i like to work on better grip, good cornering and stable straight line speed,id like to see how you dial your car.
Thanks for your time, by the way im in Manila Philippines
Old 08-23-2005, 06:32 AM   #1314
Motorman's Avatar
reactor take the rear bar off, hang Purples on the rear and Aqua on the front with 60 wt shock oil front and rear. 2 degrees rear toe.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-23-2005, 03:43 PM   #1315
JABRONI's Avatar
Default PART #'S
3. new black belts
This link will show you the Clutch Springs:
http://www.rdlogics.com/cgi-bin/cate...umb=&&start=12
Yellow Spring K1410-8
Orange Spring K1410-7
Rear Belt K1493
Side Belt K1494
Front Belt K1495
http://www.rdlogics.com/cgi-bin/cate...umb=&&start=84
JABRONI is offline   Reply With Quote
Old 08-23-2005, 04:02 PM   #1316
Derby Bros Racing's Avatar
hey scotty!
how was compton?
Derby Bros Racing is offline   Reply With Quote
Old 08-23-2005, 04:17 PM   #1317
JABRONI's Avatar
Default Crystal Park
Awesome !!!!!!!
One of my funnest races, seemed like slow motion, and I could see lines and lanes like never before. Starting to feel the force ROFL !!!
Couple things happened:
Once on Back, Big Time loss and
Unfortunately I lost my rear belt with about 6 laps to go or I probably would have been close to Bumping, maybe even scoring some Metal to take home !!!!
Other than that the car was great, and I am starting plans for the Ron Paris Race in October, should be a good turnout and alot of fun !!!!
Scott
Old 08-23-2005, 04:22 PM   #1318
FORCE
hmmmmm
Old 08-23-2005, 10:27 PM   #1319
Hey I am really looking to get one of these over another R40. I know that I will be buying the UFO and F/R spools, but I want to know what are the NEEDED option parts for this car? More towards endurance and peace of mind.
WingZero is offline   Reply With Quote
Old 08-24-2005, 06:12 AM   #1320
reactor's Avatar
newbie question--why was the stock oil have 600wt? what was the effect? and how does the 60wt performs?
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
