Old 08-22-2005, 08:17 AM   #1291
Regional Moderator
daniz24's Avatar
Originally Posted by reactor
also take a look at Dhanis car raced in Futaba Cup Indonesia, im observing the spacer dialed on the front shocks i would guess the ride height is somewhere above 5mm, with the rear i cant see clearly how it was set up, he uses the same orange springs.
The front ride height is 5.5mm and rear is 6.5mm for the 45 minutes final. And no, that is not the TM orange spring. I'm using Yokomo SS complete shock set with Rayspeed Red Spring. I think it's around between TM Purple or TM light green spring.
daniz24 is offline   Reply With Quote
Old 08-22-2005, 10:06 AM   #1292
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by JABRONI
I am pretty sure the results will be posted tomorrow, however, I know that Walter was in the "A", Brad (YBSLOW) just missed it by a fraction and was in the "B", I was in the "C" and others were throughout thevarious mains trying there best !!!!!
Goosein LV was alot of fun, and I'm sure he learned alot from what we trying to help him with , and other than an unfortunate rear end job on the first lap would have done very well.
Brad had some bad luck after taking the whole shot in the "B" and had created a substantial lead until some problems developed that I will let him recap on later.
I had two rear belts go away over the weekend , so I shave to check my alignment or wear patterns on the belts to see what the problem was, Unfortunately it went away with about 6 laps left which left me with only two wheel drive.
All in all a great weekend in Cali at a track with alot of memories of a track that has helped produce some very fast racers that currently race at a competitive national level.
The Cars felt great and performed well, setups for this track will probably not be developed because the track is going to change in design in about a month.
I had some problems in the main also, I started too rich for the main causing a flame out after 4 minutes, then we lean the motor and was better but I was way in the back, then I ran out againg on the second pit and had to start pitting every 4 minutes. Anyways, I managed to get 4th place at the end, so that was good for me with all the problems and that was my third time on that track.
Brad had a great car, his lap times were enough to make the A main on qualifiers but there is always a little luck needed, and in the main he were leading until again the luck wasn't with him.
Hopefully we can fix the problems and do better next time.
Walter Diaz
wad is offline   Reply With Quote
Old 08-22-2005, 10:07 AM   #1293
JABRONI's Avatar
Default DANIZ24
(Dogbone to a shorter one (52-53mm)
Daniz,
I'm curious as to which type or style of rear dogbone you are utilizing
Brand ? Part #
I personally just buffed off the end of round surface and It worked just fine, however, I am soon needing a replacement set and would rather get something that fits straight out of the box.
It may have been posted somwhere else, but I do not see it as of now.
Scott
JABRONI is offline   Reply With Quote
Old 08-22-2005, 10:27 AM   #1294
Send a message via AIM to goosein LV
Default goose
we will get the next race it will be 1 big goose party
goosein LV is offline   Reply With Quote
Old 08-22-2005, 10:29 AM   #1295
Default go go goose
ITS ALL ABOUT THE GOOSE QUACK QUACK QUACK
Old 08-22-2005, 10:35 AM   #1296
YBSLOW's Avatar
Default GOOSE IN LV
You Quack me up!
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-22-2005, 10:51 AM   #1297
mike jones's Avatar
yb slow what happen to you in 1/8th this weekend end you left before i got to talk to you
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 08-22-2005, 11:26 AM   #1298
YBSLOW's Avatar
Default Long story short
Well my car was too rich at the start, started 4th got ass packed by Danny Alvarado on the first lap pulling the upper arm out of the rear upright coming around the light pole on the first lap, I tried to limp into the pits and somehow got hit head on knocking off a front shock and steering tie-rod. Finally got too the pits and fixed most of this stuff pretty quickly. After a couple of more pit stops to lean the motor I came in front of the drivers stand full throttle and the car never let off and flew thru the metal strap and onto the back straight to hit the concrete curb on the back straight. The body came off along with the front shocks, front outdrives, body mount, spindles, and all but the right rear tire. What a shame the car ran a lot of 14.5's in qualifying and I thought the car would be even better for the main. Oh well nothing a couple hundred bucks can't cure.
Later!
Brad
YBSLOW Racing
Old 08-22-2005, 12:04 PM   #1299
mike jones's Avatar
so danny did take you out we wern't sure or not he says he's sorry for the take out and you can have your body back
Old 08-22-2005, 12:24 PM   #1300
YBSLOW's Avatar
Default It's cool.
It is cool. He can keep at as sovenier....LOL! Just trash it it will only bring me back bad memories.
YBSLOW Racing
Old 08-22-2005, 12:29 PM   #1301
mike jones's Avatar
no problem, you sure it was danny because dannys body was yellow and red not pink and black he change hes body before the race
Old 08-22-2005, 03:36 PM   #1302
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default A little help here please ...
Hi guys,
Just received an invitation to race this weekend a OVAL RACE with my G4/Mongoose ...
All i know (the race is next weekend) about the track is that is 170mts total length and have on the 2 curves a 20 angle to the inside ...
Now, any advice about the setup for this ?, neves run on oval tracks ... the bodies allowed will be touring type (200mm nitro IFMAR Approved bodies). The track its medium grip.
thanks in advance ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-22-2005, 04:18 PM   #1303
Trader Rating: 49 (100%+)
Default I'm Back
Well....I couldn't stand it any longer. I had recently gotten out of the Mongoose/G4 and went to the Kyosho RRR. After 2 months of trying to get the RRR to corner like the Mongoose/G4, I'm coming back.
A couple of questions:
- One of my main issues with the car before was the clutch system. Just couldn't seem to get it right. and yes, I did have the updated pieces. Does the new Version 2 (UFO clutch) correct this? I sure hope so. If so, I will order it right away.
- Any more news on the new steering system?
- Are the new low friction belts more durable than the gold ones?
thanks.
rodneybarrett is offline   Reply With Quote
Old 08-22-2005, 04:34 PM   #1304
wad
wad's Avatar
thanks.
The new clutch UFO works really good, you should have no more problem with it. The new black belts are really good also, better than the old ones.
Walter Diaz
Old 08-22-2005, 06:13 PM   #1305
Motorman's Avatar
Rodney get the orange clutch spring to to go with the UFO
Just here to give the world grief.
Motorman is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
