Old 08-18-2005, 08:29 AM   #1246
Dragon's Avatar
Send a message via ICQ to Dragon
i think i have seen AAAs that are 1050... anyone seen higher than that?
Dragon is offline   Reply With Quote
Old 08-18-2005, 10:42 AM   #1247
charlesd's Avatar
Quick question about the ufo clutch: Where do you find one ?
charlesd is offline   Reply With Quote
Old 08-18-2005, 11:12 AM   #1248
YBSLOW's Avatar
Default RDLogics.com
RDLogics.com
This clutch is alot different from previous clutches.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 08-18-2005, 11:14 AM   #1249
YBSLOW's Avatar
Originally Posted by JABRONI
Should be quite a few Gooses flying aroung in So Cal this weekend !!!!!!
Last time on the old layout !!!!!
Should be a blast !!!!!!
Jabroni your avatar sucks! Literally!
YBSLOW Racing
Old 08-18-2005, 12:12 PM   #1250
Regional Moderator
Darkseid's Avatar
Originally Posted by Dragon
BTW guys, what do u use for your receiver battery? what i have at my lhs are the team magic 650 mini receivers... are those enough? doesnt seem they would last long tho...
I built mine using 850mah cells i bought at Wal*Mart.
TLR 22...Tamiya F104...
Old 08-18-2005, 03:21 PM   #1251
Motorman's Avatar
I'VE BEEN USING GP850"S they charge about 975 to 1025
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-18-2005, 03:47 PM   #1252
JABRONI's Avatar
Allright, How about this one !!!!!
JABRONI is offline   Reply With Quote
Old 08-18-2005, 03:55 PM   #1253
Derby Bros Racing's Avatar
Derby Bros Racing is offline   Reply With Quote
Old 08-18-2005, 03:55 PM   #1254
YBSLOW's Avatar
Default much better!
much better!
YBSLOW Racing
Old 08-18-2005, 04:34 PM   #1255
Originally Posted by Motorman
The UFO is radically different than the origional or even the s class clutch.
to start with the flywheel is slightly larger and heavier which allows the engine to idle smoother during pitstops and carry some off throttle inertia which is not bad for corner speed. It is deeper so the flyweights sit deep in the flywheel and the angle on the sides of the flywheel where the flyweights sit is a higher angle which makes the flyweights react quicker in engagement and disengagement for much better response and more consistant response. the pressure plate has an odd shape (looks like an upside down UFO, hence the name)that guides the flyweights straight so they don't cock against the flywheel pins, this allows the clutch shoe to hit the clutch bell straight on every time.(the flywheel pins are pressed into the flywheel perfectly straight so the disc won't hang up, they have to be more precision than a standard setup) The flyweights have 2 weights for tunability and the bell has three holes for venting directly in line with the clutch shoe contact patch (IE like cross drilled brake rotors) sealed clutch bell bearings come with it and they keep the bearings cleaner. and the best part is that when it hits it locks up and stays hooked hard everytime. The kit comes with the red spring but the orange option spring is the one to use set 1.5 threads below flush on adjustment to start with the bell shimmed to .6MM end play.
Unfortunatly everything on the system is all by itself even the clutch bell as it is slightly larger so only UFO bells will work with it. You have to use the entire system as a singular unit or it won't stack up right.
It would not suprise me to see other manufacturers follow suit on the UFO pressure plate design
Just so you guys know I have an active dialogue with TM regularly and they are listening. I am pushing them to do something better about the S class spur material. Its OK but needs to improve. There are many other things but I can't talk about those things yet.
Hi Motorman,
Does the UFO clutch work with the stock or the S class pinions?
Thanks.
Michael
cvccsi is offline   Reply With Quote
Old 08-18-2005, 04:36 PM   #1256
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by cvccsi
Hi Motorman,
Thanks.
Michael
With both.
Walter Diaz
wad is offline   Reply With Quote
Old 08-18-2005, 05:35 PM   #1257
rcrevolution's Avatar
Send a message via AIM to rcrevolution
guys check this out tell me what u think
http://www.rcpics.net/view_single.php?medid=63403
rcrevolution is offline   Reply With Quote
Old 08-18-2005, 05:52 PM   #1258
Send a message via AIM to goosein LV
Default DR goose is in
hello everyone DR goose is in what seems to be the problem is your goose sick lifeless well a little nitro challenge will cure this problem cya sat.& sun.
goosein LV is offline   Reply With Quote
Old 08-18-2005, 07:10 PM   #1259
fordman500's Avatar
You what goose half the time I dont know what you're saying
Anyway have a great time and remeber around the wrecks,around
fordman500 is offline   Reply With Quote
Old 08-18-2005, 07:46 PM   #1260
Dragon's Avatar
if we were to build our own batt packs, what do we use to connect the batteries together?
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
