Old 08-17-2005, 03:19 PM   #1231
Motorman's Avatar
Fisher
RD has universals
I highly recommend the UFO
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 08-17-2005, 03:24 PM   #1232
fordman500's Avatar
Motorman,what are the advantages with the UFO?I do know its kind of expensive.
fordman500 is offline   Reply With Quote
Old 08-17-2005, 07:47 PM   #1233
Motorman's Avatar
The UFO is radically different than the origional or even the s class clutch.
to start with the flywheel is slightly larger and heavier which allows the engine to idle smoother during pitstops and carry some off throttle inertia which is not bad for corner speed. It is deeper so the flyweights sit deep in the flywheel and the angle on the sides of the flywheel where the flyweights sit is a higher angle which makes the flyweights react quicker in engagement and disengagement for much better response and more consistant response. the pressure plate has an odd shape (looks like an upside down UFO, hence the name)that guides the flyweights straight so they don't cock against the flywheel pins, this allows the clutch shoe to hit the clutch bell straight on every time.(the flywheel pins are pressed into the flywheel perfectly straight so the disc won't hang up, they have to be more precision than a standard setup) The flyweights have 2 weights for tunability and the bell has three holes for venting directly in line with the clutch shoe contact patch (IE like cross drilled brake rotors) sealed clutch bell bearings come with it and they keep the bearings cleaner. and the best part is that when it hits it locks up and stays hooked hard everytime. The kit comes with the red spring but the orange option spring is the one to use set 1.5 threads below flush on adjustment to start with the bell shimmed to .6MM end play.
Unfortunatly everything on the system is all by itself even the clutch bell as it is slightly larger so only UFO bells will work with it. You have to use the entire system as a singular unit or it won't stack up right.
It would not suprise me to see other manufacturers follow suit on the UFO pressure plate design
Just so you guys know I have an active dialogue with TM regularly and they are listening. I am pushing them to do something better about the S class spur material. Its OK but needs to improve. There are many other things but I can't talk about those things yet.
Old 08-17-2005, 07:49 PM   #1234
I know i asked this before, but I just moved to Fort Myers and I am dying to run my goose. I bought it in June when I was still in Indiana, and with all teh moving I haven't even got a chance to breack in the engine. My question is... when are they going to be racing at the Ft. Myers track this summer and fall. I need to race my Goose!
jnims29 is offline   Reply With Quote
Old 08-17-2005, 07:54 PM   #1235
Motorman's Avatar
you need to quiz Mike Myers or J Pilone they would know what is up in FLA. they both post here so find a post from them and drop them an Email or PM
Old 08-17-2005, 07:56 PM   #1236
fordman500's Avatar
Thanks for the explanation Motorman!!
Old 08-17-2005, 09:09 PM   #1237
JABRONI's Avatar
Default West Coast Nitro Challenge
Should be quite a few Gooses flying aroung in So Cal this weekend !!!!!!
Last time on the old layout !!!!!
Should be a blast !!!!!!
JABRONI is offline   Reply With Quote
Old 08-17-2005, 11:26 PM   #1238
Send a message via AIM to goosein LV
Default goose
its a bird its a plane its GOOOSE ooohweeee
goosein LV is offline   Reply With Quote
Old 08-18-2005, 02:17 AM   #1239
Dragon's Avatar
Send a message via ICQ to Dragon
i still wonder what its called a mongoose.... is it because of the bumber top?
Dragon is offline   Reply With Quote
Old 08-18-2005, 03:42 AM   #1240
Dragon's Avatar
BTW guys, what do u use for your receiver battery? what i have at my lhs are the team magic 650 mini receivers... are those enough? doesnt seem they would last long tho...
Old 08-18-2005, 04:09 AM   #1241
RayJ's Avatar
Default SoCal Race..
Good luck to YBSLOW and Jabroni and other goose drivers in SoCal this weekend!! Brad your due for the show!!! Good Luck!!
RayJ is offline   Reply With Quote
Old 08-18-2005, 04:17 AM   #1242
Regional Moderator
daniz24's Avatar
I'm using AAA 850mAh hump pack. I think 650 can't stand for 45 minutes final.
daniz24 is offline   Reply With Quote
Old 08-18-2005, 05:36 AM   #1243
Depends on whether or not you are running digital servos.
Old 08-18-2005, 05:41 AM   #1244
Dragon's Avatar
oh man... but i am using digital servos... so min i should get 850? which should last 45min?
Old 08-18-2005, 07:09 AM   #1245
That would be your safest bet.
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
