Old 08-13-2005, 08:11 PM   #1216
rcrevolution's Avatar
Send a message via AIM to rcrevolution
im trying to think whats wrong
novarossi doesnt give out factory settings, but im at 3 turns open on hsn, 4 open on lsn, and mid range needle is flush with carb body.
umm glow plug still burns nicely and it slightly grey.
but it doesnt start when its warm.
rcrevolution is offline   Reply With Quote
Old 08-13-2005, 08:23 PM   #1217
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
Not sure about needle settings. I don't have my car here with me to check. Maybe someone else can help you with that.
Uneke is offline   Reply With Quote
Old 08-13-2005, 08:56 PM   #1218
Rapid Roy's Avatar
Make sure that the glow plug is lighting up all the way to the end. If the 1st coil isn't lighting up, you need a new plug. If its okay, remove the plug and wipe it off. With the plug out, turn the car upside down to drain any fuel in the cylinder. Now put the car on the starter box and spin the motor a couple of times. Now reinstall the plug and try to start. If it still doesn't start, pinch the fuel line while you are trying to start it. If it starts, your too rich, lean it out a little. It sounds like its a bit rich though.
Rapid Roy is offline   Reply With Quote
Old 08-13-2005, 09:53 PM   #1219
anyone know good replacemnt plugs for nova rossis?
Old 08-13-2005, 10:45 PM   #1220
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by Darkseid
Alright guys, I've got a question.
My rear sway bar seems to be acting unevenly. Both the cup side and ball side are perfectly flat. But for some reason, when I compress the suspension on the cup side(left side), the other suspension compresses a little more than when I do the same with the ball side(right side). I hope that makes sense.
What I ended up doing was rotating the cup side bar to about a 15 degree angle. This kept the reaction the same for the ball side while the cup side (left side) suspension is being compressed. BUT, now when I compress the ball side(right side) suspension, the left suspension reacts the same as the right.
So basically now both sides react equally to opposite side suspension compression, but I have one bar level while the other is angled slightly.
My question is, is this the correct way to equalize the sides, or is there a better way to achieve this?
I think that you are in the correct way, it sounds normal to me
Walter Diaz
wad is offline   Reply With Quote
Old 08-14-2005, 03:55 AM   #1221
RayJ's Avatar
Default Rear Sway Bay
Darkseid you are correct in your observations with the rear sway bar. I ended up disconnecting mine because the car felt tweaked everytime I drove it. Brad kept wondering why his car was tweaked, and after some suspension compressions discovered the "unequal" action. The dual adjust bar is a little better and you can get it to work properly like you did.
RayJ is offline   Reply With Quote
Old 08-14-2005, 04:13 AM   #1222
Regional Moderator
Darkseid's Avatar
Thanks guys, I was hoping that was right, but it doesn't hurt to get some reassurace.
TLR 22...Tamiya F104...
Old 08-14-2005, 01:28 PM   #1223
hey guys its working now, i did what someone said pinch the fuel line while starting and now it starts up right away.
im getting temps at about 210 during break in first tank, is this ok? or too hot
Old 08-15-2005, 02:59 PM   #1224
wad
wad's Avatar
Default fordman500
Was nice to meet you!!
Let me know if I can help you out with anything else, by the way, what motor did you have in your car?
Walter Diaz
Old 08-15-2005, 04:35 PM   #1225
me ? i have a nova rossi RS .12 3-port
that thegine is already faster then my .12cv-rx at only 25% throttle and its not broken in yet
Old 08-16-2005, 02:10 AM   #1226
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
O'Donnell plugs work well in Nova engines..
Dennis: I have time to experiment. Where can I get universals for the car?? The rest of my car is very ready to go.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-16-2005, 06:17 AM   #1227
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I cant get nova plugs down here so im using Team Orion ones on my Turbo and Non Turbo engines ... and they seems to work great !!
cya!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 08-16-2005, 10:34 PM   #1228
Send a message via Yahoo to racermac71
complete mongoose g4 with any and all options, electronics, 3 pipes, enough parts too build 2 more........ most are still nip, all gears pinions and spurs 3 clutches, opional pullys, new belts on car with more new belts in package, spring sets, extra shocks, way too much too list........... everything exept a motor and reciever.......... do have a new evo 3 that can go with it for an extra 250, still sealed from factory never opened. car is in perfect condition with 4 new eligi tires on it, also has 3 new style steering systems along with 1 or 2 of the old ones, a arms composite pivot balls, 4 mm chassis, graphite everything............ i couldnt guess at whats invested but id say 3,000 or so, make offer. starter box and glow ignitor go with it
racermac71 is offline   Reply With Quote
Old 08-16-2005, 11:11 PM   #1229
not sure what its all worth but might trade everything for 2 team much more chargers, roughly 350 too 400
Old 08-17-2005, 11:56 AM   #1230
fordman500's Avatar
Goose,heres the link for Starting Grid.
http://www.rc-racing.com/cgi-bin/bt
fordman500 is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
