Old 08-07-2005, 11:29 PM   #1126
Regional Moderator
daniz24's Avatar
Oops sorry... I just read what you meant is the silver shock spring.
daniz24 is offline   Reply With Quote
Old 08-07-2005, 11:43 PM   #1127
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by fordman500
OK I have some questions.Im finally done with assembly and Im breaking in my motor.Heres the problem Im having.First, the gears spin but the tires do not,even at high RPM's.The second problem Im having is that the blue pinion that comes with the kit keeps coming off the clutch bell when they are spinning.BTW Im using a ball diff in the rear.Any help would be appreciated.
First problem, either the chutch spring is too tight or the end play is too much.
Second problem, your pinion is not tight enough.
Third problem wasn't mentined and is not affecting the previous ones, TAKE THAT DIFF OUT OF YOUR CAR PLEASE!! LOL
If you going to REV this weekend, show me your car and I will set everything up for you
Walter Diaz
wad is offline   Reply With Quote
Old 08-08-2005, 01:10 AM   #1128
Z00M's Avatar
Trader Rating: 15 (100%+)
What happens when someone new turns on their radio gear...
First of all, you go to the track thinking your car is ready to turn some good laps...
And so you put it out for a few practise laps before you nominate and get racing. What you don't expect is a newby with the same frequency to get his stuff out and try to fire his car up in the pits, radio included. And so I spear off into the concrete curb at full throttle...
and the fuel tank is smashed, the motor snapped a rod when it moved forward and stripped the gears and then was free revving.
So until I get a job, my 'goose' is off the road. It's kinda been a tough couple of months and now my hobby is out the window too.
sigh.
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-08-2005, 01:23 AM   #1129
wad
wad's Avatar
Too bad to heard that
To fix that problem, they made Spektrum now, but guess what!! they glitch, so we are on the same problem again. Hopefully some company do something about this.
Walter Diaz
Old 08-08-2005, 03:22 AM   #1130
Bundy_Bear's Avatar
sigh.
ZOOM:
Sorry to see this happen to you dude... I only know to well how hard it is too this hobby on a non existent budget, let alone have something like this happen
Head down you'll pull through dude... you could always have a year off like i did:S
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-08-2005, 05:37 AM   #1131
Dragon's Avatar
Send a message via ICQ to Dragon
Originally Posted by wyl03
heat up the plastic servo arm.
you can use a lighter.
gently heat it up.
makes it easier to bend the servo arm without breaking it!
oh .. don't heat up too long, or you'll melt it!
Originally Posted by Sparx
Some Futaba servos has that problem, the 9550 is a perfect fit though. To solve the problem with the servo arm hitting the bulkhead, heat up the servo horn and bend it so it's free, you may have to grind some material off the cup too.
WHAT????
OMG... And i thought i positioned something wrong somewhere... crap... I was like staring at it for like 5 hours... even dreamt of it while sleeping...
ARRRrrgGGgghhhh...
Thanks for the tips... will do that.
Dragon is offline   Reply With Quote
Old 08-08-2005, 02:31 PM   #1132
fordman500's Avatar
Thanks Walter
Would you have time to look at it for me?I mean Im sure youll be busy racing.If you could find the time I would appreciate it.How will I find you?
Lastly the diff stays.Im not now or have ever been a fan of gear diffs.
fordman500 is offline   Reply With Quote
Old 08-08-2005, 03:34 PM   #1133
Dreddlox's Avatar
Hey Zoom I feel your pain. The same thing happened to me yesterday. All day long everything was good. Then 4 of us line up for a 10 lap shoot out some *$#%# on the side playing with his truck turns on his radio. I watch my Goose go full tilt head first into the curb, goes about 4 feet in the air then done. I have'nt even opened the engine yet. When I was done taking inventory of all the parts I need I was already looking at the price of a new kit. Luckily the electronics are still working. There is thrill in victory and certainly lots of agony in defeat.
Dreddlox is offline   Reply With Quote
Old 08-08-2005, 03:51 PM   #1134
wad
wad's Avatar
Thanks Walter
There is always time to help
Is easy to find me, I'm the only person who wears a MONGOOSE t-shirt (either black or yellow), see you this weekend
Walter Diaz
Old 08-08-2005, 04:06 PM   #1135
fordman500's Avatar
I look forward to meeting you.Thanks
Old 08-08-2005, 04:29 PM   #1136
Slotmachine's Avatar
Send a message via MSN to Slotmachine
Mt MTX 3 went into a curb for the same reason last week. I spent $170.00 to fix it, no electronics, chassie or top plate, or engine they all survived. Basically plastic parts 1 shock and a pipe, these Mtx3`s are tough!
HOBBYWING NORTH AMERICA /FALCON SEKIDO/ TEKNO RC TEAM/VBC Racing America/VP-PRO RACING TIRES/2010 R.O.A.R. VTA National Champion Driving a T2R PRO/NANO-TECH Batteries Paul Rush
Slotmachine is offline   Reply With Quote
Old 08-08-2005, 05:15 PM   #1137
afm
afm's Avatar
how does the standard silver shock springs that come with the kit rank when compared to the other coloured springs? where do they fit?
harder or softer and relative to which?
tm gray 1.9mm 52.0 lb/in
tm orange 1.8mm 41.5 lb/in
tm blue 1.7mm 31.0 lb/in
tm aqua 1.6mm 26.0 lb/in
tm silver kit stock 26.0 lb/in
tm purple 1.5mm 20.0 lb/in
tm pink 1.4mm 17.0 lb/in
tm fuccia 1.3mm 13.5 lb/in
tm green 1.2mm 11.0 lb/in
afm
afm is offline   Reply With Quote
Old 08-08-2005, 05:32 PM   #1138
Dragon's Avatar
Can Fail safe systems lock down the car when it detects double frequencies??
Becareful... its the chinese Ghost month...
Old 08-08-2005, 05:56 PM   #1139
Trader Rating: 44 (100%+)
afm
thanks AFM.
seeing that the silver kit is right smack in the middle of the range, what springs do u commonly use?
thin (gray) for bumpy tracks/low traction and thick (green) for smooth tracks/high bite?
wyl03 is offline   Reply With Quote
Old 08-08-2005, 06:09 PM   #1140
Z00M's Avatar
Originally Posted by Dragon
WHAT????
ARRRrrgGGgghhhh...
There's no need to melt anything. Here is a pic of how the servo and servo arm should be mounted if it's not a low profile jobbie. (Keep in mind this is after my big hit so the servo arm is touching the bulkhead, but it doesn't when the chassis if flat )
XRAY XB4
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
