Old 08-07-2005, 01:00 PM   #1111
Regional Moderator
Darkseid's Avatar
Default Parts ordering
Alright, I'm about to fill up my parts bag for this car and I got a huge question?
Where the heck are the kit spec parts???
I looked in the "Mongoose and Spare parts" section on RDLogics' site and after seeing like one page of regular parts, its all hop up stuff.
Do you have to call to order the kit spec replacement parts?
TLR 22...Tamiya F104...
Old 08-07-2005, 01:18 PM   #1112
Dreddlox's Avatar
Call up or send them and e-mail, there always quik to respond. You can check http://www.brooklynhobbies.com/, They cary all the parts too.
Dreddlox is offline   Reply With Quote
Old 08-07-2005, 01:33 PM   #1113
Regional Moderator
Darkseid's Avatar
Thanks.
Old 08-07-2005, 05:10 PM   #1114
fordman500's Avatar
OK I have some questions.Im finally done with assembly and Im breaking in my motor.Heres the problem Im having.First, the gears spin but the tires do not,even at high RPM's.The second problem Im having is that the blue pinion that comes with the kit keeps coming off the clutch bell when they are spinning.BTW Im using a ball diff in the rear.Any help would be appreciated.
fordman500 is offline   Reply With Quote
Old 08-07-2005, 05:18 PM   #1115
Dragon's Avatar
Send a message via ICQ to Dragon
Hey guys, does anyone have any problems installing the steering servo?
Mine are futabas, and it seems like the throttle was a perfect fit into the slot, touching the receiver in stock position. However, the steering servo seems to far in front, with the ball stud touching the front bulkhead! And there is no more shifting back! as the servo's ass is already almost touching the throttle servo! With just enough spacing between them for the throttle servo's wire!
And experienced ones who encountered this before?
Dragon is offline   Reply With Quote
Old 08-07-2005, 05:22 PM   #1116
Send a message via AIM to goosein LV
Default goose
hey david what did you do to it
goosein LV is offline   Reply With Quote
Old 08-07-2005, 05:42 PM   #1117
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Dragon >
Some Futaba servos has that problem, the 9550 is a perfect fit though. To solve the problem with the servo arm hitting the bulkhead, heat up the servo horn and bend it so it's free, you may have to grind some material off the cup too.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 08-07-2005, 06:07 PM   #1118
Trader Rating: 44 (100%+)
Originally Posted by Sparx
Dragon >
heat up the plastic servo arm.
you can use a lighter.
gently heat it up.
makes it easier to bend the servo arm without breaking it!
oh .. don't heat up too long, or you'll melt it!
wyl03 is offline   Reply With Quote
Old 08-07-2005, 06:29 PM   #1119
Regional Moderator
daniz24's Avatar
If you want I can give you the K-Factory and spare parts list. I believe Team Magic and RDLogics share same parts number.
daniz24 is offline   Reply With Quote
Old 08-07-2005, 06:50 PM   #1120
Dreddlox's Avatar
I had problems fitting the steering servo in my Mongoose also. Use the spacers that they provide with the kit and shift the servo toward the front of the car and mount the ball stud on the back side of the servo arm. You'll want to grind a little bit off the cup so it wont bind up. And for the pinion I put a little bit of thread lock on it and havent had a problem in 2 months. Make sure the car rolls fairly smooth without the motor installed. Then check your clutch assembly. You should have very little play in the clutch, use the shims to make sure you have a tight fit, but make sure the pinions can spin freely after you tighten up the bolt.
Old 08-07-2005, 06:58 PM   #1121
Z00M's Avatar
Trader Rating: 15 (100%+)
RD has the full compliment of kit parts on their website.
Mongoose & Spare parts
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 08-07-2005, 07:30 PM   #1122
fordman500's Avatar
Man,I have no idea!!!
Old 08-07-2005, 07:48 PM   #1123
Default goose
maybe something with that ball diff
Old 08-07-2005, 11:02 PM   #1124
how does the standard silver shock springs that come with the kit rank when compared to the other coloured springs? where do they fit?
harder or softer and relative to which?
Old 08-07-2005, 11:28 PM   #1125
Regional Moderator
daniz24's Avatar
The stock silver one is too soft, I would only recommend to use if you're racing in a very slippery or even a wet track. Highly suggest to use the red or orange for most track and yellow for med-high bite track.
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
