Old 07-19-2005, 07:31 PM   #886
fordman500's Avatar
Can I use a Hitec servo for the throttle?I thought I read somewhere that I couldnt.Im using the 925.
fordman500 is offline   Reply With Quote
Old 07-19-2005, 08:10 PM   #887
Motorman's Avatar
I don't see any reason why not. does it fit??
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 07-19-2005, 08:37 PM   #888
Regional Moderator
daniz24's Avatar
I believe G4 only comes with KO/Sanwa and Futaba servo horn. Don't know about RDLogics Mongoose...
daniz24 is offline   Reply With Quote
Old 07-19-2005, 09:04 PM   #889
Motorman's Avatar
yes you will have to use a hitec horn or one of the alumunium horns made by dynamite or the like.
Old 07-19-2005, 09:24 PM   #890
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Im using 2 Hitec 635 HB servos ... not a problem !!! ... but you have to use the arms that come with the servos :
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 07-19-2005, 10:06 PM   #891
g4 mongoose
why won't the car roll backwards?Is the one way in wrong or the gears wrong on the clutch bell?The 2 speed gears are 45t and 51t. And is the front drive suppose to be so undergeared?Back tires rotate almost 2 turns to the fronts 1. 1.75 to 1 back to front.Bought the car used just don't seem right to me any replies would be greatly appreciated
lance is offline   Reply With Quote
Old 07-20-2005, 12:15 AM   #892
Motorman's Avatar
sounds like the two side pulleys are swapped. the rear one next to the engine should be a 19 tooth and the larger one goes in front. also check to make sure the brake is not binding or the clutch
Old 07-20-2005, 12:47 AM   #893
Smile
It was the clutch shoes on the 2speed were stuck.2 speed clutch bell is too small for clutch shoes.Car came with assortment of different gears and extras.new gears fit on new clutchbell but not on the one that fit the shoes.There is such a small difference between the two bells can't be 1mm. between the two did the manufacture change something or what?got everything working now but was wondering if the new bell needs smaller shoes?Tanks for your solutions.
Old 07-20-2005, 05:43 AM   #894
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
Motorman- Are you gonna have any of the new steering bell cranks at the GLC and if so will you have extras?
I would be very interested in trying one.
Uneke is offline   Reply With Quote
Old 07-20-2005, 06:59 AM   #895
Default Spares?
I am new to the G4/Mongoose, and nitro. This is my first nitro car.
What should I have on hand for spares on a typical race day, for both the car and engine? (R3)
I have already broken a universal, (about 4 tanks through the car so far) so will be picking up the V2 universals before I get out again.
Currently the car is stock.
MartynD is offline   Reply With Quote
Old 07-20-2005, 09:38 AM   #896
Regional Moderator
daniz24's Avatar
For car you will need extra clutch shoe, drive belts and spur gear. Just incase
Old 07-20-2005, 07:41 PM   #897
fordman500's Avatar
Which spring are you guys using in your clutch setup?
Old 07-20-2005, 08:12 PM   #898
RayJ's Avatar
Default Clutch Springs
Team Magic 1.7 spring for low to medium bite tracks
Team Magic 1.8 spring for high bite tracks
RayJ is offline   Reply With Quote
Old 07-20-2005, 08:21 PM   #899
fordman500's Avatar
Old 07-20-2005, 10:16 PM   #900
Motorman's Avatar
Uneke
the answer is yes. Limited units will be available by then.
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
