Old 06-29-2005, 06:32 PM   #751
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
it usually breaks after i change gears, but not until I run the car. it breaks where the threaded portion meets the bell.
Uneke is offline   Reply With Quote
Old 06-29-2005, 06:41 PM   #752
Trader Rating: 44 (100%+)
Do u guys use rubber-sealed or metal-shielded bearings clutch bearings?
i have a bunch of rubber-sealed bearings from my 1/8 buggy that fits this car's clutch. just wondering if the rubber-sealed ones can withstand the high RPM of onroad racing?
wyl03 is offline   Reply With Quote
Old 06-29-2005, 06:44 PM   #753
Moderator
Uneke's Avatar
the 1:8th buggy clutch goes through a lot more abuse so the bearings will be fine. metal shielded bearing have less friction though.
Old 06-29-2005, 08:57 PM   #754
Regional Moderator
daniz24's Avatar
Yes, it's weird. I have never had experience or look someone breaks the clutch bell. What's the problem?
daniz24 is offline   Reply With Quote
Old 06-29-2005, 09:09 PM   #755
Trader Rating: 25 (100%+)
I have just purchased a Mongoose and, reading the suggested set up sheet I noticed that the car uses a lot of camber on all corners (3 degrees front, 5 degrees rear), is this ok? Has anybody tried this setup? Please give some feedback, it will be greatly appreciated.
madness is offline   Reply With Quote
Old 06-29-2005, 11:44 PM   #756
Madness.. I have never see a setup using that much neg. camber except from the old stock setup sheet... Not sure where you're running, but if you're concern about camber, try -2* camber in the rear and -1* in the front.. Rear droop 5 and front droop 0... That should get you in the ball park at most tracks and you can fine tune from there... Remember, running to much -camber is not a good thing..
RC_Alan
rc_alan is offline   Reply With Quote
Old 06-30-2005, 07:20 AM   #757
YBSLOW's Avatar
Default Camber
RC_Alan
I ran -2 front and -4 rear camber at Rev measured on the Hudy gauges and my car ran in the 16 sec lap bracket consistantly at the O'Donnell race.
I also ditched the rear sway bar and that helped alot. I have noticed the car likes alot of rear camber. My droop was 5 in the rear and 2 in the front with 58mm tires 45 shore all the way around and it was pretty dialed even in the heat of the day.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is online now   Reply With Quote
Old 06-30-2005, 07:26 AM   #758
Thanks RC_Alan. I was a little surprised when a I saw the set-up sheet included in the manual. Since we race with foam tires I'll probably will be adding an aditional degree both front and rear (-2 front, -3 rear)
I also noticed that the cluth spring is a little bit on the soft side. Have you tried a stiffer one?
Thanks again for the help!
Old 06-30-2005, 08:06 AM   #759
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Well guys, my G4 its finished ...
I mounted a photo sequence with some comments but still in spanish (im working on a english version) ...
Mounting the pics saw an error on the shock mounting due not puting on the right place the rubber o-ring ... but i think that its all ...
You can see the spanish version at :
http://rcc.vtrbandaancha.net
hope you like it ... there are 162 pics on that web ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 06-30-2005, 08:35 AM   #760
Regional Moderator
daniz24's Avatar
Have you fixed the pivot ball nut issue on your car?
Old 06-30-2005, 08:52 AM   #761
YBSLOW's Avatar
Default Clutch Spring
I used the orange 1.7 TM spring without the flyweights at Rev. High bite tracks we run the yellow 1.8 TM spring.
YBSLOW Racing
Old 06-30-2005, 09:20 AM   #762
Tabushi's Avatar
Yes ...
I will re-take some pics this weekend with that issue fixed and i will update my website ...
Old 06-30-2005, 10:40 PM   #763
JABRONI's Avatar
Default U.S. Sedan Nats In Texas
Good luck to all in the upcoming U.S. Sedan Nationals in Texas !!!!!!!
Get some bodies in the "A" and bring home some Bling !!!!!!!!!
YBSLOW (Brad) Motorman, Rjay, Etc.....
Ask Brad about the track, we were there last year and can provide some good info on the track conditions, whether rain or bumpy track conditions !!!!
Doesnt matter !!!! Jam On It !!!!
Scott
JABRONI is offline   Reply With Quote
Old 07-01-2005, 12:43 PM   #764
YBSLOW's Avatar
Talking Sedan Nats.
Scott
Thanks for the hook-up on the plain ticket Homie. Is you avatar trying to devourtheidiotrecktum?
YBSLOW Racing
Old 07-01-2005, 01:29 PM   #765
JABRONI's Avatar
Default Avatar
I found it hilarious !!!!!!!!!
I had seen it quite some time ago and when I saw it again on the net somewhere I thought that would be perfect for an Avatar LOL !!!!!!
I need to post a full size one on my Directors Door !!!!!!!
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
