Old 06-26-2005, 05:29 PM   #721
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
The dogbones are super, go with those. The K-Factory universals that's available for the G4 is too weak, they don't survive more than a few tanks before they snap in the coupling..
btw, the last tank is always when the car breaks, dont drive that last tank!
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-26-2005, 06:02 PM   #722
Default Universals
Team Magic has new universals for the front that are stronger in the area where they used to break....I have about 2 gallons on mine.
peakman is offline   Reply With Quote
Old 06-26-2005, 07:07 PM   #723
Trader Rating: 44 (100%+)
also .. cable-tie the dogbones to the arms so that you won't lose them should they pop out
wyl03 is offline   Reply With Quote
Old 06-26-2005, 09:35 PM   #724
Regional Moderator
daniz24's Avatar
Originally Posted by Tabushi
anyone help me here please ...
Thanks !!!
cya !
Yes, the new stronger universal from K-Factory (K1488) is better than the original. You can also use the Lola conversion lower bumper from K1486 and trim them to the foam for better front end protection.
By the way, from the look of your picture I think you put the pivot ball nut in wrong direction, please check again.
daniz24 is offline   Reply With Quote
Old 06-27-2005, 12:10 AM   #725
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Which pivot ball its in wrong direction ?, i dont understand your point ... let me know about it ... thanks !!
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 06-27-2005, 01:44 AM   #726
Regional Moderator
daniz24's Avatar
The pivot ball nut is the silver one on the steering block. Try to unscrew them and see if they're placed in wrong direction.
Old 06-27-2005, 12:34 PM   #727
Tabushi's Avatar
I think its just an optical effect of the picture ... the nut its on its rigfht direction ... i will take a lower picture here and show ...
cya !
Old 06-27-2005, 12:56 PM   #728
the screw is in backwards......the concave portion goes towards the ball and the flat portion goes towards the outside of the wheel.
Old 06-27-2005, 01:21 PM   #729
Tabushi's Avatar
Really i think its just the angle of the pic ... i will repost the pic from lower position soon ... i have my rc material on my car and i dont want to go down now ... its raining outside ...
Old 06-27-2005, 04:10 PM   #730
The retaining nuts do really look mounted the wrong way direction
Old 06-27-2005, 04:31 PM   #731
GMartinez's Avatar
Trader Rating: 85 (100%+)
Sparx hit it right on the money i went thru this same issue yesterday @ a race & lost the universal & same issue when I was racing a serpent 710. switched to dog bones & never had a problem again. for universalas when getting much steering to make the car more aggressive puts strain on the universal which caused them to snap even quicker.
Here is also a ? I went with the box set up for the mongoose but 4mm caster seemed a little funky so i put it in nuetral position & for rear camber that rear was very loose what recommendations if anyone has on the rear caster setting.
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-27-2005, 06:35 PM   #732
JABRONI's Avatar
Cool O'Donnell Race Revelation Race Way !!!
Home Slice wha happin !!!!!
I saw Mark Cruz made the "A" and I saw you had a DNS for the B"" which from what it looks like you probably could have made it in the Big Show!!!
Looked like a pretty stacked "A" Main !!!
Engine ? Track? Car ? P.M. Me let me know
Did Sam ever make it to the race ?????
I saw Bill Christensen was racin as well !!! Cool !!!
By the way, what is up with the GLARCC Race I saw you posted on Starting Grid !!! Is that coming up soon ????
Scott
JABRONI is offline   Reply With Quote
Old 06-27-2005, 08:09 PM   #733
YBSLOW's Avatar
Default What happen?
Scott
Well you could say I got "DSM'ed" Brand new DSM decided to stick full throttle during warm-up for the main and broke the rear shock tower in the process. It also did it in 2 of my six qualifiers as well That is why my best qual times were in the heat of the day. My car was really good and and I had good power as well. Next time. I heard the "Honda" race was going to be in Torrance weekend after the 4th of July and I am trying to get details on it from Glen Williams. Bill and I are planning on going.
Later,
Brad
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-27-2005, 09:02 PM   #734
XTREMERCHOBBIES's Avatar
Well guys,
Today was my first day with the New G4 (Mongoose in USA) ... the car its awesome and as we run on rubber tires, wow ... the performance in rubber its real real good ... the car its well planted on the track and fast entry/exit on curves ... and all in stock form ... !! ... (i just used the base setup from the box) ...
The STS D3R engine its fantastic and a good match with the STS pipe ... AFM did a great job on modifying on the engine ...
Welll the sad part was on the last tank i run today (just the last before the lunch) ... i hit a inside part of a board (made of sand bags with nylon material over it) and my front left tire got stuck ... the result, a broken universal ... so i need alternatives on :
- Buying a better universal (Kyosho ones work well ?).
- Buying the old fashion axle and dogbone pair (i love them since my experience with them its fantastic).
This is a pic of the part :
Thanks !!!
cya !
Get team kyosho universals if you can get them. They are really hard and I've been using mine for almost 2 years without any trouble
XTREMERCHOBBIES is offline   Reply With Quote
Old 06-27-2005, 09:09 PM   #735
Good reply XTREMERCHOBBIES... I'm using the Kyosho universals in the front and K-factory's in the rear.. Less chance of damage there then in the front... YBSLOW... I heard Glen talking about the Honda race a couple of weeks ago.. I was going to race at the local club race this weekend but I might race at the Honda race if the surface if suitible for racing... The local club race is giving away a MRX4 to the winner of compition at the end of July at Crystal park... If you hear anything else about the Honda race, please pass it along or PM me.. Thanks
RC_Alan
rc_alan is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
