Old 06-08-2005, 10:08 AM   #676
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by Motorman
Difference between G4 and Mongoose.
G4 evo
New stiff chassis. silver stamped
Push type clutch set
new swing rack steering.
Front One-Way
Carbon Radio Plate
K1406 Front Anti-Roll Bar & Mount
K1407 Rear Anti-Roll Bar & Mount
CVD (2 pcs) & Drive Shaft (2pcs)
K1418 Aluminum Wheel Adapter
RDLogics Mongoose G4 parts over and above evo 2
Light 2 speed shaft PN (502200)
Push Type Clutch Set w/new K1410-1 clutch update set.
G4 S-Class 2 Speed Housing & Nut (w/bearing). PN (502250)
G4 S-Class 2 Speed 2nd Spur Gear 45T. PN (502251)
G4 S-Class 2 Speed 2nd Spur Gear 46T. PN (502252)
G4 S-Class 2 Speed 1st Spur Gear 51T.
G4 S-Class Blue Alum. Side Plate (pair).PN (502254)
K1480 Carbon Swing Rack Steering
K1481 Carbon High Ackerman Steering Block for improved steering
K1487 3mm 7075 Blue K Factory Aluminum Chassis.
K1490 G4 S-class Hard Coated Alum. Light 19T Clutch Gear
K1489 G4 S-class Hard Coated Alum. Light 18T Clutch Gear
Mike the entire transmission kit is K-1492 and K1410-1
Here you go. This was posted by motorman on 3/30/05
Hope this helps.......
Walter Diaz
wad is offline   Reply With Quote
Old 06-08-2005, 01:55 PM   #677
007kel's Avatar
Send a message via AIM to 007kel Send a message via Yahoo to 007kel
Originally Posted by YBSLOW
If the track is real smooth we run Mugen 600wt and if the track is a little bumpy and the bite is not real high we use Mugen 400wt
Thanks YBSLOW
KO PROPO HELIOS...yeah that's what I have left after leaving RC.
www.foundrycc.com
Instagram: 7kel
007kel is offline   Reply With Quote
Old 06-08-2005, 07:39 PM   #678
Do you run that weight on all 4 shocks? I heard so Nirto TC drivers run heavier fluid up front, or is it better to run the same weight all around on the mongoose.
Also what springs are a good starting point. I heard the kit one s are too stiff. I was going to get the option springs from ofna becasue they come in a set. I think they are for the LD3 or CD3, I'm not sure? BTW i'm moving to fort myers so i will mostly be running on the winternats track.
jnims29 is offline   Reply With Quote
Old 06-09-2005, 04:41 AM   #679
RayJ's Avatar
Default Mongoose Spring Set
RD Logics has a spring set that is complete and is desigend to be used on the Mongoose. I like them. It should be listed on there website. If not call them. They will be more than happy to help.
RayJ is offline   Reply With Quote
Old 06-09-2005, 07:24 AM   #680
YBSLOW's Avatar
Default OIl?Springs
I sometimes run the 600wt up front and 400wt in the rear if my car is a little loose and changing tires is too drastic. Mostly I use shock oil to tune for the overall bite and bumpyness of the track. On super high bite (traction roll) I may even run 800wt up front and 600wt in the back.
Like RayJ said give RD a call and ask for the TM spring set because I know they carry it but, do not list it on there website yet. I amtrying to get them to update the "whats new" page on there site more frequently.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 06-09-2005, 08:01 AM   #681
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Well, i've tried the new stiffer K-Factory spring, and they're awsome
The super hard Yellow 1.8mm spring gave the best performance, awsome launches. Be sure not to overtight it though because it will slip if you tighten the nut more than 0,5mm.
The setup i ran was:
Yellow 1.8mm spring
No inserts in flyweights
0,5mm endplay
Nut tightened to flush with threads and then in half of a revolution.
In rain (the race got totally soaked ) the best setup (launches EARLY, only need to rev up a bit from idle to engage) was:
Red 1,6mm spring that came with the new Kfactory clutch.
Inserts (weights) in flyweights
0,3 mm endplay
Nut tightened about 0,5mm
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-09-2005, 09:39 AM   #682
YBSLOW's Avatar
Default WOW
Originally Posted by afm
Talking about clutchs for the G4, check this one out Made in Italy
http://www.electronicdreams.it/site/...tent=155&mnu=1
AFM
It looks really lite weight. i wonder if the clutchbell would work with the K-factory cluth?
YBSLOW Racing
Old 06-09-2005, 10:28 AM   #683
Thanks I would rather rum TM springs than the ofna ones. Do the Tm ones come w/ a spring rate chart? And should i run stiffer springs up front than rear?
Old 06-09-2005, 10:41 AM   #684
YBSLOW's Avatar
Default Spring Rate Chart
The TM spring kit is nice because it come with 6 sets of springs from 1.3 to 1.9. I have run everywhere from 1.6 to 1.9 up front and from 1.5 to about 1.7 in the rear. I usually start out 1.6 front and 1.5 rear. The springs come in a little box and has a rate = to which color chart on a sticker on the box. I believe if you look back on this forum someone posted the LBS ratings and some comparisons to some common mugen springs that can be pretty helpful.
I usually run 1 spring rate stiffer up front but not all the time.
YBSLOW Racing
Old 06-09-2005, 10:45 AM   #685
wad
wad's Avatar
I like to use the same springs front&rear, but if you feel your car with too much steering, go to a harder ones, and if your car is pushing on the front go to a softers ones, that will be the best way for me to find out......
Walter Diaz
Old 06-09-2005, 10:48 AM   #686
afm
afm's Avatar
tm gray 1.9mm 52.0 lb/in
tm orange 1.8mm 41.5 lb/in
tm blue 1.7mm 31.0 lb/in
tm aqua 1.6mm 26.0 lb/in
tm silver kit stock 26.0 lb/in
tm purple 1.5mm 20.0 lb/in
tm pink 1.4mm 17.0 lb/in
tm fuccia 1.3mm 13.5 lb/in
tm green 1.2mm 11.0 lb/in
Hope it helps
AFM
afm is offline   Reply With Quote
Old 06-09-2005, 12:02 PM   #687
Sweet, thanks for the info. guys.
Old 06-10-2005, 07:05 AM   #688
DDAWG's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to DDAWG
Red face
I HAVE A MONGOOSE AND I WOULD LIKE TO SEE RDLOGICS UPDATE THEIR SITE MORE OFTEN ALSO. THAT WAY YOU COULD KEEP UP WITH WHAT IS NEW AND WHAT IS BLING. I HAVENT BEEN ABLE TO RUN MINE YET DUE TO ALL THE RAIN. BUT THE CAR IS AWSOME LOOKING JUST PLAIN STOCK OUT OF THE BOX. BUT I DO WANT THE BLING FACTOR ON THIS CAR.
DDAWG is offline   Reply With Quote
Old 06-12-2005, 06:41 PM   #689
YBSLOW's Avatar
Default Mongooosee!!
Good job Ray J in Toledo!
YBSLOW Racing
Old 06-12-2005, 07:41 PM   #690
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi, finally me and my friend got the Team Magic G4 New EVO ... the first pic is me ... and the second one are my other two friend who got the same kit ... i will be runing with STS Engine and Pipe (D3R Modified by our friend AFM) ... once again, thanks AFM !!! ... we are the only 3 Team Magic Cars in the whole country !!
Hope to work next weekend on the building ...
Our track (behind us on the pic) its about 280 meters long with a main straight of 68 meters app. ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
