Old 04-25-2005, 10:00 PM   #556
Motorman's Avatar
adam use no spacers and put the steering ball on the front of the steering servo arm on a KO. KO's are tight thats just how it is.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-25-2005, 10:05 PM   #557
adamkerrnz's Avatar
Thumbs up
OK thanks
adamkerrnz is offline   Reply With Quote
Old 04-26-2005, 01:27 AM   #558
Goodluck Motorman with that bellcrank conversion... I tried the same thing last year with the help of a very good friend that wish to not be mention... There's pictures of it posted on the Trinity G4 thread about Aug /Sept 2004. We were alittle farther along then what you have, but just couldn't get it to work properly... Then came along the current swing rack update to the G4 and I've been using it instead... I really wish you luck and I hope your conversion works well. The main problem we had was 1, we couldn't get enough steering throw and 2, the servo saver we used was a tad bit to large... The bell crank design is something TM should have done in the first place, but the swing rack setup is better then the slider system and I haven't had to many problems with it.
RC_Alan
rc_alan is offline   Reply With Quote
Old 04-26-2005, 06:18 AM   #559
Motorman's Avatar
Alan
the steering throw is the same as the current rack system on the setup board. Ackerman is very close also. There is lots of real estate now and the bump steer seems to also be lower as the tie rods are almost 1/2 inch longer. I have confidence it will work out well. I spent quite a bit of time making sure it was located the right place in the chassis fore and aft, and setting the height of the tie rods so they are level at ride height.
Old 04-26-2005, 06:30 AM   #560
hi motorman,
from what car is this steeringsaver??
dieter
4racer is offline   Reply With Quote
Old 04-26-2005, 06:32 AM   #561
Leo V.'s Avatar
Dennis YGPM.
BTW, what Xray part are you using? I'll see if I can get it working for the McCoy race.
Leo V. is offline   Reply With Quote
Old 04-26-2005, 12:29 PM   #562
YBSLOW's Avatar
Default Looks good!
Originally posted by Motorman
somthing I am working on. maybe in a couple months this will be a reality. lets hope. We still have some testing to do first though.
unfortunatly its not going to be a direct bolt in.
it requires a chassis change
That looks TIGHT! I can't wait to run it at the Biggie. Dennis I missed your call last night and I will call ya later.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 04-26-2005, 12:46 PM   #563
Leo V.'s Avatar
Brad YGPM
Old 04-26-2005, 04:42 PM   #564
RayJ's Avatar
Default Steering system conversion
Dennis it looks great!! Can't wait to try it too. It looks like it was made for the car. I'll have to show you my rear bearing concentric set-up for the 18tooth brake pulley and 63tooth belt.
RayJ is offline   Reply With Quote
Old 04-27-2005, 11:34 AM   #565
YBSLOW's Avatar
Default Re: Steering system conversion
Wow a post by the infamous RayJ!
YBSLOW Racing
Old 04-29-2005, 09:08 AM   #566
Moderator
Jpilone's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Jpilone
I just bought one of these cars for myself!
Can you guys tell me if this car has any overdrive built in?
like, if I cut tires, I cut the rears at 60 and the fronts at 59?
-Jarrod Pilone
Pro R/C Photographer
http://www.jpsportspics.com
Jpilone is offline   Reply With Quote
Old 04-29-2005, 09:58 AM   #567
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
No overdrive on Mongoose, the internal ratio is the same front and rear, if you are running everything stock, you should be fine running same tire diameter
Walter Diaz
wad is offline   Reply With Quote
Old 04-30-2005, 11:10 AM   #568
Thumbs up Mongoose 4 sale
Hey all, I bought this car after reading all the great info in this
thread.One of the best cars I have ever assembled,and an awesome fast car. But I have decided to go back electric racing.
The car is one month old,(1 qt on motor)(4 runs on chasis).
Includes,
*RRE .12
*Turbo II pipe
*Motor saver filter
*Futaba servos (s9001/s3004)
*Mcdaniels meter glow ign.
*Ofna starter box w/12v and charger.
*750mah rx battery
*Box/instructions
Just ad a transmitter and fuel.
Everything in brand new,only used on this car.
$475 shipped in the US only.
Will be posting on ebay tonight.Check there for pics.
Thanks,
Brian
BPWJRXS is offline   Reply With Quote
Old 05-01-2005, 09:00 AM   #569
Default Re: Mongoose 4 sale
Includes,
*RRE .12
*Turbo II pipe
*Motor saver filter
*750mah rx battery
*Box/instructions
Thanks,
Brian
Do you have Pics?
HAYJ is offline   Reply With Quote
Old 05-01-2005, 09:54 AM   #570
apla's Avatar
Send a message via MSN to apla
Default centax
Guys do you think that sentax is worth buying?i run with 3-shoe?
apla is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
