Old 04-10-2005, 06:58 PM   #496
SCUBA STEVE's Avatar
Trader Rating: 86 (99%+)
OK, Here is how I mounted my receiver...I hope this picture thing works! http://tinypic.com/2nri1u
SCUBA STEVE is offline   Reply With Quote
Old 04-10-2005, 07:04 PM   #497
Alright it worked!...If anyone wants to do it like this you have to dremel the upper plate a little bit but the receiver fits in nice and deep and in way less likely to take a hit....after you dremel the upper plate mount the rec. to the carbon fiber lower plate, elongate the mounting holes on the plate then you can screw it right to the right side chassis plate using the existing holes....I know it sounds confusing but once you have the peices in front of you and look at the pic you'll see how I did it.......if anyone likes it and has any questions feel free to ask
Old 04-11-2005, 03:10 AM   #498
hi motorman,
i have take your setup tips,
and this whas not good for our track,
i have low steering, so i change to 37er front and 40 er rear, no offset.
the temp yesterday about 10 c and the gripp are very low.
dieter
4racer is offline   Reply With Quote
Old 04-11-2005, 05:00 AM   #499
at all,
mongoose or g4 driver,
have you also the problem with the brake fading??? my brake goes well the first minutes in a race, and the brake goes down, on the end off a 30 min race i have nearly no brake.
i have the k-factory tuning brake disk in my car.
dieter
Old 04-11-2005, 11:48 AM   #500
C Verano's Avatar
Exclamation pm
Leo V,
You have a PM sir.
Chris
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 04-11-2005, 05:04 PM   #501
quietstorm76's Avatar
Default clutch
Thanx guys for the tips. I'm going to try the mugen super hard spring.
quietstorm76 is offline   Reply With Quote
Old 04-11-2005, 05:30 PM   #502
Dreddlox's Avatar
I'm to the point where I have to mount the upper deck to the chassis and wanted to know the trick to making the steering servo fit. Thanks
Dreddlox is offline   Reply With Quote
Old 04-11-2005, 08:43 PM   #503
Motorman's Avatar
which servo? type
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 04-11-2005, 09:11 PM   #504
Trader Rating: 49 (100%+)
I have been noticing brake fade as well. I have to keep increasing the brake travel on almost each heat. Is there any fix to this. I am using the kfactory brake disk.
rodneybarrett is offline   Reply With Quote
Old 04-11-2005, 10:33 PM   #505
Motorman's Avatar
give it a while to settle in. it will take a few races you will then need to readjust the clerance with the screws.
Old 04-12-2005, 12:09 AM   #506
Default Ball Diff
Has anyone tried the K-Factory Ball Diff? Is this a must have item?
cvccsi is offline   Reply With Quote
Old 04-12-2005, 03:25 AM   #507
Dreddlox's Avatar
I'm using a Hi-tec servo for steering.
Old 04-12-2005, 03:59 AM   #508
hi motorman,
my car have many races but the problem
with the brake fading i have from the beginning.
and iam not alone on our tracck with that problem on the g4/mongoose.
dieter
Old 04-12-2005, 05:10 AM   #509
charlesd's Avatar
Default front diff question
My mongoose is on the way and i know i'm not a good enough driver to use the one-way (yet).
Is there a part # for the front diff or do i buy the same stuff as the rear diff but just add the front pulley?
Also -- does the ball diff work in the front ?
Sorry for the newby questions.
charlesd is offline   Reply With Quote
Old 04-12-2005, 01:32 PM   #510
JABRONI's Avatar
Default Front Diff
I put one in mine and it works great, I will get you the part #
when I get home from work.
I had asked the same question and got a great response earlier in the year.
I got it from a post on some of the earlier pages in this thread, take a look and see if you can find it !!!
It has some photo's etc....
Scott
JABRONI is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
