Old 03-29-2005, 08:48 PM   #436
Motorman's Avatar
you need the new s class parts. It must have one of the very early ones. I didn't think there were anymore of those out there. we only got a very few that way.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 03-29-2005, 10:08 PM   #437
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up Thanks rc alan for your help
I really appreicate you helping me on gearing for the mongoose
it a great to know that someone is willing to share information
to help new mongoose owners go faster also it shows you
have a great deal of knowledge on g4/mongoose. Thanks again.
Ivan
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-30-2005, 05:05 AM   #438
MikeWz's Avatar
Send a message via AIM to MikeWz
Motorman - I just got a G4 Evo. What kind of parts am I looking at upgrading to get it to Mongoose specs other than the chassis?
MikeWz is offline   Reply With Quote
Old 03-30-2005, 06:34 AM   #439
Leo V.'s Avatar
Default RcAlan
RC alan
When are you going to Crystal Park?
Leo V. is offline   Reply With Quote
Old 03-30-2005, 07:43 AM   #440
BoCal... I'll be at Crystal park this weekend... I was at REV Tuesday, but really could'nt do much there as the wind storms from Monday did a number to the track as far as traction... Chatted with Paul Colman and joked about his car... lol... I left REV at about 1:30pm... I would go to Crystal park Today, but the track is closed during the week days until Mugen get through with it.... BoCal, PM me when you get a min... Ivan Dickson... No problem.... Oh, there is only 1 chart and not two... If you're having any problems figuring things out, let me know. As far as the clutch spring question, I've used the Yokomo soft clutch spring with out any problems... Motorman... I also use the 4mm chassis, it's more stable and in one of those rare occassion's... lol More durable.
RC_Alan
rc_alan is offline   Reply With Quote
Old 03-30-2005, 08:05 PM   #441
Motorman's Avatar
Difference between G4 and Mongoose.
G4 evo
New stiff chassis. silver stamped
Push type clutch set
new swing rack steering.
Front One-Way
Carbon Radio Plate
K1406 Front Anti-Roll Bar & Mount
K1407 Rear Anti-Roll Bar & Mount
CVD (2 pcs) & Drive Shaft (2pcs)
K1418 Aluminum Wheel Adapter
RDLogics Mongoose G4 parts over and above evo 2
Light 2 speed shaft PN (502200)
Push Type Clutch Set w/new K1410-1 clutch update set.
G4 S-Class 2 Speed Housing & Nut (w/bearing). PN (502250)
G4 S-Class 2 Speed 2nd Spur Gear 45T. PN (502251)
G4 S-Class 2 Speed 2nd Spur Gear 46T. PN (502252)
G4 S-Class 2 Speed 1st Spur Gear 51T.
G4 S-Class Blue Alum. Side Plate (pair).PN (502254)
K1480 Carbon Swing Rack Steering
K1481 Carbon High Ackerman Steering Block for improved steering
K1487 3mm 7075 Blue K Factory Aluminum Chassis.
K1490 G4 S-class Hard Coated Alum. Light 19T Clutch Gear
K1489 G4 S-class Hard Coated Alum. Light 18T Clutch Gear
Mike the entire transmission kit is K-1492 and K1410-1
Old 03-30-2005, 08:37 PM   #442
Motorman's Avatar
rcoldman
you can purchase the pinion but you may have mesh issues with it. It is smaller diameter and coresponds with the smaller diameter s class second gear spurs. even though the s class spurs are the same number of teeth the gear is physically smaller so the engine can be adjusted closer to account for the smaller 18 tooth first gear.
Unfortunatly the new grey gears for second require the new 2 speed housing to go with them as it is smaller on the od for the new spur. the Id is the same and the same 2 speed shoes are used.
Old 03-31-2005, 09:09 AM   #443
MikeWz's Avatar
Awesome, thanks. What's weird is I got the evo...but I also have the blue aluminum side plates
Old 03-31-2005, 04:56 PM   #444
Z00M's Avatar
Trader Rating: 15 (100%+)
Default Has the 'goose changed spec?
I bought a Mongoose but I didn't get some of the things quoted above....such as:
I didn't get any extra gears. I just got the 19/24 46/51 gears only. Is this a misprint or a running change to what's included now? If it's what's included now then the car is even better value than the one I bought!
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 03-31-2005, 05:44 PM   #445
Motorman's Avatar
yea they changed slightly
Old 03-31-2005, 11:15 PM   #446
Rob Phillips's Avatar
Where is the best place online to buy on of these, RDLogics.com? I may be getting one of these after I save back up the money Uncle Sam took from me. I was going to get a good deal on a Prospec, but due to the taxman, I had to pass. Any spares or must haves to pick up with the kit?
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 04-01-2005, 01:36 PM   #447
YBSLOW's Avatar
The TM spring kit and the K-Factory rear brake bracket with belt tensioner are the only must haves. The graphite rear shock tower and front graphite brace that ties the radio tray to the front bulkheads is very nice piece as well. RDLogics.com is a good place to buy and you might actually check Ebay as well. i believe there are a couple of places selling the Mongoose on Ebay.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 04-01-2005, 01:41 PM   #448
Motorman's Avatar
you could also have debbies or speedtech get it for you and it will be cheaper. call them.
Old 04-01-2005, 03:23 PM   #449
Ffejdat's Avatar
Motorman- I just ordered a Mongoose today from Rd directly, look forward to building and running it! i will be running this in the Heart of America series, maybe one or two Midwest series races or great Lakes challenge also! Looking for build tips, needed upgrades, etc, I have read thru all these posts, know about flywheel issue, tighten down servo saver, etc.... Did I see you mention a fuel tank issue? Not sure about that one... Have you tried the 26 tooth side pulley option with smaller front tires at all? I am wondering about shock springs, I have a complete front and rear set of Associated springs and I know they fit other shocks such as Mugen, etc., any thoughts on useing these springs? One other Question, Your guy (Nick?) that put o run in at the Winetnats that would have been 8th, was he running a RRE motor, box stock, or mildly or wildly modified? Thanks, I'm sur I'll have more Q's later!
Ffejdat is offline   Reply With Quote
Old 04-01-2005, 06:35 PM   #450
Ffejdat's Avatar
A few more questions for Mongoose- G4 owners, How small can you run your tires down to on this chassis, taking into account adjusting downstops properly and such, and what kind of "balance" of tire hardness front to rear does this car tend to like,i.e., same hardness front to rear, or one shore harder or softer front to rear in general, I know every track is different, just looking for a general idea on tire balance...
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
