Old 02-08-2005, 05:20 AM   #226
Nitro Tech
dino.tw's Avatar
Default Re: downstop
Originally posted by Mr. Shims
thanks dino, yeah i set that at four most of the time based on my hudy. im just not used to calling it downstop. thanks for the tip ill try to get a set of springs based on your recommendations and see how it handles.
When you try the springs,you will find that you don't need very big steering angle. Less steering angle means higher speed. Then the ball cup will not pops out.
The G4 has too low CG and the kit is too light. If you use hard spring you will find that the car doesn't willing to turn. Also the traction not good if you use hard springs. If you use TM spring,1.3~1.5 is the only choice.
About suspension downstop;
low grip track : Front 0 / Rear +2 (start with this)
high grip track : Front +2 / Rear +4 (when your car too sensitive)
super high grip track : Front +4 / Rear +4 (traction roll)
dino.tw is offline   Reply With Quote
Old 02-10-2005, 09:54 AM   #227
Trader Rating: 49 (100%+)
So how's the Mongoose doing down at the Winternats?
I am curious to see how the new motor is doing as well.
rodneybarrett is offline   Reply With Quote
Old 02-10-2005, 10:58 AM   #228
gonzoY5's Avatar
Dennis isn't doing so hot. As of round 4 yesterday he's in 51's place overall. Seemed to have only put down 1 good qualifier(2 DNS, 1 DNF), but times are off the pace. I don't know who else is running a Mongoose/RRE combo. Does anyone know another driver running an RD setup?
Maybe things will change today. Serpent is absolutely flying, Mugen is very close, fuel mileage seems to be a problem.
gonzoY5 is offline   Reply With Quote
Old 02-10-2005, 12:53 PM   #229
afm
afm's Avatar
Eric Jones and Nick Dotson, and way below Dennis...will have to wait till Dennis tell us if they had engine or chassis problems.
AFM
afm is offline   Reply With Quote
Old 02-10-2005, 02:08 PM   #230
Derby Bros Racing's Avatar
if only brad was there........ oh well, there's always other races.
Derby Bros Racing is offline   Reply With Quote
Old 02-10-2005, 05:50 PM   #231
gonzoY5's Avatar
Old 02-10-2005, 06:07 PM   #232
afm
afm's Avatar
After six qualy rounds Nick Dotson is 51, but on his last round he seems to have found the set up because he did some good laps in the times of top 5 and average speed same as 5th overall.
He will have to put up some serous racing on the mais to move up, but as i said he seem sto have found the key.
Dennis is 61, and Eric Jones is 57
AFM
Old 02-10-2005, 06:49 PM   #233
Francis M.'s Avatar
last report is Nick Dotson's last run qualified him in 8th with a pit but the run was DQ'd because the car came in just a hair under weight. So Nick Dotson has A main speed but will have to bump up in the mains.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 02-10-2005, 08:43 PM   #234
GMartinez's Avatar
Trader Rating: 85 (100%+)
AFM
I will be running the Mongoose this upcoming season @ region1 & @ some Major events.
I always look more @ the mains more than qualifiers that will set the tone who is consistent thru out the entire event. I was going to the event but the wife has a good lawyer LOL but I am getting a better one so I can attend the 2006 event. I will start putting the car together when it arrives I will be using a similiar set up close to my 710 that I ran last season. So good luck to the RDLOGICS Team
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 02-10-2005, 09:03 PM   #235
Any advise regarding rear traction. My mongoose always loose rear traction every time I make a turn. Do you think softer rear diff will help or harder front tires?
Robert I. is offline   Reply With Quote
Old 02-10-2005, 09:55 PM   #236
GMartinez's Avatar
What tire shore are you running.
what is your toe in set up
Before I had the 710 I was testing out the G4 Pro E class the tires were 37 all aroung with a toe in of 2 degrees I can't remember the shock oil
but the car felt very planted once I have the new car done I will let you know which set up is doing well.
Old 02-10-2005, 09:55 PM   #237
GMartinez's Avatar
Hopefully weather permitting it is cold out here
Old 02-11-2005, 09:51 PM   #238
Default WinterNats
OK, so what happenned to Nick Dotson? I mean I understand the DQ he got for being under weight but there are other heat races and his main to where he didn't even finished. Was there a problem with his engine? Or was it something else.
....When he was running, a lot of his lap times were A main caliber.
Old 02-12-2005, 12:15 PM   #239
JABRONI's Avatar
Originally posted by peakman
The steering rework that Motorman recommends is a must if you want the car to track straight lap after lap. I made the mod and it is night and day plus is durable.
I'm trying to finish up the car, however I see two issues with my steering I can't figure out.
I've been throught the posts, however, I do not see any mention of it.
If turning to the left the the steering mechanism will get sawed by the front belt, and when turning to the right the Steering Servo horn will rub against the front r/h bulkhead
JABRONI is offline   Reply With Quote
Old 02-12-2005, 12:51 PM   #240
JABRONI's Avatar
Default Steering
YBSLOW gave me some tips that appear will work, Mount servo horn on opposite side with spacers and make sure end point steering is set correctly !!!!!
Thx, I'll give er a try
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
