Old 02-03-2005, 02:10 PM   #196
Motorman's Avatar
Myself, Nick Dotson and Eric Jones will be running Mongoose's with R3 power at the winternats.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 02-03-2005, 07:40 PM   #197
DDAWG's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to DDAWG
Default set up station
motorman does rd logics sell setup stations or is it team magic?
i seen one (or i thought i did) on ebay a couple of days ago and now i cant find it. it looked just like the hudy ultimate with the little rollers on bottom of the 4 main gauges. thank for the help hudy is just to pricey
DDAWG is offline   Reply With Quote
Old 02-03-2005, 07:57 PM   #198
YBSLOW's Avatar
Default Re: 18 Tooth Pinion and new Pulleys
Originally posted by rcoldman
Motorman/All,
Can I run the new 18 tooth S-Class Clutch Gear with a 23 tooth second gear on my factory G4 centax clutch bell and still maintain proper gear clearances? This setup would yield a 7.30 first gear final and a 5.27 second gear final which should be good for a tight track. Any other thoughts?
Can I run the new 18 tooth transmission shaft pulleys without changing belts and/or tensioners?
Thanks for your response,
ED
I will be trying the 18tooth pulley setup and 18tooth speed gears setup tomorrow on a real small track. I will report back this weekend on how it worked.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 02-03-2005, 08:13 PM   #199
Send a message via AIM to munrath
Good luck at the WinterNats!!!
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 02-04-2005, 01:46 AM   #200
Mr. Shims's Avatar
Default re setup
thanks motorman, how will this effect rear grip? i need to increase rear grip as well on my g4 thank you
Mr. Shims is offline   Reply With Quote
Old 02-04-2005, 04:00 AM   #201
Nitro Tech
dino.tw's Avatar
Default Re: re setup
disconnect the rear anti-roll bar then use the rear downstop to limit the rear chassis roll.
dino.tw is offline   Reply With Quote
Old 02-04-2005, 04:59 AM   #202
Bundy_Bear's Avatar
Originally posted by Motorman
bundy the answer is yes
Motorman:
Thankyou, is it something that RDLogics and yourself are working on is it Team Magic? I have spoken to you in the past about the steering issues and it ended up being the deciding factor in me ditching the car in the end. However i do have two friends that i race with that have both G4's.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-04-2005, 06:11 AM   #203
Default ybslow
you're alive !
isuzuguy is offline   Reply With Quote
Old 02-04-2005, 01:08 PM   #204
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Mr. Motorman,
Downhere in southamerica we always have to buy from USA so due to the fact im thinking on buying a new kit im about to choose going for the mongoose.
Now, downhere we run IFMAR based rulebook but with just 1 exception .... we run RUBBER TIRES. I see the mongoose come with front one way and rear diff, is there a chance to pick up a mongoose with FRONT AND REAR DIFF ?, and buy an extra front solid axle ? (if there exist one for the G4) ?.
Now im runing with my Yokomo GT4W2L but Yokomo left us nitro 200mm guys alone for a while so im looking for switch brands ... and i like to innovate to i dont want to buy Serpent or Associated wich are most of peopole running around here ...
thanks for any comment,
Cya,
Pat
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 02-04-2005, 05:51 PM   #205
afm
afm's Avatar
Pato
You must buy separate front diff....i'ts not expensive...and since it is similar to Kyosho's there is an optional part from Kyosho to convert fron diff on to solid axle...... it's a simple bolt on part..saw it somewhere in the Kyosho V1rrr thread.
To run it on Rubber tires all you need apart from front diff, is make a lower third hole on rear uprights, to lower camber linkage fixing point (courtesy of Darren Jonhson British National Rubber Champion with TMG4).
When you get the car i can send you about 6 differnt st up sheets for Rubber Tires from British Championship)
Bye Bye
Alfonso
afm is offline   Reply With Quote
Old 02-04-2005, 09:16 PM   #206
Bundy_Bear's Avatar
Originally posted by afm
Pato
Bye Bye
Alfonso
AFM:
Is this on the rear hub side or the diff side?
BB
MissMooRC Racing
Old 02-05-2005, 12:44 AM   #207
Mr. Shims's Avatar
thanks dino, i did that already actually i never used the roll bar.
stupid question how do i set up the rear downstop?
Old 02-05-2005, 05:28 AM   #208
afm
afm's Avatar
Originally posted by Bundy_Bear
AFM:
BB
HUB SIDE
AFM
Old 02-05-2005, 08:54 AM   #209
JABRONI's Avatar
Default Front Differential
Perhaps I missed it earlier, however, is there a Front Diff available from any manufacturer for this car and if so what is the part # ?????
Any suggestions would be appreciated !!!
YBSLOW How did it go, did your Oneway Locked out work ok !!!
JABRONI is offline   Reply With Quote
Old 02-05-2005, 10:04 AM   #210
Nitro Tech
dino.tw's Avatar
see the manual,Page 18.;BAG J;STEP 3
There is a 4x8mm screw #126408
Use it to adjust the downstop(droop)
I thought I knew your problem already from your previous posts. You are using mugen whites (1.9 ) in the front and team magic orange in the rear or 1.7. Also shock oil at 35 all around ,right?
Well,the problem should be the rear spring is too hard. The orange one is 1.8 and the blue is 1.7. You need to know the TM Optional Spring has only 5 loops. The Mugen or Serpent Spring has 7 loops. Less loops means more hard if they are the same diameter. So you better use the same brand's spring in the front and the rear if you believe the number.
I would suggest you to try TM's 1.4 in both of the front and the reat first. It is equal to Mugen's 1.6(close)
I usual use Serpent yellow short spring in front and TM's 1.4 in rear. Cold weather use Serpent 30wt,hot weather use 35wt. FYI...
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
