Old 01-26-2005, 10:24 PM   #166
Motorman's Avatar
Just take your time and it will be all good. If you run into any hang up post a note here and we can advise you. I just assembled another new kit and one thing I did was shorten the lower front control arms at each end a hair so they were freer on the hingpins. they seem to be a squeek long. Just file off about .020 on each end.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-27-2005, 11:57 AM   #167
Dennis
Will you be attneding the RDlogics Grand Prix in Vegas?
I'll be in Vegas for the NHRA drags, don't know if I'll be able to stop by and watch and say hi
Sometimes I post just to look at Kraig's avatar
RoyU is offline   Reply With Quote
Old 01-29-2005, 07:50 PM   #168
i_like_f150s's Avatar
I have the RD Logics/Team Infinity 312TB. The first thing I did was take off the carb riser, as it looked like it had the potential for air leaks. Now the big "ring" on the end of the carb hits the brake mount in my LD3, and the radio plate in my MTX-3. What can be done to resolve this? Thanks in advance.
i_like_f150s is offline   Reply With Quote
Old 01-30-2005, 11:16 AM   #169
Motorman's Avatar
Roy
don't know if I'll be there or not but I will be supporting the team guys via phone and with power. The winternats will consume 2 weeks starting next weekend. one week racing one week relaxing and complaining about what I should have done different. LOL
F150
Not much, put the riser back on thats why its there. The carb sits low in the microcase engines. thats just the way they are.
Old 01-30-2005, 12:03 PM   #170
Thanks Motorman, but I must have tossed the riser. My temporary solution for the LD3 was to install an Ofna carb from a Force .12 "red head". A little trimming of the radio plate was all that was needed to fit the engine into the MTX-3.
One other minor issue with the 312TB is that the new RD Logics Turbo II pipe set would not fit. A small amount of material had to be removed from the top of the header where it mounts to the engine before it would fit flush.
Old 01-30-2005, 02:32 PM   #171
SRAD's Avatar
Default Hey Motorman
Is the car that Nitrohouse on ebay is selling.....Team Magic G4 Evo and the Mongoose the same car that you are marketing? Thanks
SRAD is offline   Reply With Quote
Old 01-30-2005, 06:08 PM   #172
SRAD's Avatar
Default Mongoose
Correction to the above post.....it's Nitrocarhouse....not Nitrohouse selling the G4 on Ebay....sorry....names sound similiar.
Old 01-30-2005, 07:36 PM   #173
Motorman's Avatar
It appears to be. Looks like the early boxing in the picture (when we still shared the Team Magic Box) the new boxes are green and black and say Mongoose on them. However I don't know why they have it listed as a Team Magic Mongoose as The car should be listed as RD Logics Mongoose G4 ?? Since their selling the combo I assume it is.
Ask them what gives??
F150 we'll take a look at that thanks for the info.
Old 01-31-2005, 02:31 AM   #174
nils's Avatar
Default new g4 s class spead gear the fastes setting
can any wone tel me what is the fastes gearing is with the new
g4 s class gearing set with use with the new 20t rear site pully
and the 20t brake pully.
im running 32 front, 26 out side front ,18 in side front.
i stil whant to have a litle over drive in the front.
is 25 /45 2nd and 20/50 1st good or to slow.
we drive big scale tracks in the netherlands.
i am driving with a jp fx t03 fully moddefeid .
nils is offline   Reply With Quote
Old 01-31-2005, 07:29 PM   #175
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Default finish building my mongoose
I am really impress with quality of rdlogics mongoose kit
also how easy it was to assemble with the instructions
considering it was my first nitro kit.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-31-2005, 07:40 PM   #176
Z00M's Avatar
Trader Rating: 15 (100%+)
My mongoose is together as well. Happy with how it looks on the bench, just have to see how it goes on the track on Sunday
My blog: http://mikesrc.wordpress.com
XRAY XB4
## NOSRAM ## XRAY ## KO ##
www.nbhc.com.au - www.teamxray.com
Z00M is offline   Reply With Quote
Old 01-31-2005, 07:50 PM   #177
Motorman's Avatar
Nils I'm working on a simple calculator that you can use to calculate any gear ratio final drive and rollout on the mongoose just by plugging in the numbers. I should have the Apha version done I hope by the end of the week. If not It will be two weeks before I can get it published after I get back from the winternats. It will be a free download from the RD site.
The beta version will also calculate the optimum gearing for a desired track length based on gear ratio, tire diameter and track length. It will be good to get the car in the window very quickly.
smaller spurs and bigger pinions will give more top end.
Old 02-01-2005, 03:53 AM   #178
Mr. Shims's Avatar
Default Steering Link Popping out
Need Advice on how to keep the ball cup link between the servo and the steering rack from popping out, i tried the team magic ball cups but no success. should there be any better way to address this would be greatly appreciated. another thing im still undecided if i should just take away the servo saver since at high speed corners the play tends to take away most of the response from the steering.
Mr. Shims is offline   Reply With Quote
Old 02-01-2005, 04:17 AM   #179
Z00M's Avatar
I fired up my Mongoose today with the R3 engine aboard.
The problem I have is that the clutch flyweights on the K factory clutch seem to be able to pop out the sides and wedge between the flywheel and the backplate of the clutch pad. This causes the clutch to lock up and gives me direct drive to the motor and when I brake, of course the engine cuts out.
Any clues?
Cheers,
Mike.
XRAY XB4
Old 02-01-2005, 05:55 AM   #180
Default clutch sticks
hey zoom i had the same problem when i first put mine together ,
if the clutch is set-up right ,as far as spacing and it spins freely
the clutch disc is sticking on the three pins on the flywheel clean the holes up with a reamer or small dremel bite and make sure the disc slides smoothly on the pins and your problem will be fixed
isuzuguy is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
