Old 10-17-2005, 09:56 AM   #1726
YBSLOW's Avatar
Default Thanks Walter
Originally Posted by wad
Congratulations Brad, good job
Thanks,
Maybe next year you can make it. My car worked great and I ran the solid spool up front in the main.
C'ya at Rev.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 10-17-2005, 09:58 AM   #1727
YBSLOW's Avatar
Default NO katana.
Originally Posted by quietstorm76
Mr. Richey,
How can I find more info on your engines? Are they modified Katana engines?
Currently Dennis is modifying the O.S engines .12 and .21
YBSLOW Racing
Old 10-17-2005, 12:21 PM   #1728
critterracing's Avatar
Default need clutch help
im new to this car and im having centex issues. no matter how its shimmed one of the 3 shoes pops out and stalls the motor. its getting lodged between the flywheel and plate.
RDlogic tech support said the plate could be warped. i tryed another one off a customer car and 2 shoes poped out instead of the one.
this is a brand new car that i cant even get it off the bench. rd is selling me k1410-4 new plate. funny how i have to buy new parts before i could drive it. i dont think this will solve the problem.
the clutch im thinking is the latest one it has a blue and grey pinions. any sugestions would be greatly appritated. is there another brand centex peeps are using?
thanks
aldo
Crispy Critters Hobby Shop and Raceway
1275 BLOOMFIELD AVE Unit 31 BLDG 6
FAIRFIELD NJ 07004-2729
973 575-0375 https://www.facebook.com/
www.critterhobbies.com www.rcpix.net
critterracing is offline   Reply With Quote
Old 10-17-2005, 12:51 PM   #1729
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
You have PM
Walter Diaz
wad is offline   Reply With Quote
Old 10-17-2005, 12:57 PM   #1730
Registered User
xrcbuggy's Avatar
Check your shoe's pin holes,bore them if necessary for smooth operation. They are a littel small, mine was any way( make sure the shoe goes back & forth smoothly).If you use the red spring, you need to go in more than 0.5mm which the manual suggest. I went w/next spring up, I think it is orange & set it flush. I think the clutch shoe's holes are the problem, they are too tight & do not go back & forth smoothly.
xrcbuggy is offline   Reply With Quote
Old 10-17-2005, 03:32 PM   #1731
Bundy_Bear's Avatar
Originally Posted by Bundy_Bear
Guys,
Is the Evo III the same as the Mongoose? Does the Evo III have the S Class gears ready for the UFO clutch?
BB
Edit: 17-10-2005 @ 10:00pm
Ok, After some further research i noticed that the Mongoose (K1487) comes with a different chassis to the Evo III (K1479). So i am going to take a stab in the dark here an say that in order to run the UFO clutch on the Evo III i would need to purchase K1492 S Class gears, K1487 C/F Side mounts & would i need to get a different chassis.... I think i am mega confused now, time to hit the sack
BB
Anyone?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 10-17-2005, 03:54 PM   #1732
Bundy_Bear's Avatar
On the other side of the coin if i was to purchase the Mongoose kit is there anything special i need to do to run the UFO Clutch?
BB
MissMooRC Racing
Old 10-17-2005, 04:04 PM   #1733
duneland's Avatar
critter,
If by shoes you mean flyweights (centax style has only one shoe). It must be shimmed with too much play. It should not be possible to have the flyweights come out far enough to get stuck when properly shimmed. Re-shim to a bairly detectable amount of end-play. Adjust engagement with adj nut & if necessary, different spring.
duneland is offline   Reply With Quote
Old 10-17-2005, 04:20 PM   #1734
wad
wad's Avatar
BB
You don't need anything special to run the UFO clutch, you can use the same gears non s-class, or if you want you can use the s-class also.
Chassis does not matter.
Remember that if you use 1st pinion s-class you have to use 2nd spur s-class.
2nd pinion & 1st spur are the same.
Walter Diaz
Old 10-17-2005, 05:50 PM   #1735
thanks for the help guys. i think what i did was f the flywheel up. i put the car together at my home instead of the shop and i grabbed the flywheel hard enough to slightly egg shape it. i ordered a new flywheel so i just have to wait now. i'll let ya know what happens.
thanks again
aldo
Old 10-17-2005, 06:01 PM   #1736
Trader Rating: 44 (100%+)
Originally Posted by 007kel
Hey has anyone heard of the G4 chassis from KFactory, part#1499? A 4mm 7075 chassis w/carbon stiffeners? Anyone ever see it? And if so, how does it handle?
it looks really trick, doesn't it?
but i think it is an absolutely UNnecessary hop-up. not to mention, expensive too.
the chassis is not a weakness in G4.
there are other better ways to spend ur money ...
wyl03 is offline   Reply With Quote
Old 10-19-2005, 10:56 AM   #1737
YBSLOW's Avatar
Default K-Factory
Does anyone have the part numbers for the K-factory red flyweights, red clutch shoe and aluminum clutchbell for the UFO clutch?
YBSLOW Racing
Old 10-19-2005, 02:31 PM   #1738
Regional Moderator
daniz24's Avatar
http://www.kfactoryracing.com/prolis...=date&proname=
daniz24 is offline   Reply With Quote
Old 10-19-2005, 02:36 PM   #1739
YBSLOW's Avatar
Default Thanks Daniz24
Thanks for the linK!
YBSLOW Racing
Old 10-19-2005, 10:56 PM   #1740
fenix's Avatar
hi guys กกก
Can i use the belts of the g4 in to the trinity reflex?
fenix is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
