Old 10-06-2005, 12:26 PM   #1681
afm
afm's Avatar
Wad, this is the new web site address with G4's setups, but the blank one is in the old address i posted before
http://www.cmldistribution.co.uk/car_setup.php
AFM
afm is offline   Reply With Quote
Old 10-06-2005, 01:11 PM   #1682
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by afm
You can get a blank setup sheet here
http://www.cmldistribution.co.uk/cml_setup.htm
Scroll down the page to Blank set-up sheets and you'll find the TMG4 sheet.
Also you'll find a lot of set-ups from different drivers and tracks, for rubber and foam, That is the old web site, also you'll find more set-ups in their new web site.
AFM
Thanks AFM, I just need a blank one.
Walter Diaz
wad is offline   Reply With Quote
Old 10-06-2005, 01:15 PM   #1683
wad
wad's Avatar
How can I write on them, do I need a special program?
Walter Diaz
Old 10-06-2005, 06:21 PM   #1684
Motorman's Avatar
Toledo setup: Traction mid to high. Smooth track.
Traction compound used: Mountain dew syrup/caster/methanol
Front:
80 wt shock oil 2 hole pistons
Aqua springs
bar flat
caster 2mm in front
toe 1 degree out per side
camber 1.5
Tires 37 shore sidewalls superglued
Tire dia 61mm
High ackerman steering blocks tie rods in front holes
Shock locations layed all the way down
Ride height 4mm
one way
Rear:
80 wt shock oil 4 hole pistons
Fuccia springs
no bar
camber 4 degrees
camber link top outer bottom inner
Toe 2.5 per side
Tires 40 shore
Tire dia 61 mm
shock locations stood up 2 holes
ride height 4.5
diff oil 25000
Gearing & Clutch
clutch standard, stock shoe, big clutchplate,orange spring
Spring setting 2 threads showing, fairly high clutch engagement.
18 internal gear ratios
18/23 pinions Used 24 during qualifying with 59 dia tires
51/45 spurs
two speed shift point high 100ft mrk
Body Mazda 6
Engine Richey Modified X12 (High RPM engine)
Pipe RD logics 62505
Head shimming .021
Nitro 30% Byron limited comp
Fuel mileage tight 5:15 plus 1 lap
performance predictable all day
If traction is low lower diff oil to 10000 and change to solid front axle. change front tires to 40 or 42.
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 10-06-2005, 06:29 PM   #1685
Motorman's Avatar
Cincinatti setup: Traction mid to high. Smooth track. huge straightaway 270 ft
Traction used VHT
Front:
Aqua springs
bar flat
caster 2mm in front
camber 1.5
Tire dia 61mm
one way
Rear:
Fuccia springs
no bar
camber 4 degrees
Toe 2.5 per side
Tires 40 shore
Tire dia 63 mm
diff oil 30000
Gearing & Clutch
clutch UFO, stock shoe, no weights in flyweights ,orange spring
Spring setting 0/.5 threads showing, fairly high clutch engagement.
18 internal gear ratios with 19 side pully for 3.5mm overdrive
18/24 pinions-63mm rear tire used to stay away from 25 pinion and 19 internals if possible
Other option is 19 internals with 20 side pulley 19/24 pinions raise shift point to 160 ft mark
51/45 spurs
two speed shift point high 130ft mrk
Body Alfa Romeo
Head shimming .021
performance: we will see
Old 10-06-2005, 07:53 PM   #1686
afm
afm's Avatar
Yes you need the complete Adobe read and write program, but that one costs it's not free like the read only version.
AFM
Old 10-07-2005, 12:30 AM   #1687
fenix's Avatar
Hi i have a doubt..
i`m tryining to put the centax clutch on a os 12 tr engine but i need tu use 4 shims after the thrust bearing is this normal?
If i use only one like the manual says there is lot of play between the bell and the clutch shoes...
thanks in advance ..
fenix is offline   Reply With Quote
Old 10-07-2005, 12:36 AM   #1688
Regional Moderator
daniz24's Avatar
Originally Posted by fenix
Hi i have a doubt..
It is absolutely very normal
daniz24 is offline   Reply With Quote
Old 10-07-2005, 12:41 AM   #1689
wad
wad's Avatar
Hi i have a doubt..
It's ok, I had to use 3 or 4 also for my OS engine, but that doesn't matter, every engine is a little different. Make sure that the play goes between 0.3 to 0.5mm
BTW: I was looking at some pictures of Race Tracks in Mexico, you guys have really good tracks, the one in Morelia looks really good.
Walter Diaz
Old 10-07-2005, 02:20 PM   #1690
fenix's Avatar
Thanks wad ĦĦĦ
I live in Monterrey Mexico as you know here we race in a parking lot track and you know the owner (el guty) Cesar Ayala..
I saw a few of your posts in mircmicro.com
Thanks for you reply guys ...
Said < --------- Is my name weird but is my name
Old 10-07-2005, 02:57 PM   #1691
wad
wad's Avatar
Thanks wad ĦĦĦ
It doesn't matter as long as you have a name.........
Walter Diaz
Old 10-07-2005, 07:51 PM   #1692
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Thanks wad ĦĦĦ
Hi Fenix, are you from D.F. ? ... where are you running ?
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 10-07-2005, 08:00 PM   #1693
fenix's Avatar
hi tabushi ĦĦĦ
No, i´m from Monterrey, Nuevo Leon,Mexico.
We have a parking lot track and offroad track.
If you need anything from here, just let me know and i will help you ..
Old 10-07-2005, 10:01 PM   #1694
JABRONI's Avatar
Default FENIX
Fenix,
You were pitting right behind us but I had no idea thAt
you were looking for advice on what to do.
I was a pitman for a Mongoose driver and noticed that you
had purchased a Mongoose from a lottery winner.
At that point it was to late, however, if you need anything
or any advice PM me and I will try to help the best I can.
Scott
JABRONI is offline   Reply With Quote
Old 10-08-2005, 08:57 PM   #1695
fenix's Avatar
thanks ĦĦĦ
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
