Old 10-03-2005, 04:16 PM   #1651
quietstorm76's Avatar
It's a permenant track with medium traction. Mostly flowing turns.
quietstorm76 is offline   Reply With Quote
Old 10-03-2005, 04:32 PM   #1652
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by quietstorm76
My Mongoose is always loose in the rear. Here is my setup.........what am I doing wrong?
Front
40 shore tires
1.5 camber
40 oil
.5 toe out
caster all shims to the rear
ride ht 5.0 mm
rear
37 shore
3 camber
40 wt oil
2 deg toe
ride ht 5.0 mm
Ok, I will go:
sylver springs (stock)
caster to the middle
ride heigh 4.5 front
all the shock in the lower position - front & rear
rear diff with 10000 oil
0.5 rear toe in (too much toe make this car loose in the rear)
if still not rear traction I will disconect the rear slwaybar
Walter Diaz
wad is offline   Reply With Quote
Old 10-03-2005, 04:34 PM   #1653
wad
wad's Avatar
What body are you running?
Walter Diaz
Old 10-03-2005, 04:44 PM   #1654
Thanks for the info.I run the new stratus body, I think it's a 3.0.
Old 10-03-2005, 04:59 PM   #1655
wad
wad's Avatar
I noticed that the new stratus make the car loose in the rear and a little sensitive in the front, I will try Mazda 6 or for more rear traction the Alfa Romeo by Team Losi.
Walter Diaz
Old 10-03-2005, 05:07 PM   #1656
wad
wad's Avatar
Also try to run same compound tires front & rear
What spring are you using on the steering rack? the stock one?
If yes, tight it all the way, a loose steering will make the car loose in the rear also.
Walter Diaz
Old 10-03-2005, 05:11 PM   #1657
wad
wad's Avatar
Try the droops at 0, front & rear.
Lots of post, sorry I got excited................lol
Walter Diaz
Old 10-03-2005, 05:17 PM   #1658
impalabob64's Avatar
Send a message via AIM to impalabob64
Default hey
the problem is you do not have enough rear toe,3.5,or 4 degree toe will solve your rearend problem.also try 1.5 toe out in frt.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 10-03-2005, 05:30 PM   #1659
Ok the steering spring is stock. As for the droop you said 0....as in no lift at all?
Old 10-03-2005, 05:43 PM   #1660
wad
wad's Avatar
Ok, tight the spring for the steering all the way.
The droop should be 0, without tires, the front and rear hubs should be at the same level as the chassis
Walter Diaz
Old 10-03-2005, 05:53 PM   #1661
ok i'll make all the changes. I really thank you for your help.
Old 10-03-2005, 06:24 PM   #1662
Regional Moderator
daniz24's Avatar
You can try 2 for front downstop and 4 for rear. If this solve your rear end being loose, you can lower the front downstop to get more steering.
daniz24 is offline   Reply With Quote
Old 10-03-2005, 11:00 PM   #1663
wad
wad's Avatar
No problem, let me know how that goes.
Walter Diaz
Old 10-03-2005, 11:13 PM   #1664
gtrmx's Avatar
Talking
Originally Posted by rcrevolution
hmm the clutch shoes are the same, and the g4 and ntc3 use the same centax clutch
I know this is an old post. I have joined the forum the week after the RD Logics race in Rev and have not had all the time to read all 57 pages on this topic. I am not sure if there was an answer for this question before but let me give it a try...
I am currently using the NTC3 clutch flyweights and clutch shoe in my Mongoose. Bear in mind, though, that the NTC3 and G4 (old kit) used a thicker clutch shoe but thinner flyweights as compared to the current RD Logics Mongoose.
As long as you match flyweights and clutch shoes you should be fine. You cannot use the RD Logics Mongoose flyweights with the NTC3/G4 clutch shoe and viceversa because the overall thickness of the "sandwich of parts" will not be the intended one.
After lots of trouble and help from Wad, I used the NTC3 flyweights (BTW they do not have brass inserts), the NTC3 clutch shoe, red spring with about 1mm tension (I think the red spring was a little soft after all but it finally worked at the B main on Sunday) and the whole set worked fine!! I am just not such a good driver.
Just consider that the weight distribution when the clutch pushes is different due to the different flyweight thicknesses and that could mean you have to use a different spring if using the RD Logics Mongoose kit parts.
BTW I'd like to publicly thank WAD for all his great help during my first incursion into a race out of my home country Mexico!!
gtrmx is offline   Reply With Quote
Old 10-03-2005, 11:22 PM   #1665
wad
wad's Avatar
You are more than welcome!!!!!
You know that you can count with me anytime
Walter Diaz
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
