Old 09-13-2005, 12:33 AM   #1516
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by xrcbuggy
Need to change my grearing for small track. Do I change clutch gear to 18 & 23? How about spur gears do I have to change them? I do not want to change the spur gears if I can? Have you change yours?
Please no lab experiment, there is not much left in the budget.
I have some good news for your wallet. You don't need to change the spurs, they should fit perfectly
Walter Diaz
wad is offline   Reply With Quote
Old 09-13-2005, 12:35 AM   #1517
Three hop-ups I would get are the 1. UFO push clutch, 2. S-Class gear set and 3. the swing rack steering system... For speed and control... the UFO clutch and the S-class gear set are a must have and for the problem-matic slider steering system, the upgraded swing rack set-up is are a must have... Don't have the part numbers, but you can go to www.rd-logics.com and order direct... Good luck and happy racing
RC_Alan
Originally Posted by British Menace
Hi All,
I've been away from the sene for some time. You can tell cause I have the original 'E' class !
Anyway,
I have most, almost all the K factory parts on my car, except the more up to date stuff.
I still have the 'sliding' steering and the original push type clutch.
I have the original steering knuckles also and stock gearing that came with the car.
My question.....?
Oh yes, my question.........lol
My car drives prity good.....infact its great! I love the car. It has loads of steering, so much so I was having trouble getting 'enough' rear end grip.
I'm at only 60% steering! Anyway.....
What would you guys suggest would be the worthwhile improvements for my car?
Bare in mind that I am a maintenence fenatic........I strip down (to the last nut an bolt) the car after every wkend of racing! So I do not mind maintaining the car.
Having previously come from England, I'm used to running on rubber tyers and so am still using them now.
Current set-up,
Front:
25lb springs, 40 wt oil, stock pistons (with o rings around the pistons though), 0.5 to 1 degree toe out, shocks laying down using K factory 3mm chassis. And 5mm ride hight.Anti-role Bar...Flat. Using Kyosho's adj' geard diff.
Running about 120,000 wt grease in.
Rear:
32lb springs, 50 wt oil, pistons as above,3 degree toe in, shocks sting fully upright on K factory tower. And 6mm ride hight.Anti-role Bar...45 Degrees.
1000 wt fiff' grease. Camber link: Inner is uppermost hole,outer is 2nd hole down.
I use the titanium ball cups, low friction belts etc.
Ant help would be greatly appreciated as although I've had the car for over a year I only started driving it 1 month ago !
Also....I'm on Iowa/Illinois border. Any good tracks around?
Thanks.
rc_alan is offline   Reply With Quote
Old 09-13-2005, 08:49 AM   #1518
British Menace's Avatar
Thanks for the reply "Rc Alan".
The UFO clutch....... whats different about that improvement?
I've heard some talking of replacing the clutch spring with a super hard one in the stock clutch and junking the brass inserts in the shoes.
Would this improve the stock clutch much?
As funds are still a little tight, this on the face of it, sounds the cheeper option.
What do you think?
Thanks again for the info' !
Tony
British Menace is offline   Reply With Quote
Old 09-13-2005, 08:56 AM   #1519
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
RCMart have the UFO for US$ 75 ... how much is in USA ? ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 09-13-2005, 09:15 AM   #1520
Tabushi's Avatar
Originally Posted by Sow&Steady
Well done Tabushi.
Thanks a lot ...
Here is a little video :
http://www.rcpics.net/img/64752
cya !
Old 09-13-2005, 09:27 AM   #1521
afm
afm's Avatar
The UFO clutch....... whats different about that improvement?.......
Tony
The UFO clutch is a completely different design which really makes a difference... read here
http://www.kfactoryracing.com/produc...me=G4&id=K1497
AFM
afm is offline   Reply With Quote
Old 09-13-2005, 11:26 AM   #1522
rcrevolution's Avatar
Send a message via AIM to rcrevolution
hey does the RD Mongoose come with the updated swing rack already?
rcrevolution is offline   Reply With Quote
Old 09-13-2005, 11:29 AM   #1523
YBSLOW's Avatar
Default Swing rack
Yes it does.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
Old 09-13-2005, 01:09 PM   #1524
k
i might look into the UFO clutch $75 is alot better then $115.
will make a difference in acell?
i have the mugen super hard spring on the way, should I just try that and see how I like it?
Old 09-14-2005, 11:41 PM   #1525
freefallmarine's Avatar
Hey, Guy's trying to figure out how to put a sterring servo linkage in my buddies mongoose? he left me the car but no instuctions. the servo arm linkage seems to bind with the front bulkhead. Any trick's i should know? Thank's. C.
freefallmarine is offline   Reply With Quote
Old 09-14-2005, 11:43 PM   #1526
wad
wad's Avatar
I just use the dremel on the bulkhead.
Walter Diaz
Old 09-14-2005, 11:52 PM   #1527
Walter,
Is there a race still this coming weekend or just practice?
EdwinF is offline   Reply With Quote
Old 09-14-2005, 11:57 PM   #1528
wad
wad's Avatar
Originally Posted by EdwinF
Walter,
Is a race on saturday morning, until 2 or 3 I guess
Walter Diaz
Old 09-15-2005, 01:35 AM   #1529
Wow... I'm here asking the question now... I've been using the S-Class gears since the came out and always have had a problem with the gears stripping... Only when I use the 2nd speed gearing of 25/46 or 25/45... My shift point is set to shift alittle early just so that it does not hit so hard and my gears are new.... I went through 6 sets of gears over the weekend... My mesh is correct and all my motor mounting screws were tight... I'm telling you I know how to set up the car... I believe that it's the plastic used in the S-Class gears that's causing this problem... Much more softer then the original gears... Motorman, AFM or anyone that has an answer to this problem.... Weekend practic is one thing.... Dropping out of a race is another.... Any quailty input is much apprieciated...
I'm using on the first gear 19/52 and 2nd is like I said 25/46 or 25/45... I've seen others having the same problem and they come up and ask me what's gives??? Why are my gears stripping??? And I'm like they are...
RC_Alan
Old 09-15-2005, 02:44 AM   #1530
Registered User
xrcbuggy's Avatar
I had some gearing question myself too, and was told, to keep the difference in No. of gear tooth the same. So original clutch gears is 24-19=5, & spur gears is 51-46=5. Also 51-24=27 & 46-19=27. Now how good is this information? I am not sure, because did not try them yet. I did send an email to Team Magic to confirm this information. I talk to dave at RD logics & he told me if I change my clutch greas, I have to change spur grears too, well I am so confused which is not funny at all. We need a mechanical Engineer to charm here.
xrcbuggy is offline   Reply With Quote
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
