Old 09-09-2005, 04:20 PM   #1501
rcrevolution's Avatar
Send a message via AIM to rcrevolution
is it me or is the stock toe angle for the mongoose too much?
rcrevolution is offline   Reply With Quote
Old 09-09-2005, 04:23 PM   #1502
and dragon, i have two questions for you.
1) what screws are you using? where can I get them? do you have a link and price?
2) whats that on you pressure line?
Old 09-09-2005, 06:43 PM   #1503
nitrodude's Avatar
Thanks Mototrman, Uneke and Daniz for the replys.
One more question though, what gears does the car come out of the box with?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 09-09-2005, 08:40 PM   #1504
GMartinez's Avatar
Trader Rating: 85 (100%+)
You will need to start off with 0 degree toe looks like 2 degree toe in
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-09-2005, 08:42 PM   #1505
Piyo Piyo's Avatar
Re-adjust your left-right steering turnbuckle. Your car has too much toe-in. Start with zero-toe.
VIOLA ARIELLE & FLOREN ISABELLE
Piyo Piyo is offline   Reply With Quote
Old 09-09-2005, 09:39 PM   #1506
hey someone said they were running the mugen super hard spring in their clutch.
what do you think if I replace the mongoose red spring with the mugen hard spring?
Old 09-09-2005, 10:03 PM   #1507
Moderator
Uneke's Avatar
Send a message via AIM to Uneke Send a message via Yahoo to Uneke
Exclamation
I was the one who used the super hard spring. I didn't use the hard spring because it didn't seem that much harder than the stock red spring for the UFO clutch.
Uneke is offline   Reply With Quote
Old 09-09-2005, 10:05 PM   #1508
Moderator
Uneke's Avatar
Exclamation
19/24 and 51/46
Old 09-10-2005, 11:47 AM   #1509
can i use the super hard spring with the stock centax clutch the mongoose has the K1410
Old 09-11-2005, 02:38 PM   #1510
Nitro Tech
dino.tw's Avatar
I use Mugen Optional Spring(super hard#H0767) with K1410 for a long time.
The gap between flywheel nut and adjusting nut is almost flat.
From the latest race I started to use the UFO clutch(K1497),I thought I won't change back to K1410.
Hope this help...
dino.tw is offline   Reply With Quote
Old 09-12-2005, 08:02 AM   #1511
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Well guys ...
Yesterday was the 2nd race at my Club ... we run 200mm touring cars IFMAR based rulebook but with rubber tires ...
I got 1st place ... yesterday was a holliday here so just 6 pilots appeared for 200mm ...
Couple of pics :
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 09-12-2005, 10:01 AM   #1512
British Menace's Avatar
Default G4 (E class) ?? Improvements
Hi All,
I've been away from the sene for some time. You can tell cause I have the original 'E' class !
Anyway,
I have most, almost all the K factory parts on my car, except the more up to date stuff.
I still have the 'sliding' steering and the original push type clutch.
I have the original steering knuckles also and stock gearing that came with the car.
My question.....?
Oh yes, my question.........lol
My car drives prity good.....infact its great! I love the car. It has loads of steering, so much so I was having trouble getting 'enough' rear end grip.
I'm at only 60% steering! Anyway.....
What would you guys suggest would be the worthwhile improvements for my car?
Bare in mind that I am a maintenence fenatic........I strip down (to the last nut an bolt) the car after every wkend of racing! So I do not mind maintaining the car.
Having previously come from England, I'm used to running on rubber tyers and so am still using them now.
Current set-up,
Front:
25lb springs, 40 wt oil, stock pistons (with o rings around the pistons though), 0.5 to 1 degree toe out, shocks laying down using K factory 3mm chassis. And 5mm ride hight.Anti-role Bar...Flat. Using Kyosho's adj' geard diff.
Running about 120,000 wt grease in.
Rear:
32lb springs, 50 wt oil, pistons as above,3 degree toe in, shocks sting fully upright on K factory tower. And 6mm ride hight.Anti-role Bar...45 Degrees.
1000 wt fiff' grease. Camber link: Inner is uppermost hole,outer is 2nd hole down.
I use the titanium ball cups, low friction belts etc.
Ant help would be greatly appreciated as although I've had the car for over a year I only started driving it 1 month ago !
Also....I'm on Iowa/Illinois border. Any good tracks around?
Thanks.
British Menace is offline   Reply With Quote
Old 09-13-2005, 12:14 AM   #1513
Registered User
xrcbuggy's Avatar
I would get K1471 (Brake Bracket W/Alu. belt tensioner) & K1474 (New Alu. middle mount) make sure these parts fit G4 E calss the 2 parts above are for Mongoose G4.
xrcbuggy is offline   Reply With Quote
Old 09-13-2005, 12:30 AM   #1514
Sow&Steady's Avatar
Originally Posted by Tabushi
Well guys ...
Couple of pics :
Well done Tabushi.
http://3hobby.net REVISITED V2 - Its on steroids!
https://www.facebook.com/ssteady
Sow&Steady is offline   Reply With Quote
Old 09-13-2005, 12:30 AM   #1515
Registered User
xrcbuggy's Avatar
Need to change my grearing for small track. Do I change clutch gear to 18 & 23? How about spur gears do I have to change them? I do not want to change the spur gears if I can? Have you change yours?
Please no lab experiment, there is not much left in the budget.
RS4 RTR 3, Rdlogics mongoose, tc4 parts car stanislow R/C Items: For Sale/Trade 22 05-02-2008 08:50 PM
RDLogics G4 Mongoose 4 Sale rhazzed R/C Items: For Sale/Trade 0 03-21-2006 08:39 PM
rdlogics mongoose for sale FRP R/C Items: For Sale/Trade 0 10-10-2005 02:46 PM
wtt: rdlogics mongoose for 1/12 car chrisw R/C Items: Wanted to Buy 5 08-26-2005 01:22 AM
NIB RDLogics Mongoose G4 i_like_f150s R/C Items: For Sale/Trade 16 02-24-2005 01:57 PM
