Old 07-12-2011, 09:19 AM   #1
Default Axial engines??????????????
So I'm kinda stuck on what engine to get for a truck I'm building. Axial .28RR-2 or Axial .32RR-1. Both big block, but the .28 has a 39,000 rmp max and the .32 has a 37,500 rpm max. You would think bigger means more power but I kinda thinking that might not be the case here. I'm kinda new to the nitro world and any help would be much appreciated.
HectikMind7 is offline   Reply With Quote
Old 07-12-2011, 10:19 AM   #2
Grenade10's Avatar
Trader Rating: 37 (100%+)
Based on what you are putting the engine in, you probably should post this in the Off Road thread.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 07-12-2011, 11:14 AM   #3
You posted it here , so I'll answer it here. The .28rr is more rpm and would work great for racing. If you use the .32rr , it will have tons of torque for the truck and not quite as much on top. If you want to pull wheelstands go with the .32.
People spend their lives worrying about death. I'm sliding in broadside h ollering "Wow, what a ride"
spooky 1 is offline   Reply With Quote
Old 07-12-2011, 11:20 AM   #4
C-Trickle's Avatar
+1. If it was my truck I'd go with the .28, much more rpm. The .32 is a complete
crazy torque monster. But it has an ok midrange with no, zero top end. For bashing or racing I think the .28 has what ya need.
What truck will it be going in?
C-Trickle is offline   Reply With Quote
Old 07-12-2011, 04:05 PM   #5
Suspended
Might be an on road truck. Plenty of on road that is not a touring or pan car.
RogerDaShrubber is offline   Reply With Quote
Old 07-12-2011, 04:29 PM   #6
DanELITE's Avatar
Send a message via AIM to DanELITE
get the Axial .28 Spec 2S [AXI0320] i had the original Spec 1S engine and i had over 10G of fule in it and did not get anything for it good motors for bashing.
or Axial .28RR-2
MBX-6-B6-2057pipe-werks pro clutch-hitec 985 & 965
MBX-6T-B5-JP3pipe-werks pro clutch-hitec 985 & 965
MBX-6E ECO Castle 2200kV-LIPO x2 2S Venom 20C 7.4V/5000mAh &
Gens ace LIPO 30C 7.4V/5300mAh Hardcase ROAR approval-hitec 985
DX3R-Byron 30%
DanELITE is offline   Reply With Quote
Old 07-12-2011, 08:00 PM   #7
Suspended
When it comes to the best ,there is only the OS .28XZ modified by ABmods !!!!!! Axial engines don't even come close !!! Checkout the ABmods dyno graphs at www.abmods.com , and you can see the difference.......
bertrandsv87 is offline   Reply With Quote
Old 07-13-2011, 06:22 AM   #8
Grenade10's Avatar
Did not want to send him away, just felt he would get better info from the off road section.
I run several Axial engines in my Ofna DM-1, currently have three in my box. All .28's Spec 1 - good engine with torque and some top RPM's - Spec 2 which is similar to the first and a Spec 2 RR black engine that I have not broke in yet.
One area that I have had issues with, has been the carb. Seem to leak around the mid needle and one carb would not tune well at all. Changed the carb and all things became good.
Old 07-13-2011, 09:02 AM   #9
C-Trickle's Avatar
On one of my Axials I've had the midrange fall out. Carb sealed it in and no probs since.
Grenade10 get that RR-2 broken in and drop it in your DM-1. I have one in my
Inferno and it's just a monster of an engine.
Old 07-16-2011, 02:33 PM   #10
Sorry, thought I had posted this in off road. It's going in a Monster GT that I'm building from the ground up, all aluminum parts, custom painted body, Axial 8-spoke 40 series beadlocks. Not sparing any cost. Going to be a show truck and parking lot queen for a while or until I roll it be accident.
I can always change the spur and clutch gear to get more top end though, right?
Old 07-17-2011, 09:18 AM   #11
C-Trickle's Avatar
Well if thats the case. Go ahead and slap that .32RR in there. Drive it before ya regear it though. You may like that insane bottom end.
Old 07-17-2011, 10:19 AM   #12
Honestly, I think I'm going to be looking for a 50-50 set up. Love watching them scream by, but still want it to step off with out hesitation. I put the 3 speed in my Savage X and I love it. Have more top and bottom end. And we have a free to the public out door track about a mile from my house so I'll be down there a lot. So I don't really want it coming off the ground every time I gun it.
Old 07-17-2011, 07:18 PM   #13
C-Trickle's Avatar
Well. Either engine sounds like it should do what you're needing. For just awesomeness put in the .32RR. Then you *almost* always win with the "i have the biggest engine" war. I put a .32RR in a 8.0MGT at the shop i work part time at. That thing had so much power compared to the 8.0. Just match the engines with a good top end pipe and call it a day.
Axial Engines? jaytowilk Monster Trucks 8 12-29-2009 06:32 PM
Axial Engines Mugen Basher Nitro Off-Road 18 05-03-2009 07:16 PM
Axial Engines thread Axial Racing Onroad Nitro Engine Zone 164 10-06-2008 06:48 PM
axial engines hillclimber R/C Items: For Sale/Trade 11 09-09-2007 06:55 PM
