Old 05-18-2002, 10:44 AM   #1
Default THrottle linkage problem...
I have a question about my throttle braking. For some reason Its backwards..... when i put it to full throttle it applies the brake but when i want to apply the brakes its just like coasting I need help and fast!
LiLRCLoUiE is offline   Reply With Quote
Old 05-18-2002, 10:59 AM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: THrottle linkage problem...
which car you are talking about?
Manticore is offline   Reply With Quote
Old 05-18-2002, 12:11 PM   #3
GregH's Avatar
Send a message via AIM to GregH
Your radio should have a switch for the throttle that says normal or reversed. Check that first, I think you'll find the problem there.
GregH is offline   Reply With Quote
Old 05-18-2002, 02:02 PM   #4
This is on a Picco Integra and i tried the radio and it makes it totally different and it still dosent fix the problem.
Old 05-18-2002, 02:54 PM   #5
RAP66's Avatar
gotta servo reverse.... then pull the servo horn off and reset all your trims back to 0..... then set up your linkages
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 05-18-2002, 10:13 PM   #6
Manticore's Avatar
yeah, as what they said, ensure the servo moves in proper direction with the reverse/normal switch on the TX.
you might have improper timing on the servo and brake linkage. make sure you have a very little bit of drag brake or the brake is "just" free when the servo in neutral position.
the point on the servo horn for brake linkage is also important. it is likely you have your point on the most outter point on your horn which makes brake "on" under full throttle.
You may check this site on information about throttle/brake linkage.
STUPID GT throttle linkage... HELP! B3boy Electric Off-Road 15 03-12-2012 08:41 PM
Revo throttle linkage help!! Associated-08 Monster Trucks 6 01-12-2011 11:23 AM
need help with 8ight throttle linkage mike williams Nitro Off-Road 6 02-12-2008 10:14 PM
how should throttle/brake linkage sit? cant get right. atebit Rookie Zone 2 10-11-2007 08:00 AM
throttle carb linkage ? Nytro Ken Electric Off-Road 4 04-13-2003 12:12 PM
