Old 07-06-2011, 06:37 PM   #16
Suspended
Losi jrx-s type R lcd's fit the Ntc3 without any mods, and are ten times stronger than the biggest AE/MIP cvd's !!! They are about 75mm from end to end, and have about 5mm axles . Just the vibration reduction alone will make them outlast cvd's! As I said before, losi makes other, stronger lcd drives for 8scale gas buggies/truggies that can easily handle more torque/power than any .21 engine can dish out !!! Retrofitting them to the 8scales is the only issue at this point... I have not tried retrofitting one yet because I do not run 8scale, but I bet it could easily be done......
bertrandsv87 is offline   Reply With Quote
Old 07-06-2011, 07:11 PM   #17
wingracer's Avatar
Trader Rating: 24 (100%+)
No one races a NTC3 seriously anymore. All the other cars use a bigger ball and pin. Anything for a 1/8th buggy is probably going to be way too long for an onroad car and might not fit the quick change axle.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-06-2011, 10:35 PM   #18
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Tony Rice View Post
Is there a difference? Some say you get more steering with CVD's. But how? Both do the same thing. Your not changing wheel speed. I have always run CVDs because that was the thing to run. But does it really make a difference?
Tony what I felt in Sedan from cvd's in the rear then going to dogbones
1 less rotating mass & felt the car rotate better sometimes over rotation when the bite came up really high
1/8th have not really felt it just cause were going so fast were dialing in the car for a lot of different reasons making it a little harder to pinpoint but maybe the same effect but others have told me more steering with cvd's
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-07-2011, 09:00 AM   #19
Suspended
I don't care what other people run, I run NTC3, and it's still legal to race one!!!! As for 8scale, you need to go to your machinist and let him find a way to make them fit !!! If you are not so inclined, then wait forever!!!! This hobby is really about building things, and if you can't build anything, keep pushing paper at the office!!!
Old 07-07-2011, 03:13 PM   #20
wingracer's Avatar
Good for you, it's still a good car but no one else runs one so no one is going to need a DCJ that fits it but you.
If the shaft is too long (or too short for that matter), there is nothing ANY machinist can do to fix it. You would have to make one from scratch. If you are going to make one from scratch, what would you need the Losi unit for?
Team Shepherd USA
Old 07-07-2011, 07:25 PM   #21
Suspended
Any good machinist can make the bone part of the dcj from scratch with the required length !!! You just need a good piece of steel to start with!!! If he owns a cnc machine, that will be quick work!!!...
Old 07-07-2011, 08:18 PM   #22
always found CVDs to hold up better.
Rick's Radical Hobby Depot For all your R/C needs!
RRHobbyDepot is offline   Reply With Quote
Old 07-08-2011, 12:28 AM   #23
nitrodude's Avatar
And they will do it for free?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 07-08-2011, 06:44 PM   #24
Suspended
If you want anything in life you have to pay for it !!! I should not have to remind you of that buddy !!!!!
Old 07-08-2011, 06:54 PM   #25
nitrodude's Avatar
Thats the point I was trying to make...
Steven Muller
Ronin Speed Parts
Old 07-08-2011, 07:23 PM   #26
Suspended
Too many lazy people in this hobby!!! If what you want is not available yet, then get off the couch , and go make your own parts !!!
Old 07-08-2011, 08:29 PM   #27
wingracer's Avatar
By all means. Which just confirms my whole point which was that the Losi LCDs are useless for our needs since you will have to make them from scratch anyway.
Team Shepherd USA
Old 07-09-2011, 08:34 AM   #28
Suspended
You have no point! Just complaints !!!!!
Old 07-09-2011, 09:02 AM   #29
wingracer's Avatar
Really? What have I complained about? Everything I have stated is fact. If you don't think so, prove me wrong. Do you always get this worked up every time someone disagrees with you?
Team Shepherd USA
Old 07-09-2011, 06:19 PM   #30
Suspended
Another complaint!!!!! Wow......... You have no solution to the problem!!! Lcd's provide a starting point to solve the problem, not endless complaints. I fitted lcd's in all my cars with a lot of grinding in some cases (m03), but no complaints !!! I only own shaft cars , and if there were a new 8scale shaft kit available, I would get it and find a way to fit lcd drives or any other good set of dcj's in the front, but again NO COMPLAINTS !!!!!!!!!!!!
