Old 10-15-2004, 09:26 AM   #1
Default nitro tc3 faster acceleration
what can i do for faster acceleration, i have a one speed transmission, the only upgrades i got so far are blue aluminum diff cases and blue drive shaft
my car is an escalade truck sittin on chrome wires its so tight
okczy21 is offline   Reply With Quote
Old 10-15-2004, 09:57 AM   #2
Ducati-Rider's Avatar
Default Mo speed
None of your upgrades improve speed or acceleration - they are all eye candy......the truck body sucks for aero, but probably looks good, if you want to accelerate faster, lower the pinion gear on the motor and increase the spur gear off the drive shaft - by changing gear ratio's you get a better jump out of the box.
Ducati-Rider is offline   Reply With Quote
Old 10-15-2004, 12:47 PM   #3
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
uhh....
two words........
TWO SPEED!!
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 10-15-2004, 01:49 PM   #4
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally posted by fastharry
uhh....
two words........
TWO SPEED!!
Old 10-15-2004, 04:03 PM   #5
i didnt want to get a 2 speed cause i only have one place to drive and its not amazingly huge to reach top speeds of what a two speed could probably do, im looking for just amazing jump out the gate, i dont race or anything just strictly for fun
should i get a 20 tooth pinion gear and a 54 tooth spur gear?what would be the best setup?surely someone has done this to their car
Old 10-15-2004, 11:11 PM   #6
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default increase at least 10% of your engine horse power... FOR FREE...
ok... nothing is FREE...
but at least this one is LOW BUDGET ENGINE PERFORMANCE MAKE DO....
http://www.donegal.flyer.co.uk/10%20...ecrets%201.htm
mop
mop_iko is offline   Reply With Quote
Old 10-15-2004, 11:38 PM   #7
ive already done those things to my car, what about these gears, which ones should i buy
Old 10-17-2004, 08:20 PM   #8
bhambrent's Avatar
RB SUPERCARGER!
bhambrent is offline   Reply With Quote
Old 10-18-2004, 01:50 PM   #9
HELLION's Avatar
Default clutch
Put a centax clutch in it! Best buy for fast acceleration!!!
HELLION is offline   Reply With Quote
Old 10-19-2004, 04:07 PM   #10
Originally posted by bhambrent
RB SUPERCARGER!
mppa.biz supercharger
c496 is offline   Reply With Quote
Old 10-20-2004, 07:31 AM   #11
HELLION's Avatar
Default yep!
I feel a bet coming on
Old 10-21-2004, 07:52 PM   #12
what size pinion and spur gears are stock with the nitro tc3(not factory editionand one speed tranny)
Old 10-22-2004, 07:42 PM   #13
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Go 2 speed.... your stock gear ratio will be your second and you'll run a higher numerical first... usually 4 teeth apart...
Misconception... 2 speeds don't necessarily give you any more top speed... They increase accelleration and make your engine not have to work so hard...
Oh yea... Get a real good handling body and new tires.... The truck with the wire wheels just won't cut it....
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 10-22-2004, 11:16 PM   #14
i have good tires they are hpi 15.00 for two and they grip real well and they are holding up real well too, i dont race plus ithink that body looks tight, would it even make a difference if i switched the spur and pinion gears with my single speed tranny, what size are the stock gears(teeth )
Old 10-23-2004, 06:34 PM   #15
vtl1180ny's Avatar
If the body looks too tight you may need to trim the wheel wells a little....
If you go to a smaller pinion or larger ring gear it will accellerate faster... Then you get to test the grip of your tires... 15 for 2 means nothing to people who actually race....
I still lurk....
more acceleration, same top speed? streetracer745 Monster Trucks 8 04-14-2007 09:52 PM
car not responding on acceleration uniquexme Electric On-Road 23 05-21-2006 12:06 AM
slow on the acceleration cheehtae Monster Trucks 9 05-18-2005 07:05 AM
RS4 Slow Acceleration Everton Nitro On-Road 13 06-21-2004 05:21 PM
nitro or electric faster bugbusters Singapore R/C Racers 71 07-30-2002 08:01 AM
