Old 06-28-2011, 11:05 PM   #1
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Default Motor Problems
I have an RB Xenon that I got used with my 1/8 scale. The motor is practically brand new. The pipe I have with it is a Sirio 2013 with a short header. The problem I am having is, the tune is all over place. It will have a lean bog going down the straight, but load up in the low speed areas and come off at 152 degree. Also, I went ahead and sealed the motor. In the past, has anybody had the same problems? Any help would be great.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*Daves RC Track*
ChadB. is offline   Reply With Quote
Old 06-28-2011, 11:29 PM   #2
nitrodude's Avatar
You pretty much answered the question yourself. If you have a lean bog on the straight, richen the top, and if it loads up on the infield, lean the bottom.
Start by richening the top, then dial in the bottom. Keep in mind that these motors are very sinsitive to overheating, if you're lucky yours is still fine. Its a very fast motor though, I used to have one.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-29-2011, 12:28 AM   #3
Geezatec's Avatar
Bog could also rich or lean condition. How much smoke you emitting. 150 degrees it maybe rich. So lean it a 1/8 turn on your HSN, till it runs evenly. Then turn your LSN slowlyCW. Idle speed may increase, tells its lean condition. Turn LSN CCW till the idle drops. It should take up to 5 seconds for it comes to idle speed.
Geezatec is offline   Reply With Quote
Old 06-29-2011, 02:43 AM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
If it is the AAC version you must keep the temp below 105 degrees celcius, a good tune will give about 90~95 degrees C
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-29-2011, 06:41 PM   #5
ChadB.'s Avatar
I started to richin up the top end about a half of a turn, it helped a little bit. By the end of the day, I had the bottom end turned out 2 and a half turns just to get the car to go half way decently. I would come in for a pit stop and go back out, there was so much smoke coming out, it was ridiculous. I just wasn't sure if this kind of motor had problems with tuning in the past or not. I will keep turning screw until I find the sweet spot.
Chad Burdick
Old 06-29-2011, 06:43 PM   #6
ChadB.'s Avatar
I thought companies went away from this material a very long time ago?
Chad Burdick
Old 06-29-2011, 10:49 PM   #7
nitrodude's Avatar
Once you git rid of the lean bog, start leaning out the bottom, 1 hour at a time, until you have good smoke, but not too much.
Steven Muller
Ronin Speed Parts
Old 06-30-2011, 02:14 AM   #8
Roelof's Avatar
The RB Xenon is made by Starmotor (Sirio) and they still do use AAC. The RB comes in 2 version, the Xenon with an ABC construction and the Xenon-R with an AAC construction.
Old 08-17-2011, 09:15 PM   #9
ChadB.'s Avatar
Hey everyone, sorry I haven't been on here to keep anyone up to date, but I am still having motor problems with the same issues above. I was going through my motor tonight and was checking the head clearance and I came up with 1.10. Is this right? I thought this was suppose to be .30 of head clearance? Anymore help would be great.
Chad Burdick
Old 08-18-2011, 07:17 AM   #10
blis's Avatar
Thinking outside the box, if there is a leak in the tank or lines, then you may be losing fuel pressure hence leaning at top speed.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-18-2011, 08:22 AM   #11
Seems the LSN is too rich and HSN too lean, try to set the other way around
GP: Capricorn C03 1/10 touring, Capricorn C803 1/8 onroad
Engine: Tesla .12 WC, Tesla .21 7 port on-road, Rody VS02, OS 2101
beebone is offline   Reply With Quote
Old 08-18-2011, 10:02 AM   #12
SMcpot's Avatar
Trader Rating: 22 (100%+)
I recently chased down a wandering tune on an old Nova mounted in an equally old chassis. Ended up being the fuel cap seal which had compressed and is now a "seal" in name only.
OP might also want to try a different plug if he hasn't already. How's the compression on the engine? And is it blowing plugs at all?
SMcpot is offline   Reply With Quote
Old 08-18-2011, 03:22 PM   #13
ChadB.'s Avatar
Thanks for the sugestions. I have had 3 different guys try and tune this thing and everyone has been scratching there head. These people are all expreinced too. I thought it could be the tank, so I went and ordered one with some new fuel line. It should be here tomorrow. Back to the head clearance. Does anyone know what the head clearance should be to run 25 percent fuel? Does anyone know if you have to much clearance, would it effect the tuning? The tune on the engine is different every time I take the car out and I cant get the motor past 180 degrees.
Chad Burdick
Old 08-18-2011, 04:02 PM   #14
blis's Avatar
head clearance is often dependent on the altitude you are running at. Sorry I dont know the specific head clearance at sea level.
Old 08-21-2011, 12:15 AM   #15
notch johnson's Avatar
Richen TOP
Lean BOTTOM
GO TO a HOTTER PLUG
www.topnotchseries.com TNT NITRO SERIES ROUND 3 @ DIALED IN RACEWAY 11-19-16
RACE LINE DESIGNS! Track Building Specialist! PM ME
Follow me on twitter @notchzilla or @topnotchseries
notch johnson is offline   Reply With Quote
E-maxx 3906 with EVX-2 16.8 motor problems tightdog1 Monster Trucks 17 05-26-2009 06:06 AM
RC8 motor problems, can you help? H2oSprayer Nitro Off-Road 20 04-26-2008 04:39 PM
Motor problems anthony Rookie Zone 7 11-05-2004 06:13 PM
