Old 10-13-2004, 12:23 AM   #1
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
Default Airtronics MX3 out of range.
ive been having problems with my radio lately,
im running an airtronics mx3 75mhz on ch77 with airtronics 94102 and hitec 625 servos, and on both my nitro and my electric, once it goes past 15-20 meters it loses complete control of the car. im pretty sure its not glitching or anything like that, the transmitter antenna is a little bit harder to extend and retract, but i think thats from nitro residue. The only damage i notice on the whole electronics setup is a small nick on the reciever wire insulation thats less than 1 mm long, and definitely not cut into the wire itself.
i have installed a venom 1100mah rx pack from 4 aa's, but that should be whats causing problems, because i dont use the rx pack on the electric. could i have damaged the rx by plugging the rx pack into channel 3 instead of the batt slot?
please help me guys, i have no idea what could be happening.
R3VoLuTiOn is offline   Reply With Quote
Old 10-13-2004, 05:37 AM   #2
New_Toasted's Avatar
Location: The Milkyway/Planet Earth/Europe/Sweden/Skåne/Malmö
If I guess I'd say it's something wrong with your reciver, if you have an ability to borrow an other RX and test you would get an answer
New_Toasted is offline   Reply With Quote
Old 10-13-2004, 05:40 PM   #3
R3VoLuTiOn's Avatar
anyone else?
Old 10-14-2004, 08:01 PM   #4
HELLION's Avatar
Default yep!!!
Pull out the battery box and stretch your springs a little also remove your crystal and check the pins to make sure they are getting good contact and make sure it's all the way in (radio and reciever)and then the antenna contact. and the battery pack in the car.If this fails to help you then I would open the reciever and check for cuts or breaks in the antenna wire all the way to where its soderd. assuming that the length of the reciever antenna wire has not been alterd and if that still dosen;t help then open the radio and check the wire that goes to the antenna. and one more thing make sure the antenna wire is not touching the other wires to the reciever ,battery and servos I hope this helps you.
HELLION is offline   Reply With Quote
Old 10-15-2004, 12:09 AM   #5
R3VoLuTiOn's Avatar
the reciever wire travels thru the same hole in the reciever box of the ntc3 to get to the antenna tube. im pretty the wires used to touch and there werent any problems?
my antenna was bitten by my cat at the end and she took less than a mm off. but even after that i think it worked fine.
Old 10-15-2004, 12:22 AM   #6
HELLION's Avatar
Default antenna
Did you check every thing else? and I would just replace your antenna wire there cheap but make sure you get the one it calls for
No range drjimmy Rookie Zone 13 09-16-2007 03:01 PM
AM Tx Rx range TeeKuang Malaysian R/C Racers 9 05-05-2007 07:57 AM
McT and range//// sambonee Micro and Mini Scales 0 12-06-2006 11:54 AM
radio range ajg Electric On-Road 1 03-14-2004 12:57 PM
Increasing radio range? Or which radios have longer range if any? VN-TEC Nitro On-Road 23 12-13-2001 09:29 AM
