Old 06-15-2011, 11:40 AM   #1
Questions?? Novarossi conrod
Hi there.
Can anyone tell me the difference between a novarossi conrod 07600 and a conrod 07601? I have a novarossi engine which is either an NS12 or an RS12 but unsure. the con rod that is in the engine atm is a 07600 and my local hobbie stores cannot start it due to the con rod being to long and the piston getting stuck. he is not familiar with novarossi so any help would be appreciated and if i need the 07601? thanks
novarossi 12 is offline   Reply With Quote
Old 06-15-2011, 10:49 PM   #2
Super Moderator
Grizzbob's Avatar
I doubt you'll get much response in the Electric sections, so I'm moving it to the Nitro onroad section, see if that reaches some folks who can help....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-16-2011, 06:27 AM   #3
ok thanks. thought I had put it on the nitro section . anyways I have got photo back from my local hobbie stores so may help to anyone who can help understand what the two different conrods are. the one in the middle of the picture is the old one and the two either side are the new ones which i think are the (07600 conrods). also @ Grizzbob do i need to stay on this thread as you said you have moved it? thanks
Old 06-16-2011, 06:34 AM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
If you don't get an answer. I have a new in the package 7601 Conrod. I will measure the length when I get home today.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is online now   Reply With Quote
Old 06-16-2011, 09:33 AM   #5
asw7576's Avatar
Two different type of conrods :
1. Long stroke ( longer conrod ) : torque oriented : LL5, Plus12
2. Short stroke ( shorter conrod ) : rpm oriented : NSR, NS
I'm not sure if people can use both type of conrod interchangeably.
I dont think its possible to use longer conrod for inside short stroke engines.
Old 06-16-2011, 05:46 PM   #6
Default Conrod
Hi there.
The difference between the 07600 and a 07601 is about 1mm in length the 07600 in your motor probablely cause the piston to hit the head, and will only fit the old engines such as CX series M & MT series 12's will not fit any later model motors.
The 07601 will fit RS, NS, old 3 ct's and will actually fit the new plus series but I have not tried this one and do not recommend.
fairgo is offline   Reply With Quote
Old 06-16-2011, 08:19 PM   #7
lil-bump's Avatar
The 7601 was used all the way up to the 3sct tuned which is a plus. The 353 used a different rod.
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-17-2011, 12:09 AM   #8
Default Conrod
Yes I stand corrected but it was only 08 353 motor that used a 7602 09 on used 7604 or as I said 7601 but don't know how well they hold up.
Old 06-17-2011, 08:59 AM   #9
ok thanks for the replys guys. I think the engine is an rs12 s2 but will take some pictures when I get it back so someone can identify it. does any one have this engine and is it any good as I haven't started it yet? thanks
