Novarossi conrod
Novarossi conrod
Hi there.
Can anyone tell me the difference between a novarossi conrod 07600 and a conrod 07601? I have a novarossi engine which is either an NS12 or an RS12 but unsure. the con rod that is in the engine atm is a 07600 and my local hobbie stores cannot start it due to the con rod being to long and the piston getting stuck. he is not familiar with novarossi so any help would be appreciated and if i need the 07601? thanks
ok thanks. thought I had put it on the nitro section . anyways I have got photo back from my local hobbie stores so may help to anyone who can help understand what the two different conrods are. the one in the middle of the picture is the old one and the two either side are the new ones which i think are the (07600 conrods). also @ Grizzbob do i need to stay on this thread as you said you have moved it? thanks
1. Long stroke ( longer conrod ) : torque oriented : LL5, Plus12
2. Short stroke ( shorter conrod ) : rpm oriented : NSR, NS
I'm not sure if people can use both type of conrod interchangeably.
I dont think its possible to use longer conrod for inside short stroke engines.
Conrod
Hi there.
The 07601 will fit RS, NS, old 3 ct's and will actually fit the new plus series but I have not tried this one and do not recommend.
The difference between the 07600 and a 07601 is about 1mm in length the 07600 in your motor probablely cause the piston to hit the head, and will only fit the old engines such as CX series M & MT series 12's will not fit any later model motors.
ok thanks for the replys guys. I think the engine is an rs12 s2 but will take some pictures when I get it back so someone can identify it. does any one have this engine and is it any good as I haven't started it yet? thanks
