Old 06-08-2011, 07:01 PM   #1
Default Slide carb throttle arm comes loose?
Im havin a problem with my throttle linkage coming loose from the slide carb on my TA NTC3. The engine is a RB .12 but im not sure of the exact model. The throttle linkage has a plastic ball on it with an opening in the ball, the ball on the metal slide carb arm goes into the ball and thats how it comes together.. but after a few runs up and down the street with the car the arm comes off the slide carb.. is there anyway to tighten it up?
Heres a pic of what it looks like
akirahz is offline   Reply With Quote
Old 06-08-2011, 07:35 PM   #2
The ballcup is probably stretched out from wear. It needs to be replaced.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBME1&P=7
Serzoni is offline   Reply With Quote
Old 06-08-2011, 07:54 PM   #3
AH okay, so i gota replace a part.. darn.. well do u know if they make a metal one so i dont have to deal with anymore plastic in that area?
i was told the throttle linkage is brand new though, and it does snap into place like it should and feels pretty snugg but ends up eventually coming off, is there anything else it could possibly be?
Old 06-09-2011, 03:43 AM   #4
itchy b's Avatar
looking at the pic, it seems that the angle of the lincage to the slide is a little too sharp so when you open the throttle it increases the angle and will cause it to pop off.
try turning the plastic pivot which attaches the linkage to the horn the opposite way to reduce that angle, or even swap the brake throttle linkage positions and readjust the servo horn so it still works properly.
You really want the throttle linkage to be as inline as possible with the slide of the carb.
Note, if you do swap the positions you will need to re adjust the collets
-Blitz-Rallyhawk-EX 1.5R-Xpress-P64 Tyrrell-Lotus79-Espirit VTA
EX1.5-SC10 4x4
itchy b is offline   Reply With Quote
Old 06-09-2011, 04:03 AM   #5
Okay i will try adjusting the plasic pivot, as it is loose and can swing all over the place, perhaps it should be tight?
I dont know what collets are? do you mean the two black screws that are on the brake linkage?
Im not sure what you mean by in-line.. like a straight line? so i should move the brake linkage over to the left in the other hole on the horn?
Thanks for your help so far
Old 06-09-2011, 06:54 AM   #6
itchy b's Avatar
Yes inline is more straight line.
Actually having a better look at the pics, it might be less mucking around and easier/simpler to just pop the engine out and rotate the carby around till you can get to the grup screw on the slide ball end adapter.
then rotate that till the ball is on top and closer to the head, which will give you a better angle to your servo and the cup will be able to rotate on the ball enough to eliminate the problem.
After thats done, reset the carb position to where it is now and refit the engine.
I think that might fix your problem the easiest way without messing with the links.
if it still isnt the best fit, you might need to replace the ball end cap for a new one as the one on there might be a little stretched and worn from poping off all the time.
Hope it works and enjoy
EX1.5-SC10 4x4
Old 06-09-2011, 09:23 PM   #7
Ah thank you for the reply good sir!
It seems to be much better now after adjusting the horn, this should work till i can replace the throttle linkage, i did quite a few passes and it never came off once after a half tank of nitro
Thanks for the help man!
Old 06-10-2011, 10:19 AM   #8
itchy b's Avatar
Great to hear you got it working well
Happy running
EX1.5-SC10 4x4
Team losi XXXNT 1/10th stadium truck(mach .15 XR2)!! Boostd2valve R/C Items: For Sale/Trade 7 07-15-2005 03:22 PM
