Old 10-05-2004, 05:35 PM   #1
Default Schumacher Fusion R12
Does anyone know where I can get set-ups and and set-up sheets and/or information for this thing?
PSI Racer is offline   Reply With Quote
Old 10-05-2004, 05:45 PM   #2
PSI Racing's Avatar
Try here.
http://www.racing-cars.com/products....bcategory=Cars
PSI Racing is offline   Reply With Quote
Old 10-05-2004, 06:01 PM   #3
Originally posted by PSI Racing
Try here.
I've checked that site. Is there anything else?
Old 10-05-2004, 06:02 PM   #4
I checked competitionx.com and gearchart.com...all I got was a blank set-up sheet.
Old 10-05-2004, 10:10 PM   #5
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: Schumacher Fusion R12
call Paul Wynn at Schumacher U.S.A. 813-889-9691 he will give you a few set ups
Old 10-05-2004, 10:30 PM   #6
Super Moderator
Marcos.J's Avatar
here is a nice set up that Paul Wynn gave me for my R-12
Front
Mission tower/3
bulkhead/alloy
arm/1
hub/alloy with low-ball
steering/2
arm sweep/0
piston/#2 vari
oil/60wt
spring/28lb
droop/2mm
swaybar/pro-bar mounted to lower arm
castor/thin kwikclip back
camber/neg 2
toe/0
ride height/4.5mm
tire/Take-off 40's(purple) 26mm Go to 43's front when very high-bite
oneway
Rear
Mission tower/3
bulkhead/alloy
arm/1
piston/#2 vari
oil/50wt
spring/25lb
droop/3mm
in-board toe/0
toe-in/2.5deg
rear arm/spaced rear
camber/neg 1.5
ride height/5mm
tire/Take-off 40's(purple) 30mm
Both setups use protoform stratus 2.1
This setup has tons of corner speed
Old 10-06-2004, 10:39 AM   #7
Default Re: Re: Schumacher Fusion R12
Front
Mission tower/3
bulkhead/alloy
arm/1
steering/2
arm sweep/0
piston/#2 vari
oil/60wt
spring/28lb
droop/2mm
camber/neg 2
toe/0
ride height/4.5mm
oneway
Rear
Mission tower/3
bulkhead/alloy
arm/1
piston/#2 vari
oil/50wt
spring/25lb
droop/3mm
in-board toe/0
toe-in/2.5deg
camber/neg 1.5
ride height/5mm
Thanks for the info and Paul's number.
Old 10-06-2004, 10:41 AM   #8
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Schumacher Fusion R12
no problem!
Old 10-06-2004, 11:14 AM   #9
Default Re: Re: Re: Re: Schumacher Fusion R12
no problem!
I'm not too familiar with the car, I just got a hold of it for $100. A buddy of mine is going to bring it over to me mid month from Seattle. Are there any querks with this car? What normally breaks when this thig hit the boards?
Old 10-09-2004, 11:56 AM   #10
Broken R12 parts I've seen:
-lower pivot ball screws
-lower arms
-hub carriers (they don't usually break, but the pivot ball screw breaks and leaves part of it into the hubs, making them somewhat useless)
-lower pivot pins (usually bent, not broken)
-upper arms
-upper suspension mounts
-lower front bumper brace
-front plastic driveshafts (replace with metal). I'm still using the original plastic ones in the back after >10 hours of racing
-driveshaft blades (check those after EVERY run. During practice, after every hard crash. If they look at least a bit suspicious, CHANGE. If they break, they take diff outputs with them -$$$).
-diff outputs (see the previous item)
-rear belts (due to wear & tear really, not crashes). If stone gets caught between belt & diff pulley, it can munch the pulley too.
-siezed clutch bell bearings (again, wear item)
-exhaust pipe of the muffler (happens with all the cars)
It takes a hard crash to break this car, but I've also seen whole suspension of one side wiped off. Never happened to myself though
olev is offline   Reply With Quote
Old 10-09-2004, 12:21 PM   #11
Super Moderator
Marcos.J's Avatar
Default Re: Re: Re: Re: Re: Schumacher Fusion R12
are you guys using the old r-12? the new r-12 team edition is alot more durable than last years!
Old 10-10-2004, 12:05 AM   #12
Z24
I Have The R12 TEAM, and it's a lot more durable. But still somehow the rear DIFF Pulley Fence snaps out. And sometimes the real belt. But other than that it's more resistant. Especially with crashes.
Z24 is offline   Reply With Quote
Old 10-11-2004, 02:42 PM   #13
Default Re: Re: Re: Re: Re: Re: Schumacher Fusion R12
What are the differences between the two versions? I want to know if i bought the old r-12 or the newre one.
Old 10-11-2004, 02:45 PM   #14
Thanks olev and Z24 fot eh info.
Old 10-11-2004, 02:47 PM   #15
Thanks olev and Z24 for the info. That's what i wanted to type.
Schumacher R12 Fusion Fred Perkins Nitro On-Road 549 10-08-2012 04:19 PM
schumacher fusion qcrvr R/C Items: For Sale/Trade 6 05-12-2004 07:30 PM
$200.00 for my SCHUMACHER FUSION R12 etips76 R/C Items: For Sale/Trade 0 10-23-2003 06:15 AM
Getting a new 1/10 which should i get a hpi rs4 3 or a schumacher fusion mohamed_own Nitro On-Road 9 10-19-2003 09:28 PM
Schumacher Fusion Fusion Australian Racing 19 02-02-2003 07:06 PM
