Old 06-04-2011, 09:12 PM   #1
92GTA's Avatar
Default .21XZ-R to replace my .18 TZ(P) Turbo?
I currently run this engine in my car (the one in my sig):
http://www.amainhobbies.com/product_...ide-Carburetor
Physically, would this one fit?
http://www.amainhobbies.com/product_...21M-Carburetor
I wondering if the engine mounts, clutch, etc. would all fit?
Thanks! Alex
http://www.TheFOAT.com/92GTA
Kyosho V-One RRR "Shimo Edition"/Pagani Zonda Body
O.S. .18 TZ(P) Turbo w/11K Slide Carb/O.S. T-1040 Pipe
Futaba BLS451 Digital Brushless High Torque/Speed Servos
Futaba 3PM-X 3-Channel 2.4Ghz FASST Radio System w/R603FF Receiver
92GTA is offline   Reply With Quote
Old 06-04-2011, 10:41 PM   #2
jds5150's Avatar
Thanks! Alex
No, it won't.
jds5150 is offline   Reply With Quote
Old 06-05-2011, 12:40 AM   #3
92GTA's Avatar
Dang it, thought that might be the case but I didn't see any measurements for the mount so I thought I'd check anyway lol.
Thanks!
Old 06-05-2011, 12:19 PM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
It is all about how handy you are......
They even put Chevy V8 blocks into a Mini Cooper so if you are handy with a dril and dremel it is possile.....
You want much CC into that car, the Picco P2 Maxx is the way to go with a direct fit, it comes in a .21 and even a .26 version. Let me remind you these engines are nor RPM monsters so more speed is impossible unless you can change the gearing a lot so you can convert the tons of torque into speed.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-06-2011, 06:23 AM   #5
A guy named Ziggy put a .21 in his V1RRR so it can be done if you have a mechanical apitude.
nitrohead5300 is offline   Reply With Quote
