HPI RS4 Evo+ Glow plug
I was looking to buy some spare glow plugs and it seems HPI R5 is the factory plug. Looked online and its around $8-10 or so a plug. Is there a cheaper other brand plug I can go with that will work? I was gonna order a few to have on hand and if I can save just a couple bucks on each thats quite a bit if I buy several.
What type of plug is it? Standard or turbo?
If it is the stock .15 it takes a regular plug. Even the .18ss does too.
Matter of fact, I don't know of any stock engines HPI uses that use a turbo style plug...
Don't forget heat range can be effected by your location and running conditions.
HTH...
Mark
HTH...
Mark
engine is HPI Nitro Star T3.0. Comes with cold plug standard.
i ran O'donnell Purple in my modded T3.0. Ran great with it. Run the same plug in my modded OS 18CVR's and modded Hyper 21 8ports. They are fairly cheap. Theres a company on fleabay that sells em for 5 for $12 shipped or so
RS4 3evo set up
Greetings,
My 7yr old son is driving the above car and we were wondering how to improve its performance...
We finally got it to shift into 2nd but the the handling was awfull......the car is pretty much stock.......looking at any suggestion....many thanks
As for glow plugs, I used to sell Mccoy plugs for this car. at a hobbyshop they run about $8 but they seem to last the longest for the price. I would run and Mc-59 in colder seasons (early spring or late fall). This is a hot plug so burns hotter, a little less longevity but easier to start and run. In the summer I would run the MC-8 which is a medium. I would never run a cold in a motor smaller than a .21
A good typical rule of thumb for a "basher" is for small block motors .20 and below run a hot plug when its below 50 degrees outside and a medium when 50+ degrees. For a big block .21+ run a medium plug when below 50 and a cold when 50+. this is the rule we lived by in the hobbyshop I worked at.
RS4 3evo set up
Thanks buddy.....
We are on a budget but wld definitely will have a gi at it..what wld you recommend a good but cheap servo, pipe and tire size & hardness....what about the shock springs....thanks....we all excited already...
Evo Steering
Definitely get rid of the plastic steering hardware. I upgraded mine to aluminum links and ball bearings on the steering shafts along with a little faster/stronger servo. It also helps to ditch the AA batteries and get a rechargable hump pack, you'll have more power going to the steering servo (and throttle/brake as well)...
HTH...
Mark
HTH...
Mark
I am going to gather some information for you, and I will post back tomorrow.
RS4 3evo set up
Thanks buddy ...looking forward to hear from you real soon.....
Good servo that isnt expensive is the Hitec 645MG. Can be found for around 25-30 bucks. If you want to spend a little more money, the Hitec 5645MG Digital is good as well.
As for a pipe I believe that motor requires a retangular header pipe to attach to the motor. The best bet for a quick hop up would be to go on HPI-Racing.com and see what pipe they have for it as an upgrade. once you change motors to something faster in the future it will have more options for a pipe and header combination.
Tires are the key to grip. This depends on what surface you are looking to run. The softer the tire typically the more grip you will have however the tires will wear extremely fast. A harder tire will be better as far as wear is concerned expecially if running on the street.
Shock oil and spring combination is another thing that can be tricky. Again in a setting where you run it in the street, the surface is going to varie so much that spending alot of time working with the shocks will get frustrating. If you take it to a track however where the surface is consistent throughout making a change can help alot.
I dont remember if this car has shock position adjustments or not but that is probably the best thing you can do to help the handling. Where the top of the shock mounts you can see if this is adjustable. At the top shock mount see if there are different mounting holes. you can put the top of the shock down one hole (lay the shock down) for more "role" of the car which helps in some situations. Or you can Stand the shock up (move the position on hole up) to make the chassis stiffer with less role. All things that are dependent on where you run.
