OLD piccointegra parts
i've been looking for old 1/8 piccointegra parts I need belts 1st and 2nd gears and front and rear tires..i've search on ebay i have no luck.. I know its an old car but its my first 1/8 car. does anyone where i can find parts for it
You may be able to use belts from other cars. I know i had a Serpent front belt on mine once.
damn i wish paris racing is still open.
I Think I can Help You out with Parts for the 1/8 Integra Picco ,,, I'm Looking
picco
heres a whole car for sale on ebay...
http://cgi.ebay.com/PICCO-INTEGRA-1-...1%7C240%3A1318
here is the "Paris racing closeout inventory" it has a lot of parts
http://stores.ebay.com/Paris-Racing-...QQftidZ2QQtZkm
http://stores.ebay.com/Paris-Racing-...QQftidZ2QQtZkm[/QUOTE]
Picco, go to this site that VIPMOTORSPORTS has mentioned, it is on ebay and the lady that runs it is great, may Ron Paris's sole rest in pieace, the site carrys alot of stock and as you might be aware the Shepherd speed V2 is the old picco integra i believe. and for tires, i know 100% Twister tires make tires for the shepherd which im sure they could be the same rim as the integra, maybe just buy one set and see if they fit. BUT CHECK OUT THE SITE!!!
hope this helps.
Cheers from downunder.
hope this helps.
I have to agree with the guys in this forum. If you want to get Picco car parts, contact Linda on the Paris-racing ebay site. She has almost everything that the Picco car would use. She also was a great assett when I was getting parts for my Serpent 835 ((now sold)). Check her out!
You can get the belts from a serpent that is what i did when i needed a belt replacement..
I'm not sure but isn't the serpent car identical to the picco one?
I've used many serpent parts for my integra they only thing that doesn't fit
is the stearing bearing that should have the pins upside down.
Nothing was identical to the Integra. Many Serpent Vector parts did fit like belts, some of the pulleys, most bearings, clutch shoes and in a pinch I even used a Vector spur gear once with some grinding.
The Sheperd Speed was the Picco Speed, not the Integra. I'm sure some parts were interchangeable but they definitely were NOT the same car.
I believe the current Shepherd shocks are the same (but not positive).
So what if you need something?
I thought that the parts would be interchangeable with other car's parts..
If you brake something in your integra what should you do?
Most parts are not interchangeable between brands, except maybe pulleys and belts on some cars.
When a company stops making parts for a car, you just get a new car. That specially true with the Picco Integras, Picco stoped makeig parts for this car a long time ago, Picco doesnt even have a car anymore.
