Old 05-23-2011, 04:26 PM   #1
Default kyosho gt2 w/sirio help
just purchased one, raced carpet 1/10 long time ago so getting back into and first nitro so ill be on here quite abit. first couple questions anybody that races at leisure hours would probly answer the best but ill take any and all advice. what diff oils should i start out with,and shock help would be appreciated as far as lube and pistons.id like to get a good starting point.
thanks,mike
crash666 is offline   Reply With Quote
Old 05-23-2011, 09:50 PM   #2
thanks,mike
It depends on how you want it to handle:
A thick oil in the rear (100,000+ for example) will be like a drift car - the rear will kick out pretty easily.
I would put 40-50 weight oil in the shocks. Just my opinion.
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 05-25-2011, 03:11 PM   #3
i was told 100,000 front 10,000 in the rear does that sound about right,just need a ballpark. thanx
Old 05-26-2011, 12:16 AM   #4
That sounds good, will definitely hook-up well.
Old 05-26-2011, 12:48 AM   #5
Jspeed's Avatar
Ran there last Sept at Leisure Hours with 50K & 10K in my IGT2, thought it was a little stiff, would try 30K & 10K if/when I run there again.
Jspeed is offline   Reply With Quote
Old 05-26-2011, 08:23 AM   #6
Adams816's Avatar
im running 10,000 front and 7,000 rear. i like it
STRC LCG slash, XXX-T MF2 tekin
IGT2 O.S., IGT1 LRP, 18R, MiniZ MR02
Trex 450 pro, Trex 450 v2
Adams816 is offline   Reply With Quote
Old 05-26-2011, 02:44 PM   #7
thanks,ill stick with the 10,000 in the rear and lower the front atleast its something should start with.
