Old 05-22-2011, 03:55 AM   #1
Les
Les's Avatar
Default Clutch Nut
Hello,
Having problems with my 733 clutch, the retaining nut that tensions the spring is unwinding during racing, the nut finish's up flush with the end of the crank thread and its running against the clutch bell, i have been spacing the bell out with shims as you do so its not dragging on the clutch bell.
Pain in the rear problem.
Any Idea's would be appreciated.
Les
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 05-22-2011, 04:05 AM   #2
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Les View Post
Hello,
Les
what pre load are you running Les ? i think Rodney had this issue too, and the lack of preload he was using allowed it to unwind. if that is not the issue, you can use blue loctite and let it go off. the new flywheel nuts have a red coating on them, this tends to lock them on when wound up. can always ring me as well when you get stuck.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-22-2011, 05:09 AM   #3
Les
Les's Avatar
Thanks Patto, had my first run at Brendale 2day awsome track, preload 1.1mm never had the problem before, the engine rotates opposite 2 the nut so you would think it impossible to unwind, it only takes about 5 laps then I notice the engine bog starting.Good mixture of car brands here. Only have red loctite will that do or should I buy some blue.
Sanwa MT4S
Old 05-22-2011, 05:36 AM   #4
Pattojnr's Avatar
see if you can get blue. red maybe too strong. but use it if you have to. what happens is the red stuff on the flywheel nut wears off. then there isnt much to hold on the thread, as everything is worn in pretty well.
Serpent - Walter RC
Old 05-22-2011, 12:03 PM   #5
Geezatec's Avatar
How much endplay you have on the clutch?? Too much would would loosen clutch or delay clutch engagement. I never used loctite coz of contant ajusting. You get in correct you shouldn't have that problem.
Geezatec is offline   Reply With Quote
Old 05-22-2011, 12:36 PM   #6
Roelof's Avatar
Send a message via ICQ to Roelof
Also be sure that damages to the nut and the clutchbell (sticking out edges) are grinded away. They can be made when using a small pin through the clutchbell adjusting the nut
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-22-2011, 05:58 PM   #7
Les
Les's Avatar
Thanks, yes I tried minimal endplay and also generous endplay also swapped the clutch adjusting nut with one off another engine,it still unwound itself.
Sanwa MT4S
Old 05-22-2011, 06:36 PM   #8
nitrodude's Avatar
We have the same problem on the 966, just put a little bit of locktite on the nut and it stops.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-22-2011, 06:40 PM   #9
Les
Les's Avatar
Thanks Nitrodude and all who offered their suggestions, much appreciated.
Les
Sanwa MT4S
Old 05-22-2011, 10:00 PM   #10
Geezatec's Avatar
You didnt answer my question. I asked how much of endplay. You just told me minimum & maximum. Tell what the minimum measurement you obtained.
Old 05-23-2011, 12:04 AM   #11
Pattojnr's Avatar
i dont think it really matters now. the situation should be sorted .
minimal means next to no end play, and generouse, i would presume around 0.4 ? either way, its not how the clutch is engaging initially, its when the clutch nut comes loose, less preload on the spring, then it becomes boggy.
the serpent flywheel nuts, come with a red coating on them, this is kind of like a thread locking compound. when you remove your clutch a few times, this tends to dissapear, and the wear on the threads it becomes not as tight as when new. so wear to thread, and the locking compound wearing away contributes to the problem. has nothing to do with end play.
But Les, as roelof suggested, make sure everything is smooth inside where it was spinning on the bell.
Serpent - Walter RC
Old 05-23-2011, 01:58 AM   #12
Les
Les's Avatar
Yes 0.1
Sanwa MT4S
Old 05-23-2011, 02:05 AM   #13
Les
Les's Avatar
No worries Patto, the clutch has been disassembled quite a few times trying different engines so you are possibly correct with your theory, as I set the clutch up same as I always do, will try small amount of locktite till new flywheel nut arrives, test it at Bayside this weekend and post the result on this forum. Racing every weekend the Missus (pitcrew) loves it LOL
Cheers
Sanwa MT4S
Old 05-23-2011, 03:26 AM   #14
Pattojnr's Avatar
Cheers
good luck , states here in 2 weeks
got the 733 ready, just have to change over the 966 now. back to nitro !
Serpent - Walter RC
Old 05-23-2011, 05:46 AM   #15
Team Chump's Avatar
Default Bayside
Cheers
Good stuff, see you there
Walter R/C
Serpent
Reds Racing
Podified Race Fuel
Team Chump is offline   Reply With Quote
Locking the flywheel so I can remove the clutch nut on Losi 2.0 Garet Jax Nitro Off-Road 26 07-07-2009 03:51 PM
Help - clutch nut came loose while clutchbell attached Miller_Time Nitro Off-Road 22 12-17-2008 03:31 PM
Flywheel spinning on collet, cannot get clutch nut off. Semple Nitro Off-Road 25 08-18-2008 10:57 PM
Clutch Nut is, well...stuck paco62 Nitro Off-Road 25 03-10-2008 12:54 PM
