Old 05-24-2011, 01:37 AM   #16
blis's Avatar
Great to catch up at last Les.
The One Way seemed dodgy too... both spurs were stripped.
If the oneway seized and were engaged in 2nd and decellerated thru the sweeper then that could have unwound the clutch spring retainer. Just a thought.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 05-24-2011, 02:32 AM   #17
Les
Les's Avatar
h
Yep it was great to catch up, unfortunately didn't get a lot of time to chat as I spent the day chasing a few problems with the car,hadn't raced for a few months so car prep probably wasn't up to scratch, my fault. You are correct the oneway was problematic.
Really looking 4ward to next meeting at Brendale, will run at Bayside Sunday.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 06-03-2011, 05:11 AM   #18
Les
Les's Avatar
Originally Posted by Pattojnr View Post
see if you can get blue. red maybe too strong. but use it if you have to. what happens is the red stuff on the flywheel nut wears off. then there isnt much to hold on the thread, as everything is worn in pretty well.
Did try loctite, ran the car for 20 minutes on the track then checked the nut and it hadn't moved, so all is good.
Thanks guys for all the helpful hints.
Cheers
Sanwa MT4S
Locking the flywheel so I can remove the clutch nut on Losi 2.0 Garet Jax Nitro Off-Road 26 07-07-2009 03:51 PM
Help - clutch nut came loose while clutchbell attached Miller_Time Nitro Off-Road 22 12-17-2008 03:31 PM
Flywheel spinning on collet, cannot get clutch nut off. Semple Nitro Off-Road 25 08-18-2008 10:57 PM
Clutch Nut is, well...stuck paco62 Nitro Off-Road 25 03-10-2008 12:54 PM
