Old 05-11-2002, 04:30 PM   #1
Smile V-one R(R) and RNT
Wat Part of the V-oneR(R) does not fit in the Tinity RNT.
I know that the two speed does not fit.
And wich two speed is better the V-oneR(R) or the TRinity RNT.
TANKS
MARC
bryan is offline   Reply With Quote
Old 05-11-2002, 08:03 PM   #2
dtm
dtm's Avatar
Send a message via ICQ to dtm
So which car do you have? and why do you need to know which 2 speed is better?? providing the 2 speed can change when you want it to....it is good enough!!
dtm is offline   Reply With Quote
Old 05-12-2002, 07:16 AM   #3
Smile
I'm gonna have the V-oneRR and the Trinity RNT.
So I want one for spare parts .
So thats wy I'm asking wich one should I hold for spare parts.
Thats wy I ask too wich two speed is Better.
Marc
Old 05-12-2002, 10:41 AM   #4
dtm
dtm's Avatar
Marc
I have no experience with the Trinity one...but I know the Kyosho one is very good indeed!!
Old 05-13-2002, 03:50 PM   #5
Smile
can anybody help me with my question???/--------------------------------------------------------------------------------
V-one R(R) and RNT
TANKS
MARC
Old 05-13-2002, 04:45 PM   #6
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
Default hyes
<HTML>
<HEAD>
<TITLE></TITLE>
</HEAD>
<BODY BGCOLOR="#FFFFFF">
<P ALIGN="center"><A HREF="http://www.freewebz.com/badboyrc"><IMG BORDER="0" SRC="http://www.freewebz.com/badboyrc/banner1.GIF"></A><BR>
The Hottest RC Race site on the Net!</P>
</BODY>
</HTML>
BadBoyRC is offline   Reply With Quote
Old 05-13-2002, 04:48 PM   #7
AMGRacer's Avatar
Default Re: hyes
Originally posted by BadBoyRC
<HTML>
<HEAD>
<TITLE></TITLE>
</HEAD>
</BODY>
</HTML>
HTML does not work in posts.
The hottest RC Race site on the Net!
AMGRacer is offline   Reply With Quote
Old 05-13-2002, 11:11 PM   #8
patelladragger's Avatar
Send a message via AIM to patelladragger
bryan,
I have a v1r and a reflex. I don't have the RR (YET) but I'm going to assume it has the same 2 speed as a v1r. The reflex 2 speed in my opinion is slightly better than the v1r 2 speed. The reflex 2 speed is basically a serpent 2 speed. But like AMG said, what's to really compare - they both shift and are adjustable and hold their settings well once you set them.
However, if you are getting a V1RR, you will likely want to use the V1RR as the primary car and the reflex as a backup because the V1RR is going to be stronger, though I have heard trinity has corrected their plastic mold and brittle plastic issues in the latest kits. If you're making RR the primary, you will have to run the 2-speed from the v1r and get V1R replacement spurs because the reflex 2 speed isn't going to work on the V1R.
Most all other parts are interchangeable except I believe there are some spacing issues with the suspension arms and the clutch's aren't interchangeable. The stock reflex clutch isn't going to work in the voner, but if you get the RR and for some reason you wanted the reflex to be your primary then you CAN run the RR centax in the reflex with a little modifcation.
Hope this helps.
patelladragger is offline   Reply With Quote
