Old 06-24-2011, 08:18 AM   #61
avs
avs's Avatar
Originally Posted by JJBinks View Post
By the edge of spring tension do you mean they don't tighten very much at all leaving it rather "loose"?
i think he means they are setting it on the high side. so the clutch will seem a little too tight until it gets warmed up.
by the way, unless shepherd has changed their spring, it has always been a preferred part, by velox and mrx drivers.
you didn't indicate wear rate, how does the shoe look compared to a new one?
Tony Shimko
avs is offline   Reply With Quote
Old 06-24-2011, 12:43 PM   #62
Send a message via MSN to PMSorber
Youre correct we normally use 1 shoe for 2 or 3 races (so 2 or 3 weekends) Wear is a bit higher than normal.
Ow yeah, I forgot to mention. I guess (and know) that about 50% of all topdrivers use our spring.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 06-24-2011, 01:05 PM   #63
GMartinez's Avatar
Trader Rating: 85 (100%+)
1 left
http://www.superiorhobbies.com/istar...d=SMR600011!SH
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 06-24-2011, 02:17 PM   #64
Originally Posted by GMartinez View Post
Doing well mate.
@ConSult Trading
Old 06-24-2011, 02:36 PM   #65
wingracer's Avatar
Trader Rating: 24 (100%+)
It might be more than that. The only two springs I will use are Shepherd and Orion.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-24-2011, 02:43 PM   #66
Same here, but the Orion go's somewhere else
@ConSult Trading
Old 06-27-2011, 05:51 AM   #67
JJBinks's Avatar
Destroyed. Very worn down.
Jon Strausbaugh
2016 Great Lakes Challenge Race Director
Great Lakes Challenge Coordinator - One Eighth Racers
www.ToledoOneEighthRacers.com
Serpent Natrix 748, Revenge .12, Desoto Racing, Futaba
JJBinks is offline   Reply With Quote
Old 06-30-2011, 05:45 AM   #68
JJBinks's Avatar
Anyone have a set-up for Leisure Hours Raceway, Joliet? I didnt make the Byrons challenge but I will be there for the midwest series race.
Jon Strausbaugh
Old 06-30-2011, 06:28 AM   #69
are the V8 and V10 clutch springs the same?
tq23 is offline   Reply With Quote
Old 06-30-2011, 07:28 PM   #70
Merrillizer's Avatar
It's for 1/10 TC, but I ran this setup at the Byron's race.
Gears: 17/23, 58/54, for Novarossi 353C
35/37 trued to 57/59 for quals
37/40 trued to 60/62 for 45m main
Front spool
Stock rear diff oil
Ride Height: 5.5/6.5
Droop: 1-2mm front, 3-4mm rear
Camber: 2/3.5
Toe: -1/3
Caster: Center
Ackerman: Rear hole on chassis, servo saver arm long
Shocks: Built with hard preload spring for less rebound
Front shocks: Light or Dark Green, 700cst 3-hole, middle hole on tower
Rear shocks: Light Green, 600cst 3-hole, lowest hole on tower
Front swaybar: Flat
Rear swaybar: Medium
Front Roll Center: Pins up
Rear Roll Center: Low Insert, Pins down, 3mm shims on uprights, outer hole
I keep a fresh can of alphabet soup in my pit bag.
Merrillizer is offline   Reply With Quote
Old 07-01-2011, 06:01 AM   #71
JJBinks's Avatar
Thanks for the set up.
Did anyone run the V8 at leisure hour?
Jon Strausbaugh
Old 07-01-2011, 07:23 AM   #72
zosman's Avatar
Front spool
Stock rear diff oil
Camber: 2/3.5
Toe: -1/3
Caster: Center
Front swaybar: Flat
nice set bro
My hobbies is Rc
zosman is offline   Reply With Quote
Old 07-04-2011, 02:03 PM   #73
GMartinez's Avatar
Doing well mate.
Pretty well just got a chance to test out the V8 11 this weekend car goes together very well & rotate's very smooth wll have more info as I was breaking in the new Torque picco std version & will see once I can lay the power down if the current set up I put on will handle the same ttyl
Old 07-04-2011, 08:27 PM   #74
JJBinks's Avatar
Can anyone who switched from the 09 or 10 V8 to the Eleven Kit that recently came out provide me with differences they saw in chassis performance on the track? I am looking to possibly upgrade to the Eleven.
Jon Strausbaugh
Old 07-05-2011, 04:51 AM   #75
Yep. What we have noticed from the start is that the cars has far better corner entry behavior, more ballanced overall due to changed distributed weights.
@ConSult Trading
Team Associated TC5 RCknight Electric On-Road 13256 12-15-2017 05:13 PM
Shepherd V8 '09 Josh Cyrul Nitro On-Road 400 10-13-2011 07:09 AM
2009 Great Lakes Challenge "GLC" presented by Shepherd Micro Racing Brian Berry Nitro On-Road 164 08-10-2009 07:44 AM
